in.h
1 /*
2  * Copyright (c) 1982, 1986, 1990, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)in.h 8.3 (Berkeley) 1/3/94
30  * $FreeBSD: src/sys/netinet/in.h,v 1.91 2005/08/22 16:13:07 andre Exp $
31  */
32
33
34 #ifndef _NETINET_IN_H_
35 #define _NETINET_IN_H_
36
37 #include <rtems/bsdnet/_types.h>
38 #include <rtems/endian.h>
39
40 #ifndef _IN_ADDR_T_DECLARED
41 typedef uint32_t in_addr_t;
42 #define _IN_ADDR_T_DECLARED
43 #endif
44
45 /* Protocols common to RFC 1700, POSIX, and X/Open. */
46 #define IPPROTO_IP 0 /* dummy for IP */
47 #define IPPROTO_ICMP 1 /* control message protocol */
48 #define IPPROTO_TCP 6 /* tcp */
49 #define IPPROTO_UDP 17 /* user datagram protocol */
50
51 #define INADDR_ANY (u_int32_t)0x00000000
52 #define INADDR_BROADCAST (u_int32_t)0xffffffff /* must be masked */
53
54 #ifndef _IN_PORT_T_DECLARED
55 typedef uint16_t in_port_t;
56 #define _IN_PORT_T_DECLARED
57 #endif
58
59 #ifndef _SA_FAMILY_T_DECLARED
60 typedef __sa_family_t sa_family_t;
61 #define _SA_FAMILY_T_DECLARED
62 #endif
63
64 /* Internet address (a structure for historical reasons). */
65 #ifndef _STRUCT_IN_ADDR_DECLARED
66 struct in_addr {
67  in_addr_t s_addr;
68 };
69 #define _STRUCT_IN_ADDR_DECLARED
70 #endif
71
72 /* Socket address, internet style. */
73 struct sockaddr_in {
74  uint8_t sin_len;
75  sa_family_t sin_family;
76  in_port_t sin_port;
77  struct in_addr sin_addr;
78  char sin_zero[8];
79 };
80
81
82 /*
83  * Constants and structures defined by the internet system,
84  * Per RFC 790, September 1981, and numerous additions.
85  */
86
87 /*
88  * Protocols (RFC 1700)
89  */
90 #define IPPROTO_HOPOPTS 0 /* IP6 hop-by-hop options */
91 #define IPPROTO_IGMP 2 /* group mgmt protocol */
92 #define IPPROTO_GGP 3 /* gateway^2 (deprecated) */
93 #define IPPROTO_IPV4 4 /* IPv4 encapsulation */
94 #define IPPROTO_IPIP IPPROTO_IPV4 /* for compatibility */
95 #define IPPROTO_ST 7 /* Stream protocol II */
96 #define IPPROTO_EGP 8 /* exterior gateway protocol */
97 #define IPPROTO_PIGP 9 /* private interior gateway */
98 #define IPPROTO_RCCMON 10 /* BBN RCC Monitoring */
99 #define IPPROTO_NVPII 11 /* network voice protocol*/
100 #define IPPROTO_PUP 12 /* pup */
101 #define IPPROTO_ARGUS 13 /* Argus */
102 #define IPPROTO_EMCON 14 /* EMCON */
103 #define IPPROTO_XNET 15 /* Cross Net Debugger */
104 #define IPPROTO_CHAOS 16 /* Chaos*/
105 #define IPPROTO_MUX 18 /* Multiplexing */
106 #define IPPROTO_MEAS 19 /* DCN Measurement Subsystems */
107 #define IPPROTO_HMP 20 /* Host Monitoring */
108 #define IPPROTO_PRM 21 /* Packet Radio Measurement */
109 #define IPPROTO_IDP 22 /* xns idp */
110 #define IPPROTO_TRUNK1 23 /* Trunk-1 */
111 #define IPPROTO_TRUNK2 24 /* Trunk-2 */
112 #define IPPROTO_LEAF1 25 /* Leaf-1 */
113 #define IPPROTO_LEAF2 26 /* Leaf-2 */
114 #define IPPROTO_RDP 27 /* Reliable Data */
115 #define IPPROTO_IRTP 28 /* Reliable Transaction */
116 #define IPPROTO_TP 29 /* tp-4 w/ class negotiation */
