RTEMS 6.1
I2C_TypeDefInstance
I2C_InitTypeDef Init
uint8_t * pBuffPtr
uint16_t XferSize
__IO uint16_t XferCount
__IO uint32_t XferOptions
__IO uint32_t PreviousState
HAL_StatusTypeDef(* XferISR )(struct __I2C_HandleTypeDef *hi2c, uint32_t ITFlags, uint32_t ITSources)
DMA_HandleTypeDefhdmatx
DMA_HandleTypeDefhdmarx
HAL_LockTypeDef Lock
__IO HAL_I2C_StateTypeDef State
__IO HAL_I2C_ModeTypeDef Mode
__IO uint32_t ErrorCode
__IO uint32_t AddrEventCount
__IO uint32_t Devaddress
__IO uint32_t Memaddress
Field Documentation
◆ AddrEventCount
__IO uint32_t __I2C_HandleTypeDef::AddrEventCount
I2C Address Event counter
◆ Devaddress
__IO uint32_t __I2C_HandleTypeDef::Devaddress
I2C Target device address
◆ ErrorCode
__IO uint32_t __I2C_HandleTypeDef::ErrorCode
I2C Error code
◆ hdmarx
DMA_HandleTypeDef* __I2C_HandleTypeDef::hdmarx
I2C Rx DMA handle parameters
◆ hdmatx
DMA_HandleTypeDef* __I2C_HandleTypeDef::hdmatx
I2C Tx DMA handle parameters
◆ Init
I2C_InitTypeDef __I2C_HandleTypeDef::Init
I2C communication parameters
◆ Instance
I2C_TypeDef* __I2C_HandleTypeDef::Instance
I2C registers base address
◆ Lock
HAL_LockTypeDef __I2C_HandleTypeDef::Lock
I2C locking object
◆ Memaddress
__IO uint32_t __I2C_HandleTypeDef::Memaddress
I2C Target memory address
◆ Mode
__IO HAL_I2C_ModeTypeDef __I2C_HandleTypeDef::Mode
I2C communication mode
◆ pBuffPtr
uint8_t* __I2C_HandleTypeDef::pBuffPtr
Pointer to I2C transfer buffer
◆ PreviousState
__IO uint32_t __I2C_HandleTypeDef::PreviousState
I2C communication Previous state
◆ State
__IO HAL_I2C_StateTypeDef __I2C_HandleTypeDef::State
I2C communication state
◆ XferCount
__IO uint16_t __I2C_HandleTypeDef::XferCount
I2C transfer counter
◆ XferISR
HAL_StatusTypeDef(* __I2C_HandleTypeDef::XferISR) (struct __I2C_HandleTypeDef *hi2c, uint32_t ITFlags, uint32_t ITSources)
I2C transfer IRQ handler function pointer
◆ XferOptions
__IO uint32_t __I2C_HandleTypeDef::XferOptions
I2C sequantial transfer options, this parameter can be a value of I2C Sequential Transfer Options
◆ XferSize
uint16_t __I2C_HandleTypeDef::XferSize
I2C transfer size
