RTEMS 6.1
This header file provides the status codes of Classic API directives and support functions. More...
#include <stdbool.h>Go to the source code of this file.
| #define | RTEMS_STATUS_CODES_FIRST RTEMS_SUCCESSFUL |
| This constant represents the lowest valid value for a Classic API directive status code. | |
| #define | RTEMS_STATUS_CODES_LAST RTEMS_PROXY_BLOCKING |
| This constant represents the highest valid value for a Classic API directive status code. | |
Enumerations | |
| enum | rtems_status_code { RTEMS_SUCCESSFUL = 0 , RTEMS_TASK_EXITTED = 1 , RTEMS_MP_NOT_CONFIGURED = 2 , RTEMS_INVALID_NAME = 3 , RTEMS_INVALID_ID = 4 , RTEMS_TOO_MANY = 5 , RTEMS_TIMEOUT = 6 , RTEMS_OBJECT_WAS_DELETED = 7 , RTEMS_INVALID_SIZE = 8 , RTEMS_INVALID_ADDRESS = 9 , RTEMS_INVALID_NUMBER = 10 , RTEMS_NOT_DEFINED = 11 , RTEMS_RESOURCE_IN_USE = 12 , RTEMS_UNSATISFIED = 13 , RTEMS_INCORRECT_STATE = 14 , RTEMS_ALREADY_SUSPENDED = 15 , RTEMS_ILLEGAL_ON_SELF = 16 , RTEMS_ILLEGAL_ON_REMOTE_OBJECT = 17 , RTEMS_CALLED_FROM_ISR = 18 , RTEMS_INVALID_PRIORITY = 19 , RTEMS_INVALID_CLOCK = 20 , RTEMS_INVALID_NODE = 21 , RTEMS_NOT_CONFIGURED = 22 , RTEMS_NOT_OWNER_OF_RESOURCE = 23 , RTEMS_NOT_IMPLEMENTED = 24 , RTEMS_INTERNAL_ERROR = 25 , RTEMS_NO_MEMORY = 26 , RTEMS_IO_ERROR = 27 , RTEMS_INTERRUPTED = 28 , RTEMS_PROXY_BLOCKING = 29 } |
| This enumeration provides status codes for directives of the Classic API. More... | |
| int | rtems_status_code_to_errno (rtems_status_code status_code) |
| Maps the RTEMS status code to a POSIX error number. | |
| const char * | rtems_status_text (rtems_status_code status_code) |
| Maps the status code to a descriptive text. | |
