HAL Mode structure definition.
More...
- Note
- HAL I2C Mode value coding follow below described bitmap :
b7 (not used)
x : Should be set to 0
b6
0 : None
1 : Memory (HAL I2C communication is in Memory Mode)
b5
0 : None
1 : Slave (HAL I2C communication is in Slave Mode)
b4
0 : None
1 : Master (HAL I2C communication is in Master Mode)
b3-b2-b1-b0 (not used)
xxxx : Should be set to 0000
◆ HAL_I2C_ModeTypeDef
| Enumerator |
| HAL_I2C_MODE_NONE | No I2C communication on going
| HAL_I2C_MODE_MASTER | I2C communication is in Master Mode
| HAL_I2C_MODE_SLAVE | I2C communication is in Slave Mode
| HAL_I2C_MODE_MEM | I2C communication is in Memory Mode