117 #define IPPROTO_BLT 30 /* Bulk Data Transfer */
118 #define IPPROTO_NSP 31 /* Network Services */
119 #define IPPROTO_INP 32 /* Merit Internodal */
120 #define IPPROTO_SEP 33 /* Sequential Exchange */
121 #define IPPROTO_3PC 34 /* Third Party Connect */
122 #define IPPROTO_IDPR 35 /* InterDomain Policy Routing */
123 #define IPPROTO_XTP 36 /* XTP */
124 #define IPPROTO_DDP 37 /* Datagram Delivery */
125 #define IPPROTO_CMTP 38 /* Control Message Transport */
126 #define IPPROTO_TPXX 39 /* TP++ Transport */
127 #define IPPROTO_IL 40 /* IL transport protocol */
128 #define IPPROTO_IPV6 41 /* IP6 header */
129 #define IPPROTO_SDRP 42 /* Source Demand Routing */
130 #define IPPROTO_ROUTING 43 /* IP6 routing header */
131 #define IPPROTO_FRAGMENT 44 /* IP6 fragmentation header */
132 #define IPPROTO_IDRP 45 /* InterDomain Routing*/
133 #define IPPROTO_RSVP 46 /* resource reservation */
134 #define IPPROTO_GRE 47 /* General Routing Encap. */
135 #define IPPROTO_MHRP 48 /* Mobile Host Routing */
136 #define IPPROTO_BHA 49 /* BHA */
137 #define IPPROTO_ESP 50 /* IP6 Encap Sec. Payload */
138 #define IPPROTO_AH 51 /* IP6 Auth Header */
139 #define IPPROTO_INLSP 52 /* Integ. Net Layer Security */
140 #define IPPROTO_SWIPE 53 /* IP with encryption */
141 #define IPPROTO_NHRP 54 /* Next Hop Resolution */
142 #define IPPROTO_MOBILE 55 /* IP Mobility */
143 #define IPPROTO_TLSP 56 /* Transport Layer Security */
144 #define IPPROTO_SKIP 57 /* SKIP */
145 #define IPPROTO_ICMPV6 58 /* ICMP6 */
146 #define IPPROTO_NONE 59 /* IP6 no next header */
147 #define IPPROTO_DSTOPTS 60 /* IP6 destination option */
148 #define IPPROTO_AHIP 61 /* any host internal protocol */
149 #define IPPROTO_CFTP 62 /* CFTP */
150 #define IPPROTO_HELLO 63 /* "hello" routing protocol */
151 #define IPPROTO_SATEXPAK 64 /* SATNET/Backroom EXPAK */
152 #define IPPROTO_KRYPTOLAN 65 /* Kryptolan */
153 #define IPPROTO_RVD 66 /* Remote Virtual Disk */
154 #define IPPROTO_IPPC 67 /* Pluribus Packet Core */
155 #define IPPROTO_ADFS 68 /* Any distributed FS */
156 #define IPPROTO_SATMON 69 /* Satnet Monitoring */
157 #define IPPROTO_VISA 70 /* VISA Protocol */
158 #define IPPROTO_IPCV 71 /* Packet Core Utility */
159 #define IPPROTO_CPNX 72 /* Comp. Prot. Net. Executive */
160 #define IPPROTO_CPHB 73 /* Comp. Prot. HeartBeat */
161 #define IPPROTO_WSN 74 /* Wang Span Network */
162 #define IPPROTO_PVP 75 /* Packet Video Protocol */
163 #define IPPROTO_BRSATMON 76 /* BackRoom SATNET Monitoring */
164 #define IPPROTO_ND 77 /* Sun net disk proto (temp.) */
165 #define IPPROTO_WBMON 78 /* WIDEBAND Monitoring */
166 #define IPPROTO_WBEXPAK 79 /* WIDEBAND EXPAK */
167 #define IPPROTO_EON 80 /* ISO cnlp */
168 #define IPPROTO_VMTP 81 /* VMTP */
169 #define IPPROTO_SVMTP 82 /* Secure VMTP */
170 #define IPPROTO_VINES 83 /* Banyon VINES */
171 #define IPPROTO_TTP 84 /* TTP */
172 #define IPPROTO_IGP 85 /* NSFNET-IGP */
173 #define IPPROTO_DGP 86 /* dissimilar gateway prot. */
