RTEMS 6.1
uint32_t AudioMode
uint32_t Synchro
uint32_t SynchroExt
uint32_t MckOutput
uint32_t OutputDrive
uint32_t NoDivider
uint32_t FIFOThreshold
uint32_t AudioFrequency
uint32_t Mckdiv
uint32_t MckOverSampling
uint32_t MonoStereoMode
uint32_t CompandingMode
uint32_t TriState
SAI_PdmInitTypeDef PdmInit
uint32_t Protocol
uint32_t DataSize
uint32_t FirstBit
uint32_t ClockStrobing
Field Documentation
◆ AudioFrequency
uint32_t SAI_InitTypeDef::AudioFrequency
Specifies the audio frequency sampling. This parameter can be a value of SAI Audio Frequency
◆ AudioMode
uint32_t SAI_InitTypeDef::AudioMode
Specifies the SAI Block audio Mode. This parameter can be a value of SAI Block Mode
◆ ClockStrobing
uint32_t SAI_InitTypeDef::ClockStrobing
Specifies the SAI Block clock strobing edge sensitivity. This parameter can be a value of SAI Block Clock Strobing
◆ CompandingMode
uint32_t SAI_InitTypeDef::CompandingMode
Specifies the companding mode type. This parameter can be a value of SAI Block Companding Mode
◆ DataSize
uint32_t SAI_InitTypeDef::DataSize
Specifies the SAI Block data size. This parameter can be a value of SAI Block Data Size
◆ FIFOThreshold
uint32_t SAI_InitTypeDef::FIFOThreshold
Specifies SAI Block FIFO threshold. This parameter can be a value of SAI Block Fifo Threshold
◆ FirstBit
uint32_t SAI_InitTypeDef::FirstBit
Specifies whether data transfers start from MSB or LSB bit. This parameter can be a value of SAI Block MSB LSB transmission
◆ Mckdiv
uint32_t SAI_InitTypeDef::Mckdiv
Specifies the master clock divider. This parameter must be a number between Min_Data = 0 and Max_Data = 63.
Note
This parameter is used only if AudioFrequency is set to SAI_AUDIO_FREQUENCY_MCKDIV otherwise it is internally computed.
◆ MckOutput
uint32_t SAI_InitTypeDef::MckOutput
Specifies whether master clock output will be generated or not. This parameter can be a value of SAI Block Master Clock Output
Note
This feature is only available on STM32H7xx Rev.B and above
◆ MckOverSampling
uint32_t SAI_InitTypeDef::MckOverSampling
Specifies the master clock oversampling. This parameter can be a value of SAI Block Master Clock OverSampling
◆ MonoStereoMode
uint32_t SAI_InitTypeDef::MonoStereoMode
Specifies if the mono or stereo mode is selected. This parameter can be a value of SAI Mono Stereo Mode
◆ NoDivider
uint32_t SAI_InitTypeDef::NoDivider
Specifies whether master clock will be divided or not. This parameter can be a value of SAI Block NoDivider
Note
If bit NODIV in the SAI_xCR1 register is cleared, the frame length should be aligned to a number equal to a power of 2, from 8 to 256. If bit NODIV in the SAI_xCR1 register is set, the frame length can take any of the values from 8 to 256.
The NODIV bit is the same as NOMCK bit in STM32H7xx rev.Y
◆ OutputDrive
uint32_t SAI_InitTypeDef::OutputDrive
Specifies when SAI Block outputs are driven. This parameter can be a value of SAI Block Output Drive
Note
This value has to be set before enabling the audio block but after the audio block configuration.
◆ PdmInit
SAI_PdmInitTypeDef SAI_InitTypeDef::PdmInit
Specifies the PDM configuration.
◆ Protocol
uint32_t SAI_InitTypeDef::Protocol
Specifies the SAI Block protocol. This parameter can be a value of SAI Block Protocol
◆ Synchro
uint32_t SAI_InitTypeDef::Synchro
Specifies SAI Block synchronization This parameter can be a value of SAI Block Synchronization
◆ SynchroExt
uint32_t SAI_InitTypeDef::SynchroExt
Specifies SAI external output synchronization, this setup is common for BlockA and BlockB This parameter can be a value of SAI External synchronisation
Note
If both audio blocks of same SAI are used, this parameter has to be set to the same value for each audio block
◆ TriState
uint32_t SAI_InitTypeDef::TriState
Specifies the companding mode type. This parameter can be a value of SAI TRIState Management
