RTEMS 6.1
timer.h
2
11/*
12 * Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/timer/if/header */
55
56#ifndef _RTEMS_RTEMS_TIMER_H
57#define _RTEMS_RTEMS_TIMER_H
58
59#include <stddef.h>
60#include <rtems/rtems/attr.h>
61#include <rtems/rtems/status.h>
62#include <rtems/rtems/types.h>
64
65#ifdef __cplusplus
66extern "C" {
67#endif
68
69/* Generated from spec:/rtems/timer/if/group */
70
79/* Generated from spec:/rtems/timer/if/class-bit-not-dormant */
80
86#define TIMER_CLASS_BIT_NOT_DORMANT 0x4
87
88/* Generated from spec:/rtems/timer/if/class-bit-on-task */
89
96#define TIMER_CLASS_BIT_ON_TASK 0x2
97
98/* Generated from spec:/rtems/timer/if/class-bit-time-of-day */
99
105#define TIMER_CLASS_BIT_TIME_OF_DAY 0x1
106
107/* Generated from spec:/rtems/timer/if/classes */
108
114typedef enum {
119
125
132
139
148
149/* Generated from spec:/rtems/timer/if/information */
150
156typedef struct {
162
167
175
184
185/* Generated from spec:/rtems/timer/if/get-information */
186
222 rtems_id id,
224);
225
226/* Generated from spec:/rtems/timer/if/server-default-priority */
227
237#define RTEMS_TIMER_SERVER_DEFAULT_PRIORITY ( (rtems_task_priority) -1 )
238
239/* Generated from spec:/rtems/timer/if/service-routine */
240
250
251/* Generated from spec:/rtems/timer/if/service-routine-entry */
252
260
261/* Generated from spec:/rtems/timer/if/create */
262
320
321/* Generated from spec:/rtems/timer/if/ident */
322
369
370/* Generated from spec:/rtems/timer/if/cancel */
371
405
406/* Generated from spec:/rtems/timer/if/delete */
407
446
447/* Generated from spec:/rtems/timer/if/fire-after */
448
493 rtems_id id,
494 rtems_interval ticks,
496 void *user_data
497);
498
499/* Generated from spec:/rtems/timer/if/fire-when */
500
548 rtems_id id,
549 const rtems_time_of_day *wall_time,
551 void *user_data
552);
553
554/* Generated from spec:/rtems/timer/if/initiate-server */
555
612 rtems_task_priority priority,
613 size_t stack_size,
614 rtems_attribute attribute_set
615);
616
617/* Generated from spec:/rtems/timer/if/server-fire-after */
618
665 rtems_id id,
666 rtems_interval ticks,
668 void *user_data
669);
670
671/* Generated from spec:/rtems/timer/if/server-fire-when */
672
722 rtems_id id,
723 const rtems_time_of_day *wall_time,
725 void *user_data
726);
727
728/* Generated from spec:/rtems/timer/if/reset */
729
776
777#ifdef __cplusplus
778}
779#endif
780
781#endif /* _RTEMS_RTEMS_TIMER_H */
This header file provides Classic API directive attributes.
This header file provides types used by the Classic API.
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition: attr.h:96
rtems_status_code
Definition: status.h:85
rtems_status_code rtems_timer_reset(rtems_id id)
Resets the timer.
Definition: timerreset.c:44
rtems_timer_service_routine(* rtems_timer_service_routine_entry)(rtems_id, void *)
This type defines the prototype of routines which can be fired by directives of the Timer Manager.
Definition: timer.h:259
rtems_status_code rtems_timer_server_fire_after(rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
Fires the timer after the interval using the Timer Server.
Definition: timerserverfireafter.c:44
rtems_status_code rtems_timer_create(rtems_name name, rtems_id *id)
Creates a timer.
Definition: timercreate.c:212
rtems_status_code rtems_timer_delete(rtems_id id)
Deletes the timer.
Definition: timerdelete.c:44
This timer class bit indicates that the timer is not dormant.
Definition: timer.h:86
rtems_status_code rtems_timer_server_fire_when(rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
Fires the timer at the time of day using the Timer Server.
Definition: timerserverfirewhen.c:44
rtems_status_code rtems_timer_cancel(rtems_id id)
Cancels the timer.
Definition: timercancel.c:44
rtems_status_code rtems_timer_fire_when(rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
Fires the timer at the time of day.
Definition: timerfirewhen.c:44
rtems_status_code rtems_timer_ident(rtems_name name, rtems_id *id)
Identifies a timer by the object name.
Definition: timerident.c:45
rtems_status_code rtems_timer_initiate_server(rtems_task_priority priority, size_t stack_size, rtems_attribute attribute_set)
Initiates the Timer Server.
Definition: timerserver.c:239
void rtems_timer_service_routine
This type defines the return type of routines which can be fired by directives of the Timer Manager.
Definition: timer.h:249
rtems_status_code rtems_timer_get_information(rtems_id id, rtems_timer_information *the_info)
Gets information about the timer.
Definition: timergetinfo.c:44
Timer_Classes
The timer class indicates how the timer was most recently fired.
Definition: timer.h:114
This timer class bit indicates that the timer uses a time of day.
Definition: timer.h:105
rtems_status_code rtems_timer_fire_after(rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
Fires the timer after the interval.
Definition: timerfireafter.c:44
This timer class bit indicates that the timer routine executes in a task context.
Definition: timer.h:96
@ TIMER_TIME_OF_DAY
This timer class indicates that the timer is currently in use as an time of day timer which will fire...
Definition: timer.h:137
@ TIMER_TIME_OF_DAY_ON_TASK
Definition: timer.h:144
@ TIMER_INTERVAL
This timer class indicates that the timer is currently in use as an interval timer which will fire in...
Definition: timer.h:124
@ TIMER_INTERVAL_ON_TASK
Definition: timer.h:130
@ TIMER_DORMANT
This timer class indicates that the timer was never in use.
Definition: timer.h:118
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition: types.h:257
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition: types.h:114
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdogticks.h:59
This header file provides the status codes of Classic API directives and support functions.
This type represents Classic API calendar times.
Definition: types.h:266
The structure contains information about a timer.
Definition: timer.h:156
Watchdog_Interval stop_time
This member indicates the time the timer was scheduled to fire.
Definition: timer.h:182
Timer_Classes the_class
The timer class member indicates how the timer was most recently fired.
Definition: timer.h:161
Watchdog_Interval initial
This member indicates the initial requested interval.
Definition: timer.h:166
Watchdog_Interval start_time
This member indicates the time the timer was initially scheduled.
Definition: timer.h:174
This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are ...
