POSIX_API_Control Struct Reference
This defines the POSIX API support structure associated with each thread in a system with POSIX configured. More...
#include <threadsup.h>
Collaboration diagram for POSIX_API_Control:
Collaboration graph
[legend]
pthread_attr_t Attributes
 This is the POSIX threads attribute set. More...
int detachstate
 This indicates whether the thread is attached or detached. More...
Thread_queue_Control Join_List
 This is the set of threads waiting for the thread to exit. More...
int schedpolicy
 This is the thread's current scheduling policy. More...
struct sched_param schedparam
 This is the thread's current set of scheduling parameters. More...
int ss_high_priority
 This is the high priority to execute at when using the sporadic scheduler.
Watchdog_Control Sporadic_timer
 This is the timer which controls when the thread executes at high and low priority when using the sporadic scheduler.
sigset_t signals_blocked
 This is the set of signals which are currently blocked. More...
sigset_t signals_pending
 This is the set of signals which are currently pending. More...
Thread_Action Signal_action
 Signal post-switch action in case signals are pending.
int cancelability_state
 This is the cancelability state. More...
int cancelability_type
 This is the cancelability type. More...
int cancelation_requested
 This indicates if a cancelation has been requested. More...
Chain_Control Cancellation_Handlers
 This is the set of cancelation handlers. More...
Field Documentation
◆ Attributes
pthread_attr_t POSIX_API_Control::Attributes
◆ cancelability_state
int POSIX_API_Control::cancelability_state
Referenced by _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch(), and _POSIX_Threads_cancel_run().
◆ cancelability_type
int POSIX_API_Control::cancelability_type
Referenced by _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch().
◆ cancelation_requested
int POSIX_API_Control::cancelation_requested
◆ Cancellation_Handlers
Chain_Control POSIX_API_Control::Cancellation_Handlers
Referenced by _POSIX_Threads_cancel_run().
◆ detachstate
int POSIX_API_Control::detachstate
◆ Join_List
Thread_queue_Control POSIX_API_Control::Join_List
◆ schedparam
struct sched_param POSIX_API_Control::schedparam
Referenced by _POSIX_Threads_Sporadic_budget_callout(), and _POSIX_Threads_Sporadic_budget_TSR().
◆ schedpolicy
int POSIX_API_Control::schedpolicy
◆ signals_blocked
sigset_t POSIX_API_Control::signals_blocked
◆ signals_pending
sigset_t POSIX_API_Control::signals_pending
