18 #ifndef _RTEMS_SCORE_TODIMPL_H 19 #define _RTEMS_SCORE_TODIMPL_H 45 #define TOD_SECONDS_PER_MINUTE (uint32_t)60 50 #define TOD_MINUTES_PER_HOUR (uint32_t)60 55 #define TOD_MONTHS_PER_YEAR (uint32_t)12 60 #define TOD_DAYS_PER_YEAR (uint32_t)365 65 #define TOD_HOURS_PER_DAY (uint32_t)24 71 #define TOD_SECONDS_PER_DAY (uint32_t) (TOD_SECONDS_PER_MINUTE * \ 72 TOD_MINUTES_PER_HOUR * \ 78 #define TOD_SECONDS_PER_NON_LEAP_YEAR (365 * TOD_SECONDS_PER_DAY) 83 #define TOD_MILLISECONDS_PER_SECOND (uint32_t)1000 88 #define TOD_MICROSECONDS_PER_SECOND (uint32_t)1000000 93 #define TOD_NANOSECONDS_PER_SECOND (uint32_t)1000000000 98 #define TOD_NANOSECONDS_PER_MICROSECOND (uint32_t)1000 107 #define TOD_SECONDS_1970_THROUGH_1988 \ 108 (((1987 - 1970 + 1) * TOD_SECONDS_PER_NON_LEAP_YEAR) + \ 109 (4 * TOD_SECONDS_PER_DAY)) 118 #define TOD_BASE_YEAR 1988 184 static inline void _TOD_Set(
185 const struct timespec *tod_as_timespec
192 tod_as_timespec->tv_sec,
193 tod_as_timespec->tv_nsec
203 static inline void _TOD_Get(
215 static inline void _TOD_Get_as_timespec(
216 struct timespec *time
232 static inline void _TOD_Get_uptime(
247 static inline void _TOD_Get_zero_based_uptime(
262 static inline void _TOD_Get_zero_based_uptime_as_timespec(
263 struct timespec *time
276 static inline uint32_t _TOD_Seconds_since_epoch(
void )
307 #define TOD_TICKS_PER_SECOND TOD_TICKS_PER_SECOND_method() TOD control.
Definition: todimpl.h:132
void _Timecounter_Bintime(struct bintime *bt)
Returns the wall clock time in the bintime format.
RTEMS_INLINE_ROUTINE void _TOD_Get_timeval(struct timeval *time)
This routine returns a timeval based upon the internal timespec format TOD.
Definition: todimpl.h:313
void _TOD_Tickle_ticks(void)
Increments time of day at each clock tick.
Definition: coretodtickle.c:25
uint32_t seconds_trigger
Time of day seconds trigger.
Definition: todimpl.h:140
void _Timecounter_Binuptime(struct bintime *bt)
Returns the uptime in the bintime format.
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
Helpers for Manipulating Timestamps.
void _TOD_Handler_initialization(void)
Initializes the time of day handler.
Definition: coretod.c:23
bool is_set
Indicates if the time of day is set.
Definition: todimpl.h:148
RTEMS_INLINE_ROUTINE bool _TOD_Is_set(void)
Check if the TOD is Set.
Definition: todimpl.h:337
volatile time_t _Timecounter_Time_second
The wall clock time in seconds.
void _TOD_Set_with_timestamp(const Timestamp_Control *tod_as_timestamp)
Sets the time of day from timestamp.
Definition: coretodset.c:25
void _Timecounter_Nanouptime(struct timespec *ts)
Returns the uptime in the timespec format.
Timecounter Implementation.
void _Timecounter_Nanotime(struct timespec *ts)
Returns the wall clock time in the timespec format.
uint32_t TOD_TICKS_PER_SECOND_method(void)
Gets number of ticks in a second.
Definition: coretodtickspersec.c:24
struct bintime Timestamp_Control
Define the Timestamp control type.
Definition: timestamp.h:55
Definition: rtems_bsdnet.h:233
void _Timecounter_Microtime(struct timeval *tv)
Returns the wall clock time in the timeval format.
RTEMS_INLINE_ROUTINE void _Timestamp_Set(Timestamp_Control *_time, time_t _seconds, long _nanoseconds)
Set timestamp to specified seconds and nanoseconds.
Definition: timestamp.h:67
#define SCORE_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:81
void _TOD_Adjust(const Timestamp_Control timestamp)
Adjust the Time of Time.
Definition: coretodadjust.c:24
