RTEMS 6.1
uint32_t Timing
uint32_t OwnAddress1
uint32_t AddressingMode
uint32_t DualAddressMode
uint32_t OwnAddress2
uint32_t OwnAddress2Masks
uint32_t GeneralCallMode
uint32_t NoStretchMode
Field Documentation
◆ AddressingMode
uint32_t I2C_InitTypeDef::AddressingMode
Specifies if 7-bit or 10-bit addressing mode is selected. This parameter can be a value of I2C Addressing Mode
◆ DualAddressMode
uint32_t I2C_InitTypeDef::DualAddressMode
Specifies if dual addressing mode is selected. This parameter can be a value of I2C Dual Addressing Mode
◆ GeneralCallMode
uint32_t I2C_InitTypeDef::GeneralCallMode
Specifies if general call mode is selected. This parameter can be a value of I2C General Call Addressing Mode
◆ NoStretchMode
uint32_t I2C_InitTypeDef::NoStretchMode
Specifies if nostretch mode is selected. This parameter can be a value of I2C No-Stretch Mode
◆ OwnAddress1
uint32_t I2C_InitTypeDef::OwnAddress1
Specifies the first device own address. This parameter can be a 7-bit or 10-bit address.
◆ OwnAddress2
uint32_t I2C_InitTypeDef::OwnAddress2
Specifies the second device own address if dual addressing mode is selected This parameter can be a 7-bit address.
◆ OwnAddress2Masks
uint32_t I2C_InitTypeDef::OwnAddress2Masks
Specifies the acknowledge mask address second device own address if dual addressing mode is selected. This parameter can be a value of I2C Own Address2 Masks
◆ Timing
uint32_t I2C_InitTypeDef::Timing
Specifies the I2C_TIMINGR_register value. This parameter calculated by referring to I2C initialization section in Reference manual