174 #define IPPROTO_TCF 87 /* TCF */
175 #define IPPROTO_IGRP 88 /* Cisco/GXS IGRP */
176 #define IPPROTO_OSPFIGP 89 /* OSPFIGP */
177 #define IPPROTO_SRPC 90 /* Strite RPC protocol */
178 #define IPPROTO_LARP 91 /* Locus Address Resoloution */
179 #define IPPROTO_MTP 92 /* Multicast Transport */
180 #define IPPROTO_AX25 93 /* AX.25 Frames */
181 #define IPPROTO_IPEIP 94 /* IP encapsulated in IP */
182 #define IPPROTO_MICP 95 /* Mobile Int.ing control */
183 #define IPPROTO_SCCSP 96 /* Semaphore Comm. security */
184 #define IPPROTO_ETHERIP 97 /* Ethernet IP encapsulation */
185 #define IPPROTO_ENCAP 98 /* encapsulation header */
186 #define IPPROTO_APES 99 /* any private encr. scheme */
187 #define IPPROTO_GMTP 100 /* GMTP*/
188 #define IPPROTO_IPCOMP 108 /* payload compression (IPComp) */
189 /* 101-254: Partly Unassigned */
190 #define IPPROTO_PIM 103 /* Protocol Independent Mcast */
191 #define IPPROTO_CARP 112 /* CARP */
192 #define IPPROTO_PGM 113 /* PGM */
193 #define IPPROTO_PFSYNC 240 /* PFSYNC */
194 /* 255: Reserved */
195 /* BSD Private, local use, namespace incursion */
196 #define IPPROTO_DIVERT 254 /* divert pseudo-protocol */
197 #define IPPROTO_RAW 255 /* raw IP packet */
198 #define IPPROTO_MAX 256
199
200 /*
201  * Merged from FreeBSD 1.78 of this file so Python compiles.
202  * This is a size value for functions such as inet_ntop().
203  */
204 #define INET_ADDRSTRLEN 16
205
206 /*
207  * Local port number conventions:
208  *
209  * When a user does a bind(2) or connect(2) with a port number of zero,
210  * a non-conflicting local port address is chosen.
211  * The default range is IPPORT_HIFIRSTAUTO through
212  * IPPORT_HILASTAUTO, although that is settable by sysctl.
213  *
214  * A user may set the IPPROTO_IP option IP_PORTRANGE to change this
215  * default assignment range.
216  *
217  * The value IP_PORTRANGE_DEFAULT causes the default behavior.
218  *
219  * The value IP_PORTRANGE_HIGH changes the range of candidate port numbers
220  * into the "high" range. These are reserved for client outbound connections
221  * which do not want to be filtered by any firewalls.
222  *
223  * The value IP_PORTRANGE_LOW changes the range to the "low" are
224  * that is (by convention) restricted to privileged processes. This
225  * convention is based on "vouchsafe" principles only. It is only secure
226  * if you trust the remote host to restrict these ports.
227  *
228  * The default range of ports and the high range can be changed by
229  * sysctl(3). (net.inet.ip.port{hi,low}{first,last}_auto)
230  *
231  * Changing those values has bad security implications if you are
232  * using a stateless firewall that is allowing packets outside of that
233  * range in order to allow transparent outgoing connections.
234  *
235  * Such a firewall configuration will generally depend on the use of these
236  * default values. If you change them, you may find your Security
237  * Administrator looking for you with a heavy object.
