RTEMS 4.6.1 On-Line Library
Concept Index
RTEMS C User's Guide
Concept Index
add memory to a region
announce arrival of package
announce fatal error
aperiodic task, definition
ASR
ASR mode, building
ASR vs. ISR
asynchronous signal routine
binary semaphores
Board Support Packages
broadcast message to a queue
BSP, definition
BSPs
buffers, definition
cancel a period
cancel a timer
clock
clock tick
close a device
communication and synchronization
conclude current period
confdefs.h
Configuration Table
convert external to internal address
convert internal to external address
counting semaphores
CPU Dependent Information Table
create a message queue
create a partition
create a period
create a port
create a region
create a semaphore
create a task
create a timer
create an extension set
current task mode
current task priority
delay a task for an interval
delay a task until a wall time
delays
delete a message queue
delete a partition
delete a period
delete a port
delete a region
delete a semaphore
delete a timer
delete an extension set
deleting a task
device driver interface
Device Driver Table
device drivers
device names
disable interrupts
disabling interrupts
dispatching
dual ported memory
dual ported memory, definition
enable interrupts
establish an ASR
establish an ISR
event condition, building
event flag, definition
event set, building
event set, definition
events
extension set
external addresses, definition
fatal error detection
fatal error processing
fatal error user extension
fatal error, announce
fatal errors
fire a task-based timer at wall time
fire a timer after an interval
fire a timer at wall time
fire task-based a timer after an interval
flash interrupts
floating point
flush a semaphore
flush messages on a queue
get buffer from partition
get class from object ID
get ID of a message queue
get ID of a partition
get ID of a period
get ID of a port
get ID of a region
get ID of a semaphore
get ID of a task
get ID of an extension set
get index from object ID
get node from object ID
get number of pending messages
get per-task variable
get segment from region
get size of segment
get status of period
get task mode
get task notepad entry
get task preemption mode
get task priority
global objects table
global objects, definition
heterogeneous multiprocessing
initialization tasks
Initialization Tasks Table
initialize a device driver
initialize RTEMS
initiate the Timer Server
install an ASR
install an ISR
internal addresses, definition
interrupt level, task
interrupt levels
interrupt processing
IO Control
IO Manager
is interrupt in progress
is task suspended
ISR vs. ASR
lock a semaphore
lookup device major and minor number
major device number
manual round robin
memory management
message queue attributes
message queues
messages
minor device number
MPCI and remote operations
MPCI entry points
MPCI, definition
multiprocessing
multiprocessing topologies
Multiprocessor Communications Interface Table
Multiprocessor Configuration Table
mutual exclusion
nodes, definition
object ID
object ID composition
object name
objects
obtain a semaphore
obtain buffer from partition
obtain ID of a partition
obtain ID of a period
obtain ID of a port
obtain ID of a region
obtain ID of a semaphore
obtain ID of an extension set
obtain per-task variable
obtain status of period
obtain task mode
obtain task priority
obtain the ID of a timer
obtain the time of day
obtaining class from object ID
obtaining index from object ID
obtaining node from object ID
open a devive
partition attribute set, building
partition, definition
partitions
per task variables
per-task variable
period initiation
periodic tasks
ports
POSIX API Configuration Table
preemption
priority, task
proxy, definition
put message at front of queue
rate mononitonic tasks
Rate Monotonic Scheduling Algorithm, definition
read from a device
receive event condition
receive message from a queue
region attribute set, building
region, add memory
region, definition
regions
register a device driver
register device
release a semaphore
reset a timer
restarting a task
resuming a task
return buffer to partitition
return segment to region
RMS Algorithm, definition
RMS First Deadline Rule
RMS Processor Utilization Rule
RMS schedulability analysis
round robin scheduling
RTEMS API Configuration Table
RTEMS Configuration Table
runtime driver registration
scheduling
scheduling mechanisms
segment, definition
semaphores
send event set to a task
send message to a queue
send signal set
set task mode
set task notepad entry
set task preemption mode
set task priority
set the time of day
shutdown RTEMS
signal set, building
signals
special device services
sporadic task, definition
start current period
start multitasking
starting a task
suspending a task
task arguments
task attributes, building
task mode
task mode, building
task priority
task private data
task private variable
task prototype
task scheduling
task state transitions
task states
task, definition
tasks
TCB extension area
time
timeouts
timers
timeslicing
unblock all tasks waiting on a semaphore
unlock a semaphore
unregister a device driver
user extensions
User Extensions Table
wake up after an interval
wake up at a wall time
write to a device
Copyright © 1988-2004
OAR Corporation
