rtems-4.11.3
libnetworking
net
route.h
1
2
* Copyright (c) 1980, 1986, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)route.h 8.4 (Berkeley) 1/9/95
30
* $FreeBSD: src/sys/net/route.h,v 1.65 2006/03/15 19:39:09 andre Exp $
31
32
33
34
#ifndef _NET_ROUTE_H_
35
#define _NET_ROUTE_H_
36
37
sys/socket.h
/* struct sockaddr */
38
39
* Kernel resident routing tables.
40
41
* The routing tables are initialized when interface addresses
42
* are set by making entries for all directly connected interfaces.
43
44
45
46
* A route consists of a destination address and a reference
47
* to a routing entry. These are often held by protocols
48
* in their control blocks, e.g. inpcb.
49
50
struct
route
51
struct
rtentry
*ro_rt;
52
struct
sockaddr
ro_dst;
53
54
55
56
* These numbers are used by reliable protocols for determining
57
* retransmission behavior and are included in the routing structure.
58
59
struct
rt_metrics_lite
60
u_long rmx_mtu;
/* MTU for this path */
61
u_long rmx_expire;
/* lifetime for route, e.g. redirect */
62
u_long rmx_pksent;
/* packets sent using this route */
63
64
65
struct
rt_metrics
66
u_long rmx_locks;
/* Kernel must leave these values alone */
67
u_long rmx_mtu;
68
u_long rmx_hopcount;
/* max hops expected */
69
u_long rmx_expire;
70
u_long rmx_recvpipe;
/* inbound delay-bandwidth product */
71
u_long rmx_sendpipe;
/* outbound delay-bandwidth product */
72
u_long rmx_ssthresh;
/* outbound gateway buffer limit */
73
u_long rmx_rtt;
/* estimated round trip time */
74
u_long rmx_rttvar;
/* estimated rtt variance */
75
u_long rmx_pksent;
76
u_long rmx_filler[4];
/* will be used for T/TCP later */
77
78
79
80
* rmx_rtt and rmx_rttvar are stored as microseconds;
81
* RTTTOPRHZ(rtt) converts to a value suitable for use
82
* by a protocol slowtimo counter.
83
84
#define RTM_RTTUNIT 1000000
/* units for rtt, rttvar, as units per sec */
85
#define RTTTOPRHZ(r) ((r) / (RTM_RTTUNIT / PR_SLOWHZ))
86
87
88
* XXX kernel function pointer `rt_output' is visible to applications.
89
90
struct
mbuf
91
92
93
* We distinguish between routes to hosts and routes to networks,
94
* preferring the former if available. For each route we infer
95
* the interface to use from the gateway address supplied when
96
* the route was entered. Routes that forward packets through
97
* gateways are marked so that the output routines know to address the
98
* gateway rather than the ultimate destination.
99
100
#ifndef RNF_NORMAL
101
net/radix.h
102
#endif
103
struct
rtentry
104
struct
radix_node
rt_nodes[2];
/* tree glue, and other values */
105
#define rt_key(r) ((struct sockaddr *)((r)->rt_nodes->rn_key))
106
#define rt_mask(r) ((struct sockaddr *)((r)->rt_nodes->rn_mask))
107
struct
sockaddr
*rt_gateway;
/* value */
108
u_long rt_flags;
/* up/down?, host/net */
109
struct
ifnet
*rt_ifp;
/* the answer: interface to use */
110
struct
ifaddr
*rt_ifa;
/* the answer: interface address to use */
111
struct
rt_metrics
rt_rmx;
/* metrics used by rx'ing protocols */
112
long
rt_refcnt;
/* # held references */
113
struct
sockaddr
*rt_genmask;
/* for generation of cloned routes */
114
caddr_t rt_llinfo;
/* pointer to link level info cache */
115
struct
rtentry
*rt_gwroute;
/* implied entry for gatewayed routes */
116
struct
rtentry
*rt_parent;
/* cloning parent of this route */
117
118
119
120
* Following structure necessary for 4.3 compatibility;
121
* We should eventually move it to a compat file.