238  */
239
240 /*
241  * Ports < IPPORT_RESERVED are reserved for
242  * privileged processes (e.g. root). (IP_PORTRANGE_LOW)
243  * Ports > IPPORT_USERRESERVED are reserved
244  * for servers, not necessarily privileged. (IP_PORTRANGE_DEFAULT)
245  */
246 #define IPPORT_RESERVED 1024
247 #define IPPORT_USERRESERVED 5000
248
249 /*
250  * Default local port range to use by setting IP_PORTRANGE_HIGH
251  */
252 #define IPPORT_HIFIRSTAUTO 40000
253 #define IPPORT_HILASTAUTO 44999
254
255 /*
256  * Scanning for a free reserved port return a value below IPPORT_RESERVED,
257  * but higher than IPPORT_RESERVEDSTART. Traditionally the start value was
258  * 512, but that conflicts with some well-known-services that firewalls may
259  * have a fit if we use.
260  */
261 #define IPPORT_RESERVEDSTART 600
262 /*
263  * Definitions of bits in internet address integers.
264  * On subnets, the decomposition of addresses to host and net parts
265  * is done according to subnet mask, not the masks here.
266  */
267 #define IN_CLASSA(i) (((u_int32_t)(i) & 0x80000000) == 0)
268 #define IN_CLASSA_NET 0xff000000
269 #define IN_CLASSA_NSHIFT 24
270 #define IN_CLASSA_HOST 0x00ffffff
271 #define IN_CLASSA_MAX 128
272
273 #define IN_CLASSB(i) (((u_int32_t)(i) & 0xc0000000) == 0x80000000)
274 #define IN_CLASSB_NET 0xffff0000
275 #define IN_CLASSB_NSHIFT 16
276 #define IN_CLASSB_HOST 0x0000ffff
277 #define IN_CLASSB_MAX 65536
278
279 #define IN_CLASSC(i) (((u_int32_t)(i) & 0xe0000000) == 0xc0000000)
280 #define IN_CLASSC_NET 0xffffff00
281 #define IN_CLASSC_NSHIFT 8
282 #define IN_CLASSC_HOST 0x000000ff
283
284 #define IN_CLASSD(i) (((u_int32_t)(i) & 0xf0000000) == 0xe0000000)
285 #define IN_CLASSD_NET 0xf0000000 /* These ones aren't really */
286 #define IN_CLASSD_NSHIFT 28 /* net and host fields, but */
287 #define IN_CLASSD_HOST 0x0fffffff /* routing needn't know. */
288 #define IN_MULTICAST(i) IN_CLASSD(i)
289
290 #define IN_EXPERIMENTAL(i) (((u_int32_t)(i) & 0xf0000000) == 0xf0000000)
291 #define IN_BADCLASS(i) (((u_int32_t)(i) & 0xf0000000) == 0xf0000000)
292
293 #define INADDR_LOOPBACK (u_int32_t)0x7f000001
294 #ifndef _KERNEL
295 #define INADDR_NONE 0xffffffff /* -1 return */
296 #endif
297
298 #define INADDR_UNSPEC_GROUP (u_int32_t)0xe0000000 /* 224.0.0.0 */
299 #define INADDR_ALLHOSTS_GROUP (u_int32_t)0xe0000001 /* 224.0.0.1 */
300 #define INADDR_ALLRTRS_GROUP (u_int32_t)0xe0000002 /* 224.0.0.2 */
301 #define INADDR_MAX_LOCAL_GROUP (u_int32_t)0xe00000ff /* 224.0.0.255 */
302
303 #define IN_LOOPBACKNET (u_int32_t)127 /* official! */
304
305 /*
306  * Options for use with [gs]etsockopt at the IP level.
307  * First word of comment is data type; bool is stored in int.
