RTEMS 6.1
Data Fields | |
| SAI_Block_TypeDef * | Instance |
| SAI_InitTypeDef | Init |
| SAI_FrameInitTypeDef | FrameInit |
| SAI_SlotInitTypeDef | SlotInit |
| uint8_t * | pBuffPtr |
| uint16_t | XferSize |
| uint16_t | XferCount |
| DMA_HandleTypeDef * | hdmatx |
| DMA_HandleTypeDef * | hdmarx |
| SAIcallback | mutecallback |
| void(* | InterruptServiceRoutine )(struct __SAI_HandleTypeDef *hsai) |
| HAL_LockTypeDef | Lock |
| __IO HAL_SAI_StateTypeDef | State |
| __IO uint32_t | ErrorCode |
| __IO uint32_t __SAI_HandleTypeDef::ErrorCode |
SAI Error code
| SAI_FrameInitTypeDef __SAI_HandleTypeDef::FrameInit |
SAI Frame configuration parameters
| DMA_HandleTypeDef* __SAI_HandleTypeDef::hdmarx |
SAI Rx DMA handle parameters
| DMA_HandleTypeDef* __SAI_HandleTypeDef::hdmatx |
SAI Tx DMA handle parameters
| SAI_InitTypeDef __SAI_HandleTypeDef::Init |
SAI communication parameters
| SAI_Block_TypeDef* __SAI_HandleTypeDef::Instance |
SAI Blockx registers base address
| HAL_LockTypeDef __SAI_HandleTypeDef::Lock |
SAI locking object
| SAIcallback __SAI_HandleTypeDef::mutecallback |
SAI mute callback
| uint8_t* __SAI_HandleTypeDef::pBuffPtr |
Pointer to SAI transfer Buffer
| SAI_SlotInitTypeDef __SAI_HandleTypeDef::SlotInit |
SAI Slot configuration parameters
| __IO HAL_SAI_StateTypeDef __SAI_HandleTypeDef::State |
SAI communication state
| uint16_t __SAI_HandleTypeDef::XferCount |
SAI transfer counter
| uint16_t __SAI_HandleTypeDef::XferSize |
SAI transfer size
