RTEMS 5.2
libio.h
1
13/*
14 * COPYRIGHT (c) 1989-2008.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * Modifications to support reference counting in the file system are
18 * Copyright (c) 2012 embedded brains GmbH.
19 *
20 * The license and distribution terms for this file may be
21 * found in the file LICENSE in this distribution or at
22 * http://www.rtems.org/license/LICENSE.
23 */
24
25#ifndef _RTEMS_RTEMS_LIBIO_H
26#define _RTEMS_RTEMS_LIBIO_H
27
28#include <sys/types.h>
29#include <sys/stat.h>
30#include <sys/ioccom.h>
31#include <sys/statvfs.h>
32#include <sys/uio.h>
33
34#include <unistd.h>
35#include <termios.h>
36
37#include <rtems.h>
38#include <rtems/fs.h>
39#include <rtems/chain.h>
40#include <rtems/score/atomic.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
46struct knote;
47
68);
69
79);
80
84typedef struct {
88 const char *path;
89
93 size_t pathlen;
94
99 const char *token;
100
105 size_t tokenlen;
106
119 int flags;
120
127
136
142
149
159);
160
175 const rtems_filesystem_location_info_t *parentloc,
176 const rtems_filesystem_location_info_t *targetloc,
177 const char *name,
178 size_t namelen
179);
180
194 mode_t mode
195);
196
211 uid_t owner,
212 gid_t group
213);
214
232);
233
243);
244
263);
264
279 const void *data
280);
281
298);
299
313);
314
332);
333
351 const rtems_filesystem_location_info_t *parentloc,
352 const char *name,
353 size_t namelen,
354 mode_t mode,
355 dev_t dev
356);
357
370 const rtems_filesystem_location_info_t *parentloc,
372);
373
388 time_t actime,
389 time_t modtime
390);
391
407 const rtems_filesystem_location_info_t *parentloc,
408 const char *name,
409 size_t namelen,
410 const char *target
411);
412
427 char *buf,
428 size_t bufsize
429);
430
446 const rtems_filesystem_location_info_t *oldparentloc,
448 const rtems_filesystem_location_info_t *newparentloc,
449 const char *name,
450 size_t namelen
451);
452
466 struct statvfs *buf
467);
468
477 rtems_filesystem_are_nodes_equal_t are_nodes_equal_h;
486 rtems_filesystem_fsunmount_me_t fsunmount_me_h;
492};
493
499
507);
508
516);
517
526);
527
534 const rtems_filesystem_location_info_t *parentloc,
535 const rtems_filesystem_location_info_t *targetloc,
536 const char *name,
537 size_t namelen
538);
539
555);
556
563 const rtems_filesystem_location_info_t *parentloc,
564 const char *name,
565 size_t namelen,
566 mode_t mode,
567 dev_t dev
568);
569
576 const rtems_filesystem_location_info_t *parentloc,
578);
579
587 mode_t mode
588);
589
597 uid_t owner,
598 gid_t group
599);
600
608);
609
615);
616
623 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
624);
625
632 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
633);
634
641 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
642);
643
651 time_t actime,
652 time_t modtime
653);
654
661 const rtems_filesystem_location_info_t *parentloc,
662 const char *name,
663 size_t namelen,
664 const char *target
665);
666
674 char *buf,
675 size_t bufsize
676);
677
684 const rtems_filesystem_location_info_t *oldparentloc,
686 const rtems_filesystem_location_info_t *newparentloc,
687 const char *name,
688 size_t namelen
689);
690
698 struct statvfs *buf
699);
700
726 rtems_libio_t *iop,
727 const char *path,
728 int oflag,
729 mode_t mode
730);
731
743 rtems_libio_t *iop
744);
745
760typedef ssize_t (*rtems_filesystem_read_t)(
761 rtems_libio_t *iop,
762 void *buffer,
763 size_t count
764);
765
782typedef ssize_t (*rtems_filesystem_readv_t)(
783 rtems_libio_t *iop,
784 const struct iovec *iov,
785 int iovcnt,
786 ssize_t total
787);
788
803typedef ssize_t (*rtems_filesystem_write_t)(
804 rtems_libio_t *iop,
805 const void *buffer,
806 size_t count
807);
808
825typedef ssize_t (*rtems_filesystem_writev_t)(
826 rtems_libio_t *iop,
827 const struct iovec *iov,
828 int iovcnt,
829 ssize_t total
830);
831
845 rtems_libio_t *iop,
846 ioctl_command_t request,
847 void *buffer
848);
849
865 rtems_libio_t *iop,
866 off_t offset,
867 int whence
868);
869
883 struct stat *buf
884);
885
899 rtems_libio_t *iop,
900 off_t length
901);
902
915 rtems_libio_t *iop
916);
917
930 rtems_libio_t *iop
931);
932
945 rtems_libio_t *iop,
946 int cmd
947);
948
960 rtems_libio_t *iop,
961 int events
962);
963
976 rtems_libio_t *iop,