308  */
309 #define IP_OPTIONS 1 /* buf/ip_opts; set/get IP options */
310 #define IP_HDRINCL 2 /* int; header is included with data */
311 #define IP_TOS 3 /* int; IP type of service and preced. */
312 #define IP_TTL 4 /* int; IP time to live */
313 #define IP_RECVOPTS 5 /* bool; receive all IP opts w/dgram */
314 #define IP_RECVRETOPTS 6 /* bool; receive IP opts for response */
315 #define IP_RECVDSTADDR 7 /* bool; receive IP dst addr w/dgram */
316 #define IP_SENDSRCADDR IP_RECVDSTADDR /* cmsg_type to set src addr */
317 #define IP_RETOPTS 8 /* ip_opts; set/get IP options */
318 #define IP_MULTICAST_IF 9 /* u_char; set/get IP multicast i/f */
319 #define IP_MULTICAST_TTL 10 /* u_char; set/get IP multicast ttl */
320 #define IP_MULTICAST_LOOP 11 /* u_char; set/get IP multicast loopback */
321 #define IP_ADD_MEMBERSHIP 12 /* ip_mreq; add an IP group membership */
322 #define IP_DROP_MEMBERSHIP 13 /* ip_mreq; drop an IP group membership */
323 #define IP_MULTICAST_VIF 14 /* set/get IP mcast virt. iface */
324 #define IP_RSVP_ON 15 /* enable RSVP in kernel */
325 #define IP_RSVP_OFF 16 /* disable RSVP in kernel */
326 #define IP_RSVP_VIF_ON 17 /* set RSVP per-vif socket */
327 #define IP_RSVP_VIF_OFF 18 /* unset RSVP per-vif socket */
328 #define IP_PORTRANGE 19 /* int; range to choose for unspec port */
329 #define IP_RECVIF 20 /* bool; receive reception if w/dgram */
330
331 #define IP_FW_ADD 50 /* add a firewall rule to chain */
332 #define IP_FW_DEL 51 /* delete a firewall rule from chain */
333 #define IP_FW_FLUSH 52 /* flush firewall rule chain */
334 #define IP_FW_ZERO 53 /* clear single/all firewall counter(s) */
335 #define IP_FW_GET 54 /* get entire firewall rule chain */
336 #define IP_NAT 55 /* set/get NAT opts */
337
338 /*
339  * Defaults and limits for options
340  */
341 #define IP_DEFAULT_MULTICAST_TTL 1 /* normally limit m'casts to 1 hop */
342 #define IP_DEFAULT_MULTICAST_LOOP 1 /* normally hear sends if a member */
343 #define IP_MAX_MEMBERSHIPS 20 /* per socket */
344
345 /*
346  * Argument structure for IP_ADD_MEMBERSHIP and IP_DROP_MEMBERSHIP.
347  */
348 struct ip_mreq {
349  struct in_addr imr_multiaddr; /* IP multicast address of group */
350  struct in_addr imr_interface; /* local IP address of interface */
351 };
352
353 /*
354  * Argument for IP_PORTRANGE:
355  * - which range to search when port is unspecified at bind() or connect()
356  */
357 #define IP_PORTRANGE_DEFAULT 0 /* default range */
358 #define IP_PORTRANGE_HIGH 1 /* "high" - request firewall bypass */
359 #define IP_PORTRANGE_LOW 2 /* "low" - vouchsafe security */
360
361 /*
362  * Definitions for inet sysctl operations.
363  *
364  * Third level is protocol number.
365  * Fourth level is desired variable within that protocol.
