RTEMS 6.1
Data Fields | |
| FunctionalState | Activation |
| uint32_t | MicPairsNbr |
| uint32_t | ClockEnable |
| FunctionalState SAI_PdmInitTypeDef::Activation |
Enable/disable PDM interface
| uint32_t SAI_PdmInitTypeDef::ClockEnable |
Specifies which clock must be enabled. This parameter can be a values combination of SAI PDM Clock Enable
| uint32_t SAI_PdmInitTypeDef::MicPairsNbr |
Specifies the number of microphone pairs used. This parameter must be a number between Min_Data = 1 and Max_Data = 3.
