RTEMS 6.1
__IO uint32_t CR1
__IO uint32_t CR2
__IO uint32_t FRCR
__IO uint32_t SLOTR
__IO uint32_t IMR
__IO uint32_t SR
__IO uint32_t CLRFR
__IO uint32_t DR
Field Documentation
◆ CLRFR
__IO uint32_t SAI_Block_TypeDef::CLRFR
SAI block x clear flag register, Address offset: 0x1C
◆ CR1
__IO uint32_t SAI_Block_TypeDef::CR1
SAI block x configuration register 1, Address offset: 0x04
◆ CR2
__IO uint32_t SAI_Block_TypeDef::CR2
SAI block x configuration register 2, Address offset: 0x08
◆ DR
__IO uint32_t SAI_Block_TypeDef::DR
SAI block x data register, Address offset: 0x20
◆ FRCR
__IO uint32_t SAI_Block_TypeDef::FRCR
SAI block x frame configuration register, Address offset: 0x0C
◆ IMR
__IO uint32_t SAI_Block_TypeDef::IMR
SAI block x interrupt mask register, Address offset: 0x14
◆ SLOTR
__IO uint32_t SAI_Block_TypeDef::SLOTR
SAI block x slot register, Address offset: 0x10
◆ SR
__IO uint32_t SAI_Block_TypeDef::SR
SAI block x status register, Address offset: 0x18
The documentation for this struct was generated from the following files:
