#include <rtems.h>#include <rtems/error.h>#include <rtems/rtems_bsdnet.h>#include <rtems/rtems_bsdnet_internal.h>#include <string.h>#include <stdio.h>#include <errno.h>#include <rtems/dhcp.h>#include <rtems/rtems_dhcp_failsafe.h>#include <sys/ioctl.h>#include <sys/socket.h>#include <net/route.h>#include <netinet/in.h>#include <net/if.h>#include <net/if_var.h>#include <netinet/in_var.h>#include <sys/sockio.h>#include <arpa/inet.h>
| void | rtems_bsdnet_dhcp_failsafe_config (int network_fail_timeout_, int network_down_time_, int broadcast_delay_, int dhcp_monitor_priority_) |
| Set the DHCP fallback options. More... | |
| void | rtems_bsdnet_do_dhcp_failsafe (void) |
| void rtems_bsdnet_dhcp_failsafe_config | ( | int | network_fail_timeout, |
| int | network_down_time, | ||
| int | broadcast_delay, | ||
| int | dhcp_monitor_priority | ||
See the commentary at the top of the implementation.
| network_fail_timeout_ | The number of seconds before the interface is considered disconnected |
| network_down_time_ | The number of seconds the interface remains down. |
| broadcast_delay_ | The delay in seconds before broadcasts are sent. |
| dhcp_monitor_priority_ | The monitor priority. |
