◆ FirstBitOffset
| uint32_t SAI_SlotInitTypeDef::FirstBitOffset |
Specifies the position of first data transfer bit in the slot. This parameter must be a number between Min_Data = 0 and Max_Data = 24
◆ SlotActive
| uint32_t SAI_SlotInitTypeDef::SlotActive |
Specifies the slots in audio frame that will be activated. This parameter can be a value of SAI Block Slot Active
◆ SlotNumber
| uint32_t SAI_SlotInitTypeDef::SlotNumber |
Specifies the number of slot in the audio frame. This parameter must be a number between Min_Data = 1 and Max_Data = 16
◆ SlotSize
| uint32_t SAI_SlotInitTypeDef::SlotSize |
