| #define | HAL_MMC_CARD_IDLE 0x00000000U |
| #define | HAL_MMC_CARD_READY 0x00000001U |
| #define | HAL_MMC_CARD_IDENTIFICATION 0x00000002U |
| #define | HAL_MMC_CARD_STANDBY 0x00000003U |
| #define | HAL_MMC_CARD_TRANSFER 0x00000004U |
| #define | HAL_MMC_CARD_SENDING 0x00000005U |
| #define | HAL_MMC_CARD_RECEIVING 0x00000006U |
| #define | HAL_MMC_CARD_PROGRAMMING 0x00000007U |
| #define | HAL_MMC_CARD_DISCONNECTED 0x00000008U |
| #define | HAL_MMC_CARD_BUSTEST 0x00000009U |
| #define | HAL_MMC_CARD_SLEEP 0x0000000AU |
| #define | HAL_MMC_CARD_ERROR 0x000000FFU |
#define | MMC_InitTypeDef SDMMC_InitTypeDef |
#define | MMC_TypeDef SDMMC_TypeDef |
| #define | MMC_BLOCKSIZE ((uint32_t)512U) |
| #define | HAL_MMC_ERROR_NONE SDMMC_ERROR_NONE |
| #define | HAL_MMC_ERROR_CMD_CRC_FAIL SDMMC_ERROR_CMD_CRC_FAIL |
| #define | HAL_MMC_ERROR_DATA_CRC_FAIL SDMMC_ERROR_DATA_CRC_FAIL |
| #define | HAL_MMC_ERROR_CMD_RSP_TIMEOUT SDMMC_ERROR_CMD_RSP_TIMEOUT |
| #define | HAL_MMC_ERROR_DATA_TIMEOUT SDMMC_ERROR_DATA_TIMEOUT |
| #define | HAL_MMC_ERROR_TX_UNDERRUN SDMMC_ERROR_TX_UNDERRUN |
| #define | HAL_MMC_ERROR_RX_OVERRUN SDMMC_ERROR_RX_OVERRUN |
| #define | HAL_MMC_ERROR_ADDR_MISALIGNED SDMMC_ERROR_ADDR_MISALIGNED |
| #define | HAL_MMC_ERROR_BLOCK_LEN_ERR SDMMC_ERROR_BLOCK_LEN_ERR |
| #define | HAL_MMC_ERROR_ERASE_SEQ_ERR SDMMC_ERROR_ERASE_SEQ_ERR |
| #define | HAL_MMC_ERROR_BAD_ERASE_PARAM SDMMC_ERROR_BAD_ERASE_PARAM |
| #define | HAL_MMC_ERROR_WRITE_PROT_VIOLATION SDMMC_ERROR_WRITE_PROT_VIOLATION |
| #define | HAL_MMC_ERROR_LOCK_UNLOCK_FAILED SDMMC_ERROR_LOCK_UNLOCK_FAILED |
| #define | HAL_MMC_ERROR_COM_CRC_FAILED SDMMC_ERROR_COM_CRC_FAILED |
| #define | HAL_MMC_ERROR_ILLEGAL_CMD SDMMC_ERROR_ILLEGAL_CMD |
| #define | HAL_MMC_ERROR_CARD_ECC_FAILED SDMMC_ERROR_CARD_ECC_FAILED |
| #define | HAL_MMC_ERROR_CC_ERR SDMMC_ERROR_CC_ERR |
| #define | HAL_MMC_ERROR_GENERAL_UNKNOWN_ERR SDMMC_ERROR_GENERAL_UNKNOWN_ERR |
| #define | HAL_MMC_ERROR_STREAM_READ_UNDERRUN SDMMC_ERROR_STREAM_READ_UNDERRUN |
| #define | HAL_MMC_ERROR_STREAM_WRITE_OVERRUN SDMMC_ERROR_STREAM_WRITE_OVERRUN |
| #define | HAL_MMC_ERROR_CID_CSD_OVERWRITE SDMMC_ERROR_CID_CSD_OVERWRITE |
| #define | HAL_MMC_ERROR_WP_ERASE_SKIP SDMMC_ERROR_WP_ERASE_SKIP |
| #define | HAL_MMC_ERROR_CARD_ECC_DISABLED SDMMC_ERROR_CARD_ECC_DISABLED |
| #define | HAL_MMC_ERROR_ERASE_RESET SDMMC_ERROR_ERASE_RESET |
| #define | HAL_MMC_ERROR_AKE_SEQ_ERR SDMMC_ERROR_AKE_SEQ_ERR |
| #define | HAL_MMC_ERROR_INVALID_VOLTRANGE SDMMC_ERROR_INVALID_VOLTRANGE |