366  */
367 #define IPPROTO_MAXID (IPPROTO_IDP + 1) /* don't list to IPPROTO_MAX */
368
369 #define CTL_IPPROTO_NAMES { \
370  { "ip", CTLTYPE_NODE }, \
371  { "icmp", CTLTYPE_NODE }, \
372  { "igmp", CTLTYPE_NODE }, \
373  { "ggp", CTLTYPE_NODE }, \
374  { 0, 0 }, \
375  { 0, 0 }, \
376  { "tcp", CTLTYPE_NODE }, \
377  { 0, 0 }, \
378  { "egp", CTLTYPE_NODE }, \
379  { 0, 0 }, \
380  { 0, 0 }, \
381  { 0, 0 }, \
382  { "pup", CTLTYPE_NODE }, \
383  { 0, 0 }, \
384  { 0, 0 }, \
385  { 0, 0 }, \
386  { 0, 0 }, \
387  { "udp", CTLTYPE_NODE }, \
388  { 0, 0 }, \
389  { 0, 0 }, \
390  { 0, 0 }, \
391  { 0, 0 }, \
392  { "idp", CTLTYPE_NODE }, \
393 }
394
395 /*
396  * Names for IP sysctl objects
397  */
398 #define IPCTL_FORWARDING 1 /* act as router */
399 #define IPCTL_SENDREDIRECTS 2 /* may send redirects when forwarding */
400 #define IPCTL_DEFTTL 3 /* default TTL */
401 #ifdef notyet
402 #define IPCTL_DEFMTU 4 /* default MTU */
403 #endif
404 #define IPCTL_RTEXPIRE 5 /* cloned route expiration time */
405 #define IPCTL_RTMINEXPIRE 6 /* min value for expiration time */
406 #define IPCTL_RTMAXCACHE 7 /* trigger level for dynamic expire */
407 #define IPCTL_SOURCEROUTE 8 /* may perform source routes */
408 #define IPCTL_DIRECTEDBROADCAST 9 /* may re-broadcast received packets */
409 #define IPCTL_INTRQMAXLEN 10 /* max length of netisr queue */
410 #define IPCTL_INTRQDROPS 11 /* number of netisr q drops */
411 #define IPCTL_ACCEPTSOURCEROUTE 13 /* may accept source routed packets */
412 #define IPCTL_MAXID 13
413
414 #define IPCTL_NAMES { \
415  { 0, 0 }, \
416  { "forwarding", CTLTYPE_INT }, \
417  { "redirect", CTLTYPE_INT }, \
418  { "ttl", CTLTYPE_INT }, \
419  { "mtu", CTLTYPE_INT }, \
420  { "rtexpire", CTLTYPE_INT }, \
421  { "rtminexpire", CTLTYPE_INT }, \
422  { "rtmaxcache", CTLTYPE_INT }, \
423  { "sourceroute", CTLTYPE_INT }, \
424  { "directed-broadcast", CTLTYPE_INT }, \
425  { "intr-queue-maxlen", CTLTYPE_INT }, \
426  { "intr-queue-drops", CTLTYPE_INT }, \
427  { "accept_sourceroute", CTLTYPE_INT }, \
428 }
429
430
431 #ifdef _KERNEL
432
433 struct ifnet; struct mbuf; /* forward declarations for Standard C */
434
435 int in_broadcast(struct in_addr, struct ifnet *);
436 int in_canforward(struct in_addr);
437 int in_cksum(struct mbuf *, int);
438 int in_localaddr(struct in_addr);
439 char *inet_ntoa(struct in_addr); /* in libkern */
440
441 /* Firewall hooks */
442 struct ip;
443 typedef int ip_fw_chk_t(struct ip**, int, struct ifnet*, int, struct mbuf**);
444 typedef int ip_fw_ctl_t(int, struct mbuf**);
445 extern ip_fw_chk_t *ip_fw_chk_ptr;
446 extern ip_fw_ctl_t *ip_fw_ctl_ptr;
447
448 /* IP NAT hooks */
449 typedef int ip_nat_t(struct ip**, struct mbuf**, struct ifnet*, int);
450 typedef int ip_nat_ctl_t(int, struct mbuf**);
451 extern ip_nat_t *ip_nat_ptr;
452 extern ip_nat_ctl_t *ip_nat_ctl_ptr;
453 #define IP_NAT_IN 0x00000001
454 #define IP_NAT_OUT 0x00000002
455
456 #endif /* _KERNEL */
457
458 #endif /* !_NETINET_IN_H_*/
Definition: in.h:74
This include file provides endian information about the target.
Definition: in.h:349
Definition: ip.h:61
Definition: inet.h:93
Definition: if_var.h:99
Definition: mbuf.h:103
