RTEMS 6.1
Data Structures | Macros | Typedefs | Enumerations | Functions
timer.h File Reference
This header file provides the Timer Manager API. More...
#include <stddef.h>
#include <rtems/rtems/attr.h>
#include <rtems/score/watchdogticks.h>
struct  rtems_timer_information
 The structure contains information about a timer. More...
#define TIMER_CLASS_BIT_NOT_DORMANT   0x4
 This timer class bit indicates that the timer is not dormant.
#define TIMER_CLASS_BIT_ON_TASK   0x2
 This timer class bit indicates that the timer routine executes in a task context.
#define TIMER_CLASS_BIT_TIME_OF_DAY   0x1
 This timer class bit indicates that the timer uses a time of day.
#define RTEMS_TIMER_SERVER_DEFAULT_PRIORITY   ( (rtems_task_priority) -1 )
 This constant represents the default value for the task priority of the Timer Server.
typedef void rtems_timer_service_routine
 This type defines the return type of routines which can be fired by directives of the Timer Manager.
typedef rtems_timer_service_routine(* rtems_timer_service_routine_entry) (rtems_id, void *)
 This type defines the prototype of routines which can be fired by directives of the Timer Manager.
enum  Timer_Classes {
  TIMER_DORMANT , TIMER_INTERVAL = TIMER_CLASS_BIT_NOT_DORMANT , TIMER_INTERVAL_ON_TASK , TIMER_TIME_OF_DAY ,
  TIMER_TIME_OF_DAY_ON_TASK
 The timer class indicates how the timer was most recently fired. More...
rtems_status_code rtems_timer_get_information (rtems_id id, rtems_timer_information *the_info)
 Gets information about the timer.
rtems_status_code rtems_timer_create (rtems_name name, rtems_id *id)
 Creates a timer.
rtems_status_code rtems_timer_ident (rtems_name name, rtems_id *id)
 Identifies a timer by the object name.
rtems_status_code rtems_timer_cancel (rtems_id id)
 Cancels the timer.
rtems_status_code rtems_timer_delete (rtems_id id)
 Deletes the timer.
rtems_status_code rtems_timer_fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
 Fires the timer after the interval.
rtems_status_code rtems_timer_fire_when (rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
 Fires the timer at the time of day.
rtems_status_code rtems_timer_initiate_server (rtems_task_priority priority, size_t stack_size, rtems_attribute attribute_set)
 Initiates the Timer Server.
rtems_status_code rtems_timer_server_fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
 Fires the timer after the interval using the Timer Server.
rtems_status_code rtems_timer_server_fire_when (rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
 Fires the timer at the time of day using the Timer Server.
rtems_status_code rtems_timer_reset (rtems_id id)
 Resets the timer.