| #define | HAL_MMC_ERROR_ADDR_OUT_OF_RANGE SDMMC_ERROR_ADDR_OUT_OF_RANGE |
| #define | HAL_MMC_ERROR_REQUEST_NOT_APPLICABLE SDMMC_ERROR_REQUEST_NOT_APPLICABLE |
| #define | HAL_MMC_ERROR_PARAM SDMMC_ERROR_INVALID_PARAMETER |
| #define | HAL_MMC_ERROR_UNSUPPORTED_FEATURE SDMMC_ERROR_UNSUPPORTED_FEATURE |
| #define | HAL_MMC_ERROR_BUSY SDMMC_ERROR_BUSY |
| #define | HAL_MMC_ERROR_DMA SDMMC_ERROR_DMA |
| #define | HAL_MMC_ERROR_TIMEOUT SDMMC_ERROR_TIMEOUT |
| #define | MMC_CONTEXT_NONE ((uint32_t)0x00000000U) |
| #define | MMC_CONTEXT_READ_SINGLE_BLOCK ((uint32_t)0x00000001U) |
| #define | MMC_CONTEXT_READ_MULTIPLE_BLOCK ((uint32_t)0x00000002U) |
| #define | MMC_CONTEXT_WRITE_SINGLE_BLOCK ((uint32_t)0x00000010U) |
| #define | MMC_CONTEXT_WRITE_MULTIPLE_BLOCK ((uint32_t)0x00000020U) |
| #define | MMC_CONTEXT_IT ((uint32_t)0x00000008U) |
| #define | MMC_CONTEXT_DMA ((uint32_t)0x00000080U) |
| #define | MMC_HIGH_VOLTAGE_RANGE 0x80FF8000U |
| #define | MMC_DUAL_VOLTAGE_RANGE 0x80FF8080U |
| #define | MMC_LOW_VOLTAGE_RANGE 0x80000080U |
| #define | EMMC_HIGH_VOLTAGE_RANGE 0xC0FF8000U |
| #define | EMMC_DUAL_VOLTAGE_RANGE 0xC0FF8080U |
| #define | EMMC_LOW_VOLTAGE_RANGE 0xC0000080U |
#define | MMC_INVALID_VOLTAGE_RANGE 0x0001FF01U |
| #define | MMC_LOW_CAPACITY_CARD ((uint32_t)0x00000000U) |
| #define | MMC_HIGH_CAPACITY_CARD ((uint32_t)0x00000001U) |
| #define | HAL_MMC_ERASE 0x00000000U |
| #define | HAL_MMC_TRIM 0x00000001U |
| #define | HAL_MMC_DISCARD 0x00000003U |
| #define | HAL_MMC_SECURE_ERASE 0x80000000U |
| #define | HAL_MMC_SECURE_TRIM_STEP1 0x80000001U |
| #define | HAL_MMC_SECURE_TRIM_STEP2 0x80008000U |
| #define | IS_MMC_ERASE_TYPE(TYPE) |
| #define | HAL_MMC_SRT_ERASE 0x00000001U |
| #define | HAL_MMC_SRT_WRITE_CHAR_ERASE 0x00000002U |
| #define | HAL_MMC_SRT_WRITE_CHAR_COMPL_RANDOM 0x00000004U |
| #define | HAL_MMC_SRT_VENDOR_DEFINED 0x00000008U |
| #define | IS_MMC_SRT_TYPE(TYPE) |
| #define | __HAL_MMC_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_MMC_STATE_RESET) |
| | Reset MMC handle state.
| #define | __HAL_MMC_ENABLE_IT(__HANDLE__, __INTERRUPT__) __SDMMC_ENABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Enable the MMC device interrupt.
| #define | __HAL_MMC_DISABLE_IT(__HANDLE__, __INTERRUPT__) __SDMMC_DISABLE_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Disable the MMC device interrupt.
| #define | __HAL_MMC_GET_FLAG(__HANDLE__, __FLAG__) __SDMMC_GET_FLAG((__HANDLE__)->Instance, (__FLAG__)) |
| | Check whether the specified MMC flag is set or not.
