RTEMS 6.1
Inter-integrated Circuit Interface. More...
#include <stm32h723xx.h>
__IO uint32_t CR1
__IO uint32_t CR2
__IO uint32_t OAR1
__IO uint32_t OAR2
__IO uint32_t TIMINGR
__IO uint32_t TIMEOUTR
__IO uint32_t ISR
__IO uint32_t ICR
__IO uint32_t PECR
__IO uint32_t RXDR
__IO uint32_t TXDR
Field Documentation
◆ CR1
__IO uint32_t I2C_TypeDef::CR1
I2C Control register 1, Address offset: 0x00
◆ CR2
__IO uint32_t I2C_TypeDef::CR2
I2C Control register 2, Address offset: 0x04
◆ ICR
__IO uint32_t I2C_TypeDef::ICR
I2C Interrupt clear register, Address offset: 0x1C
◆ ISR
__IO uint32_t I2C_TypeDef::ISR
I2C Interrupt and status register, Address offset: 0x18
◆ OAR1
__IO uint32_t I2C_TypeDef::OAR1
I2C Own address 1 register, Address offset: 0x08
◆ OAR2
__IO uint32_t I2C_TypeDef::OAR2
I2C Own address 2 register, Address offset: 0x0C
◆ PECR
__IO uint32_t I2C_TypeDef::PECR
I2C PEC register, Address offset: 0x20
◆ RXDR
__IO uint32_t I2C_TypeDef::RXDR
I2C Receive data register, Address offset: 0x24
◆ TIMEOUTR
__IO uint32_t I2C_TypeDef::TIMEOUTR
I2C Timeout register, Address offset: 0x14
◆ TIMINGR
__IO uint32_t I2C_TypeDef::TIMINGR
I2C Timing register, Address offset: 0x10
◆ TXDR
__IO uint32_t I2C_TypeDef::TXDR
I2C Transmit data register, Address offset: 0x28
The documentation for this struct was generated from the following files:
