rtems_status_code rtems_task_ident( rtems_name name, rtems_unsigned32 node, rtems_id *id );
RTEMS_SUCCESSFUL
- task identified successfully
RTEMS_INVALID_NAME
- invalid task name
RTEMS_INVALID_NODE
- invalid node id
This directive obtains the task id associated with the task name
specified in name. A task may obtain its own id by specifying
RTEMS_SELF
or its own task name in name. If the task name is not
unique, then the task id returned will match one of the tasks
with that name. However, this task id is not guaranteed to
correspond to the desired task. The task id, returned in id, is
used in other task related directives to access the task.
This directive will not cause the running task to be preempted.
If node is RTEMS_SEARCH_ALL_NODES
, all nodes are searched with the
local node being searched first. All other nodes are searched
with the lowest numbered node searched first.
If node is a valid node number which does not represent the local node, then only the tasks exported by the designated node are searched.
This directive does not generate activity on remote nodes. It accesses only the local copy of the global object table.