| #define | __HAL_MMC_CLEAR_FLAG(__HANDLE__, __FLAG__) __SDMMC_CLEAR_FLAG((__HANDLE__)->Instance, (__FLAG__)) |
| | Clear the MMC's pending flags.
| #define | __HAL_MMC_GET_IT(__HANDLE__, __INTERRUPT__) __SDMMC_GET_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Check whether the specified MMC interrupt has occurred or not.
| #define | __HAL_MMC_CLEAR_IT(__HANDLE__, __INTERRUPT__) __SDMMC_CLEAR_IT((__HANDLE__)->Instance, (__INTERRUPT__)) |
| | Clear the MMC's interrupt pending bits.
#define | MMC_EXT_CSD_DATA_SEC_SIZE_INDEX 61 |
#define | MMC_EXT_CSD_DATA_SEC_SIZE_POS 8 |
HAL_StatusTypeDef | HAL_MMC_Init (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_InitCard (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_DeInit (MMC_HandleTypeDef *hmmc) |
void | HAL_MMC_MspInit (MMC_HandleTypeDef *hmmc) |
void | HAL_MMC_MspDeInit (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_ReadBlocks (MMC_HandleTypeDef *hmmc, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_MMC_WriteBlocks (MMC_HandleTypeDef *hmmc, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_MMC_Erase (MMC_HandleTypeDef *hmmc, uint32_t BlockStartAdd, uint32_t BlockEndAdd) |
HAL_StatusTypeDef | HAL_MMC_ReadBlocks_IT (MMC_HandleTypeDef *hmmc, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_MMC_WriteBlocks_IT (MMC_HandleTypeDef *hmmc, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_MMC_ReadBlocks_DMA (MMC_HandleTypeDef *hmmc, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_MMC_WriteBlocks_DMA (MMC_HandleTypeDef *hmmc, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
void | HAL_MMC_IRQHandler (MMC_HandleTypeDef *hmmc) |
void | HAL_MMC_TxCpltCallback (MMC_HandleTypeDef *hmmc) |
void | HAL_MMC_RxCpltCallback (MMC_HandleTypeDef *hmmc) |
void | HAL_MMC_ErrorCallback (MMC_HandleTypeDef *hmmc) |
void | HAL_MMC_AbortCallback (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_ConfigWideBusOperation (MMC_HandleTypeDef *hmmc, uint32_t WideMode) |
HAL_StatusTypeDef | HAL_MMC_ConfigSpeedBusOperation (MMC_HandleTypeDef *hmmc, uint32_t SpeedMode) |
HAL_MMC_CardStateTypeDef | HAL_MMC_GetCardState (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_GetCardCID (MMC_HandleTypeDef *hmmc, HAL_MMC_CardCIDTypeDef *pCID) |
HAL_StatusTypeDef | HAL_MMC_GetCardCSD (MMC_HandleTypeDef *hmmc, HAL_MMC_CardCSDTypeDef *pCSD) |
HAL_StatusTypeDef | HAL_MMC_GetCardInfo (MMC_HandleTypeDef *hmmc, HAL_MMC_CardInfoTypeDef *pCardInfo) |
HAL_StatusTypeDef | HAL_MMC_GetCardExtCSD (MMC_HandleTypeDef *hmmc, uint32_t *pExtCSD, uint32_t Timeout) |
HAL_MMC_StateTypeDef | HAL_MMC_GetState (MMC_HandleTypeDef *hmmc) |
uint32_t | HAL_MMC_GetError (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_Abort (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_Abort_IT (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_EraseSequence (MMC_HandleTypeDef *hmmc, uint32_t EraseType, uint32_t BlockStartAdd, uint32_t BlockEndAdd) |
HAL_StatusTypeDef | HAL_MMC_Sanitize (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_ConfigSecRemovalType (MMC_HandleTypeDef *hmmc, uint32_t SRTMode) |
HAL_StatusTypeDef | HAL_MMC_GetSupportedSecRemovalType (MMC_HandleTypeDef *hmmc, uint32_t *SupportedSRT) |
HAL_StatusTypeDef | HAL_MMC_SleepDevice (MMC_HandleTypeDef *hmmc) |
HAL_StatusTypeDef | HAL_MMC_AwakeDevice (MMC_HandleTypeDef *hmmc) |
Header file of MMC HAL module.
- Author
- MCD Application Team
- Attention
