RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions
Enable the Monitor to Show bdbuf Information. More...
#include <rtems/monitor.h>
#include <rtems/bdbuf.h>
#include <ctype.h>
#include <rtems/libio.h>
#include <inttypes.h>
struct  show_bdbuf_filter_t
struct  show_bdbuf_selector_t
struct  show_bdbuf_bdbuf_info_t
#define DISABLE_PREEMPTION(key)
#define ENABLE_PREEMPTION(key)
#define ARRAY_CNT(arr)   (sizeof((arr))/sizeof((arr)[0]))
typedef rtems_mode preemption_key_t
enum  bdbuf_chain_identifier_t { bdbuf_chain_ident_none , bdbuf_chain_ident_free , bdbuf_chain_ident_lru , bdbuf_chain_ident_mod }
rtems_status_code rtems_bdbuf_show_follow_chain_node_to_head (const Chain_Node *the_node, Chain_Control **the_head)
rtems_status_code rtems_bdbuf_show_determine_chain_of_bdbuf (const bdbuf_buffer *the_bdbuf, const bdbuf_pool *curr_pool, bdbuf_chain_identifier_t *chn_ident)
rtems_status_code rtems_bdbuf_show_getargs (int argc, char **argv, show_bdbuf_filter_t *filter, show_bdbuf_selector_t *selector)
rtems_status_code rtems_bdbuf_show_get_bufpool (struct bdbuf_pool **pool_base_pptr, int *pool_cnt_ptr)
rtems_status_code rtems_bdbuf_show_pool_header (int pool_idx, bdbuf_pool *pool_ptr)
rtems_status_code rtems_show_bdbuf_get_bdbuf_info (const bdbuf_buffer *the_bdbuf, int bdbuf_idx, const bdbuf_pool *curr_pool, show_bdbuf_bdbuf_info_t *bdbuf_info)
rtems_status_code rtems_show_bdbuf_match_filter (const show_bdbuf_bdbuf_info_t *bdbuf_info, const show_bdbuf_filter_t *filter, bool *is_match)
rtems_status_code rtems_show_bdbuf_print_wait_chain (bdbuf_buffer *the_bdbuf)
rtems_status_code rtems_show_bdbuf_print (const show_bdbuf_bdbuf_info_t *bdbuf_info, show_bdbuf_selector_t *selector, bool print_header)
void rtems_bdbuf_show_fnc (int argc, char **argv, rtems_monitor_command_arg_t *command_arg, bool verbose)
rtems_status_code rtems_bdbuf_show_init (void)
This module inspects the bdbuf data structures, assuming they are static, but in fact they are used very dynamically. Therefore the results show MAY BE INCORRECT in some cases. And, to cure this a bit, this module may block preemption for a rather long time and therefore it may BREAK THE REALTIME BEHAVIOUR OF YOUR SYSTEM (when in use)
◆ DISABLE_PREEMPTION
#define DISABLE_PREEMPTION (   key)
Value:
do { \
rtems_task_mode(RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &(key)); \
} while (0)
#define RTEMS_NO_PREEMPT
Definition: modes.h:75
#define RTEMS_PREEMPT_MASK
Definition: modes.h:64
◆ ENABLE_PREEMPTION
#define ENABLE_PREEMPTION (   key)
Value:
do { \
rtems_mode temp; \
rtems_task_mode((key), RTEMS_PREEMPT_MASK, &temp); \
} while (0)
