POSIX API Configuration Parameters
This module contains the parameters related to configuration of the POSIX API services. More...
#define CONFIGURE_MAXIMUM_POSIX_KEYS   0
 This configuration parameter specifies the maximum number of POSIX API keys. More...
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
 This macro is calculated to specify the memory required for POSIX API key/value pairs. More...
#define CONFIGURE_POSIX_KEYS   (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS)
 This macro is calculated to specify the total number of POSIX API keys required by the application and configured system capabilities. More...
#define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs)
 This macro is calculated to specify the memory required for POSIX API keys. More...
#define CONFIGURE_MAXIMUM_POSIX_THREADS   0
 This configuration parameter specifies the maximum number of POSIX API threads.
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE   0
 This configuration parameter specifies the stack size of the POSIX API Initialization thread (if used).
◆ CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
Value:
#define CONFIGURE_MAXIMUM_TASKS
This configures the maximum number of Classic API tasks.
Definition: confdefs.h:2075
Definition: confdefs.h:2449
Definition: confdefs.h:2751
This is an internal parameter.
◆ CONFIGURE_MAXIMUM_POSIX_KEYS
POSIX Keys are available whether or not the POSIX API is enabled.
◆ CONFIGURE_MEMORY_FOR_POSIX_KEYS
#define CONFIGURE_MEMORY_FOR_POSIX_KEYS (   _keys,
  _key_value_pairs
Value:
_Configure_Max_Objects(_key_value_pairs) \
#define _Configure_Object_RAM(_number, _size)
This macro accounts for how memory for a set of configured objects is allocated from the Executive Wo...
Definition: confdefs.h:1403
Represents POSIX key and value pair.
Definition: key.h:45
#define _Configure_From_workspace(_size)
This is a helper macro used in calculations in this file.
Definition: confdefs.h:1372
#define _Configure_Max_Objects(_max)
Do not use the unlimited bit as part of the multiplication for memory usage.
Definition: confdefs.h:1393
The data structure used to manage a POSIX key.
Definition: key.h:77
◆ CONFIGURE_POSIX_KEYS