122
123
struct
ortentry
124
u_long rt_hash;
/* to speed lookups */
125
struct
sockaddr
rt_dst;
/* key */
126
struct
sockaddr
rt_gateway;
/* value */
127
short
rt_flags;
128
short
rt_refcnt;
129
u_long rt_use;
/* raw # packets forwarded */
130
struct
ifnet
*rt_ifp;
131
132
133
#define rt_use rt_rmx.rmx_pksent
134
135
#define RTF_UP 0x1
/* route usable */
136
#define RTF_GATEWAY 0x2
/* destination is a gateway */
137
#define RTF_HOST 0x4
/* host entry (net otherwise) */
138
#define RTF_REJECT 0x8
/* host or net unreachable */
139
#define RTF_DYNAMIC 0x10
/* created dynamically (by redirect) */
140
#define RTF_MODIFIED 0x20
/* modified dynamically (by redirect) */
141
#define RTF_DONE 0x40
/* message confirmed */
142
/* 0x80 unused, was RTF_DELCLONE */
143
#define RTF_CLONING 0x100
/* generate new routes on use */
144
#define RTF_XRESOLVE 0x200
/* external daemon resolves name */
145
#define RTF_LLINFO 0x400
/* generated by link layer (e.g. ARP) */
146
#define RTF_STATIC 0x800
/* manually added */
147
#define RTF_BLACKHOLE 0x1000
/* just discard pkts (during updates) */
148
#define RTF_PROTO2 0x4000
/* protocol specific routing flag */
149
#define RTF_PROTO1 0x8000
150
151
#define RTF_PRCLONING 0x10000
/* protocol requires cloning */
152
#define RTF_WASCLONED 0x20000
/* route generated through cloning */
153
#define RTF_PROTO3 0x40000
154
/* 0x80000 unused */
155
#define RTF_PINNED 0x100000
/* future use */
156
#define RTF_LOCAL 0x200000
/* route represents a local address */
157
#define RTF_BROADCAST 0x400000
/* route represents a bcast address */
158
#define RTF_MULTICAST 0x800000
/* route represents a mcast address */
159
/* 0x1000000 and up unassigned */
160
161
162
* Routing statistics.
163
164
struct
rtstat
165
short
rts_badredirect;
/* bogus redirect calls */
166
short
rts_dynamic;
/* routes created by redirects */
167
short
rts_newgateway;
/* routes modified by redirects */
168
short
rts_unreach;
/* lookups which failed */
169
short
rts_wildcard;
/* lookups satisfied by a wildcard */
170
171
172
* Structures for routing messages.
173
174
struct
rt_msghdr
175
u_short rtm_msglen;
/* to skip over non-understood messages */
176
u_char rtm_version;
/* future binary compatibility */
177
u_char rtm_type;
/* message type */
178
u_short rtm_index;
/* index for associated ifp */
179
int
rtm_flags;
/* flags, incl. kern & message, e.g. DONE */
180
int
rtm_addrs;
/* bitmask identifying sockaddrs in msg */
181
pid_t rtm_pid;
/* identify sender */
182
int
rtm_seq;
/* for sender to identify action */
183
int
rtm_errno;
/* why failed */
184
int
rtm_use;
/* from rtentry */
185
u_long rtm_inits;
/* which metrics we are initializing */
186
struct
rt_metrics
rtm_rmx;
/* metrics themselves */
187
188
189
#define RTM_VERSION 5
/* Up the ante and ignore older versions */
190
191
192
* Message types.
193
194
#define RTM_ADD 0x1
/* Add Route */
195
#define RTM_DELETE 0x2
/* Delete Route */
196
#define RTM_CHANGE 0x3
/* Change Metrics or flags */
197
#define RTM_GET 0x4
/* Report Metrics */
198
#define RTM_LOSING 0x5
/* Kernel Suspects Partitioning */
199
#define RTM_REDIRECT 0x6
/* Told to use different route */
200
#define RTM_MISS 0x7
/* Lookup failed on this address */
201
#define RTM_LOCK 0x8
/* fix specified metrics */
202
#define RTM_OLDADD 0x9
/* caused by SIOCADDRT */
203
#define RTM_OLDDEL 0xa
/* caused by SIOCDELRT */
204
#define RTM_RESOLVE 0xb
/* req to resolve dst to LL addr */
205
#define RTM_NEWADDR 0xc
/* address being added to iface */
206
#define RTM_DELADDR 0xd
/* address being removed from iface */
207
#define RTM_IFINFO 0xe
/* iface going up/down etc. */
208
#define RTM_NEWMADDR 0xf
/* mcast group membership being added to if */
209
#define RTM_DELMADDR 0x10
/* mcast group membership being deleted */
210
#define RTM_IFANNOUNCE 0x11
/* iface arrival/departure */
211
#define RTM_IEEE80211 0x12
/* IEEE80211 wireless event */
212
213
214
* Bitmask values for rtm_inits and rmx_locks.
