RTEMS Logo
RTEMS 4.6.1 On-Line Library
Interrupt Manager INTERRUPT_IS_IN_PROGRESS - Is an ISR in Progress
PREV UP NEXT Bookshelf RTEMS C User's Guide
6.4.5: INTERRUPT_IS_IN_PROGRESS - Is an ISR in Progress
CALLING SEQUENCE:
rtems_boolean rtems_interrupt_is_in_progress( void );
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive returns TRUE if the processor is currently servicing an interrupt and FALSE otherwise. A return value of TRUE indicates that the caller is an interrupt service routine, NOT a task. The directives available to an interrupt service routine are restricted.
NOTES:
This directive will not cause the calling task to be preempted.
