RTEMS 6.1
__IO uint8_t CSDStruct
__IO uint8_t SysSpecVersion
__IO uint8_t Reserved1
__IO uint8_t TAAC
__IO uint8_t NSAC
__IO uint8_t MaxBusClkFrec
__IO uint16_t CardComdClasses
__IO uint8_t RdBlockLen
__IO uint8_t PartBlockRead
__IO uint8_t WrBlockMisalign
__IO uint8_t RdBlockMisalign
__IO uint8_t DSRImpl
__IO uint8_t Reserved2
__IO uint32_t DeviceSize
__IO uint8_t MaxRdCurrentVDDMin
__IO uint8_t MaxRdCurrentVDDMax
__IO uint8_t MaxWrCurrentVDDMin
__IO uint8_t MaxWrCurrentVDDMax
__IO uint8_t DeviceSizeMul
__IO uint8_t EraseGrSize
__IO uint8_t EraseGrMul
__IO uint8_t WrProtectGrSize
__IO uint8_t WrProtectGrEnable
__IO uint8_t ManDeflECC
__IO uint8_t WrSpeedFact
__IO uint8_t MaxWrBlockLen
__IO uint8_t WriteBlockPaPartial
__IO uint8_t Reserved3
__IO uint8_t ContentProtectAppli
__IO uint8_t FileFormatGroup
__IO uint8_t CopyFlag
__IO uint8_t PermWrProtect
__IO uint8_t TempWrProtect
__IO uint8_t ECC
__IO uint8_t CSD_CRC
__IO uint8_t Reserved4
Field Documentation
◆ CardComdClasses
__IO uint16_t HAL_MMC_CardCSDTypeDef::CardComdClasses
Card command classes
◆ ContentProtectAppli
__IO uint8_t HAL_MMC_CardCSDTypeDef::ContentProtectAppli
Content protection application
◆ CopyFlag
__IO uint8_t HAL_MMC_CardCSDTypeDef::CopyFlag
Copy flag (OTP)
◆ CSD_CRC
__IO uint8_t HAL_MMC_CardCSDTypeDef::CSD_CRC
CSD CRC
◆ CSDStruct
__IO uint8_t HAL_MMC_CardCSDTypeDef::CSDStruct
CSD structure
◆ DeviceSize
__IO uint32_t HAL_MMC_CardCSDTypeDef::DeviceSize
Device Size
◆ DeviceSizeMul
__IO uint8_t HAL_MMC_CardCSDTypeDef::DeviceSizeMul
Device size multiplier
◆ DSRImpl
__IO uint8_t HAL_MMC_CardCSDTypeDef::DSRImpl
DSR implemented
◆ ECC
__IO uint8_t HAL_MMC_CardCSDTypeDef::ECC
ECC code
◆ EraseGrMul
__IO uint8_t HAL_MMC_CardCSDTypeDef::EraseGrMul
Erase group size multiplier
◆ EraseGrSize
__IO uint8_t HAL_MMC_CardCSDTypeDef::EraseGrSize
Erase group size
◆ FileFormat
__IO uint8_t HAL_MMC_CardCSDTypeDef::FileFormat
File format
◆ FileFormatGroup
__IO uint8_t HAL_MMC_CardCSDTypeDef::FileFormatGroup
File format group
◆ ManDeflECC
__IO uint8_t HAL_MMC_CardCSDTypeDef::ManDeflECC
Manufacturer default ECC
◆ MaxBusClkFrec
__IO uint8_t HAL_MMC_CardCSDTypeDef::MaxBusClkFrec
Max. bus clock frequency
◆ MaxRdCurrentVDDMax
__IO uint8_t HAL_MMC_CardCSDTypeDef::MaxRdCurrentVDDMax
Max. read current @ VDD max
◆ MaxRdCurrentVDDMin
__IO uint8_t HAL_MMC_CardCSDTypeDef::MaxRdCurrentVDDMin
Max. read current @ VDD min
◆ MaxWrBlockLen
__IO uint8_t HAL_MMC_CardCSDTypeDef::MaxWrBlockLen
Max. write data block length
◆ MaxWrCurrentVDDMax
__IO uint8_t HAL_MMC_CardCSDTypeDef::MaxWrCurrentVDDMax
Max. write current @ VDD max
◆ MaxWrCurrentVDDMin
__IO uint8_t HAL_MMC_CardCSDTypeDef::MaxWrCurrentVDDMin
Max. write current @ VDD min
◆ NSAC
__IO uint8_t HAL_MMC_CardCSDTypeDef::NSAC
Data read access time 2 in CLK cycles
◆ PartBlockRead
__IO uint8_t HAL_MMC_CardCSDTypeDef::PartBlockRead
Partial blocks for read allowed
◆ PermWrProtect
__IO uint8_t HAL_MMC_CardCSDTypeDef::PermWrProtect
Permanent write protection
◆ RdBlockLen
__IO uint8_t HAL_MMC_CardCSDTypeDef::RdBlockLen
Max. read data block length
◆ RdBlockMisalign
__IO uint8_t HAL_MMC_CardCSDTypeDef::RdBlockMisalign
Read block misalignment
◆ Reserved1
__IO uint8_t HAL_MMC_CardCSDTypeDef::Reserved1
Reserved
◆ Reserved2
__IO uint8_t HAL_MMC_CardCSDTypeDef::Reserved2
Reserved
◆ Reserved3
__IO uint8_t HAL_MMC_CardCSDTypeDef::Reserved3
Reserved
◆ Reserved4
__IO uint8_t HAL_MMC_CardCSDTypeDef::Reserved4
Always 1
◆ SysSpecVersion
__IO uint8_t HAL_MMC_CardCSDTypeDef::SysSpecVersion
System specification version
◆ TAAC
__IO uint8_t HAL_MMC_CardCSDTypeDef::TAAC
Data read access time 1
◆ TempWrProtect
__IO uint8_t HAL_MMC_CardCSDTypeDef::TempWrProtect
Temporary write protection
◆ WrBlockMisalign
__IO uint8_t HAL_MMC_CardCSDTypeDef::WrBlockMisalign
Write block misalignment
◆ WriteBlockPaPartial
__IO uint8_t HAL_MMC_CardCSDTypeDef::WriteBlockPaPartial
Partial blocks for write allowed
◆ WrProtectGrEnable
__IO uint8_t HAL_MMC_CardCSDTypeDef::WrProtectGrEnable
Write protect group enable
◆ WrProtectGrSize
__IO uint8_t HAL_MMC_CardCSDTypeDef::WrProtectGrSize
Write protect group size
◆ WrSpeedFact
__IO uint8_t HAL_MMC_CardCSDTypeDef::WrSpeedFact
Write speed factor
