RTEMS Logo
RTEMS 4.6.1 On-Line Library
Clock Manager CLOCK_SET - Set system date and time
PREV UP NEXT Bookshelf RTEMS C User's Guide
7.4.1: CLOCK_SET - Set system date and time
CALLING SEQUENCE:
rtems_status_code rtems_clock_set(
  rtems_time_of_day *time_buffer
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - date and time set successfully
RTEMS_INVALID_TIME_OF_DAY - invalid time of day
DESCRIPTION:
This directive sets the system date and time. The date, time, and ticks in the time_buffer structure are all range-checked, and an error is returned if any one is out of its valid range.
NOTES:
Years before 1988 are invalid.
The system date and time are based on the configured tick rate (number of microseconds in a tick).
Setting the time forward may cause a higher priority task, blocked waiting on a specific time, to be made ready. In this case, the calling task will be preempted after the next clock tick.
Re-initializing RTEMS causes the system date and time to be reset to an uninitialized state. Another call to rtems_clock_set is required to re-initialize the system date and time to application specific specifications.
