RTEMS Logo
RTEMS 4.6.1 On-Line Library
Task Manager TASK_WAKE_AFTER - Wake up after interval
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.13: TASK_WAKE_AFTER - Wake up after interval
CALLING SEQUENCE:
rtems_status_code rtems_task_wake_after(
  rtems_interval ticks
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - always successful
DESCRIPTION:
This directive blocks the calling task for the specified number of system clock ticks. When the requested interval has elapsed, the task is made ready. The rtems_clock_tick directive automatically updates the delay period.
NOTES:
Setting the system date and time with the rtems_clock_set directive has no effect on a rtems_task_wake_after blocked task.
A task may give up the processor and remain in the ready state by specifying a value of RTEMS_YIELD_PROCESSOR in ticks.
The maximum timer interval that can be specified is the maximum value which can be represented by the rtems_unsigned32 type.
A clock tick is required to support the functionality of this directive.
