RTEMS Logo
RTEMS 4.6.1 On-Line Library
Task Manager TASK_START - Start a task
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.3: TASK_START - Start a task
CALLING SEQUENCE:
rtems_status_code rtems_task_start(
  rtems_id            id,
  rtems_task_entry    entry_point,
  rtems_task_argument argument
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - ask started successfully
RTEMS_INVALID_ADDRESS - invalid task entry point
RTEMS_INVALID_ID - invalid task id
RTEMS_INCORRECT_STATE - task not in the dormant state
RTEMS_ILLEGAL_ON_REMOTE_OBJECT - cannot start remote task
DESCRIPTION:
This directive readies the task, specified by tid, for execution based on the priority and execution mode specified when the task was created. The starting address of the task is given in entry_point. The task's starting argument is contained in argument. This argument can be a single value or used as an index into an array of parameter blocks.
NOTES:
The calling task will be preempted if its preemption mode is enabled and the task being started has a higher priority.
Any actions performed on a dormant task such as suspension or change of priority are nullified when the task is initiated via the rtems_task_start directive.