215
216
#define RTV_MTU 0x1
/* init or lock _mtu */
217
#define RTV_HOPCOUNT 0x2
/* init or lock _hopcount */
218
#define RTV_EXPIRE 0x4
/* init or lock _expire */
219
#define RTV_RPIPE 0x8
/* init or lock _recvpipe */
220
#define RTV_SPIPE 0x10
/* init or lock _sendpipe */
221
#define RTV_SSTHRESH 0x20
/* init or lock _ssthresh */
222
#define RTV_RTT 0x40
/* init or lock _rtt */
223
#define RTV_RTTVAR 0x80
/* init or lock _rttvar */
224
225
226
* Bitmask values for rtm_addrs.
227
228
#define RTA_DST 0x1
/* destination sockaddr present */
229
#define RTA_GATEWAY 0x2
/* gateway sockaddr present */
230
#define RTA_NETMASK 0x4
/* netmask sockaddr present */
231
#define RTA_GENMASK 0x8
/* cloning mask sockaddr present */
232
#define RTA_IFP 0x10
/* interface name sockaddr present */
233
#define RTA_IFA 0x20
/* interface addr sockaddr present */
234
#define RTA_AUTHOR 0x40
/* sockaddr for author of redirect */
235
#define RTA_BRD 0x80
/* for NEWADDR, broadcast or p-p dest addr */
236
237
238
* Index offsets for sockaddr array for alternate internal encoding.
239
240
#define RTAX_DST 0
241
#define RTAX_GATEWAY 1
242
#define RTAX_NETMASK 2
243
#define RTAX_GENMASK 3
244
#define RTAX_IFP 4
245
#define RTAX_IFA 5
246
#define RTAX_AUTHOR 6
247
#define RTAX_BRD 7
248
#define RTAX_MAX 8
/* size of array to allocate */
249
250
struct
rt_addrinfo
251
int
rti_addrs;
252
struct
sockaddr
*rti_info[RTAX_MAX];
253
254
255
struct
route_cb {
256
int
ip_count;
257
int
ipx_count;
258
int
ns_count;
259
int
iso_count;
260
int
any_count;
261
262
263
#ifdef _KERNEL
264
#define RTFREE(rt) \
265
do { \
266
if ((rt)->rt_refcnt <= 1) \
267
rtfree(rt); \
268
else \
269
(rt)->rt_refcnt--; \
270
} while (0)
271
272
extern
struct
route_cb route_cb;
273
extern
struct
radix_node_head
*rt_tables[AF_MAX+1];
274
275
void
route_init(
void
276
void
rt_ifmsg(
struct
ifnet
277
void
rt_missmsg(
int
struct
rt_addrinfo
int
int
278
void
rt_newaddrmsg(
int
struct
ifaddr
int
struct
rtentry
279
int
rt_setgate(
struct
rtentry
struct
sockaddr
struct
sockaddr
280
void
rtalloc_ign(
struct
route
unsigned
long
281
void
rtalloc(
struct
route
*ro);
/* XXX deprecated, use rtalloc_ign(ro, 0) */
282
struct
rtentry
283
rtalloc1(
struct
sockaddr
int
unsigned
long
284
void
rtfree(
struct
rtentry
285
int
rtinit(
struct
ifaddr
int
int
286
int
rtioctl(
int
, caddr_t,
struct
proc
287
void
rtredirect(
struct
sockaddr
struct
sockaddr
288
struct
sockaddr
int
struct
sockaddr
struct
rtentry
289
int
rtrequest(
int
struct
sockaddr
290
struct
sockaddr
struct
sockaddr
int
struct
rtentry
291
#endif
292
293
#endif
rt_msghdr
Definition:
route.h:175
ortentry
Definition:
route.h:124
radix_node_head
Definition:
radix.h:106
proc
Definition:
proc.h:5
route
Definition:
route.h:51
radix_node
Definition:
radix.h:41
rt_addrinfo
Definition:
route.h:251
rtstat
Definition:
route.h:165
sockaddr
Definition:
socket.h:180
ifnet
Definition:
if_var.h:99
ifaddr
Definition:
if_var.h:211
mbuf
Definition:
mbuf.h:103
rt_metrics_lite
Definition:
route.h:60
radix.h
socket.h
rtentry
Definition:
route.h:104
rt_metrics
Definition:
route.h:66