977 struct knote *kn
978);
979
995 rtems_libio_t *iop,
996 void **addr,
997 size_t len,
998 int prot,
999 off_t off
1000);
1001
1013 rtems_filesystem_ftruncate_t ftruncate_h;
1015 rtems_filesystem_fdatasync_t fdatasync_h;
1018 rtems_filesystem_kqfilter_t kqfilter_h;
1022};
1023
1029
1036 rtems_libio_t *iop,
1037 const char *path,
1038 int oflag,
1039 mode_t mode
1040);
1041
1048 rtems_libio_t *iop
1049);
1050
1057 rtems_libio_t *iop,
1058 void *buffer,
1059 size_t count
1060);
1061
1068 rtems_libio_t *iop,
1069 const struct iovec *iov,
1070 int iovcnt,
1071 ssize_t total
1072);
1073
1080 rtems_libio_t *iop,
1081 const void *buffer,
1082 size_t count
1083);
1084
1091 rtems_libio_t *iop,
1092 const struct iovec *iov,
1093 int iovcnt,
1094 ssize_t total
1095);
1096
1103 rtems_libio_t *iop,
1104 ioctl_command_t request,
1105 void *buffer
1106);
1107
1114 rtems_libio_t *iop,
1115 off_t offset,
1116 int whence
1117);
1118
1131 rtems_libio_t *iop,
1132 off_t offset,
1133 int whence
1134);
1135
1154 rtems_libio_t *iop,
1155 off_t offset,
1156 int whence
1157);
1158
1168 struct stat *buf
1169);
1170
1177 rtems_libio_t *iop,
1178 off_t length
1179);
1180
1187 rtems_libio_t *iop,
1188 off_t length
1189);
1190
1197 rtems_libio_t *iop
1198);
1199
1206 rtems_libio_t *iop
1207);
1208
1215 rtems_libio_t *iop,
1216 int cmd
1217);
1218
1227 rtems_libio_t *iop,
1228 int events
1229);
1230
1239 rtems_libio_t *iop,
1240 struct knote *kn
1241);
1242
1251 rtems_libio_t *iop,
1252 void **addr,
1253 size_t len,
1254 int prot,
1255 off_t off
1256);
1257
1272typedef off_t rtems_off64_t __attribute__((deprecated));
1273
1282 const char *type
1283);
1284
1289typedef struct {
1290 int link_max; /* count */
1291 int max_canon; /* max formatted input line size */
1292 int max_input; /* max input line size */
1293 int name_max; /* max name length */
1294 int path_max; /* max path */
1295 int pipe_buf; /* pipe buffer size */
1296 int posix_async_io; /* async IO supported on fs, 0=no, 1=yes */
1297 int posix_chown_restrictions; /* can chown: 0=no, 1=yes */
1298 int posix_no_trunc; /* error on names > max name, 0=no, 1=yes */
1299 int posix_prio_io; /* priority IO, 0=no, 1=yes */
1300 int posix_sync_io; /* file can be sync'ed, 0=no, 1=yes */
1301 int posix_vdisable; /* special char processing, 0=no, 1=yes */
1303
1311
1321 Atomic_Uint flags;
1322 off_t offset; /* current offset into file */
1324 uint32_t data0; /* private to "driver" */
1325 void *data1; /* ... */
1326};
1327
1334typedef struct {
1335 rtems_libio_t *iop;
1336 off_t offset;
1337 char *buffer;
1338 uint32_t count;
1339 uint32_t flags;
1340 uint32_t bytes_moved;
1342
1346typedef struct {
1347 rtems_libio_t *iop;
1348 uint32_t flags;
1349 uint32_t mode;
1351
1355typedef struct {
1356 rtems_libio_t *iop;
1357 ioctl_command_t command;
1358 void *buffer;
1359 int ioctl_return;
1361
1367#define LIBIO_FLAGS_NO_DELAY 0x0001U /* return immediately if no data */
1368#define LIBIO_FLAGS_READ 0x0002U /* reading */
1369#define LIBIO_FLAGS_WRITE 0x0004U /* writing */
1370#define LIBIO_FLAGS_OPEN 0x0100U /* device is open */
1371#define LIBIO_FLAGS_APPEND 0x0200U /* all writes append */
1372#define LIBIO_FLAGS_CLOSE_ON_EXEC 0x0800U /* close on process exec() */
1373#define LIBIO_FLAGS_READ_WRITE (LIBIO_FLAGS_READ | LIBIO_FLAGS_WRITE)
1374#define LIBIO_FLAGS_REFERENCE_INC 0x1000U
1375
1378static inline unsigned int rtems_libio_iop_flags( const rtems_libio_t *iop )
1379{
1380 return _Atomic_Load_uint( &iop->flags, ATOMIC_ORDER_RELAXED );
1381}
1382
1388static inline bool rtems_libio_iop_is_no_delay( const rtems_libio_t *iop )
1389{
1390 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_NO_DELAY ) != 0;
1391}
1392
1398static inline bool rtems_libio_iop_is_readable( const rtems_libio_t *iop )
1399{
1400 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_READ ) != 0;
1401}
1402
1408static inline bool rtems_libio_iop_is_writeable( const rtems_libio_t *iop )
1409{
1410 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_WRITE ) != 0;
1411}
1412
1418static inline bool rtems_libio_iop_is_append( const rtems_libio_t *iop )
1419{
1420 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_APPEND ) != 0;
1421}
1422
1428typedef int (*rtems_libio_open_t)(
1429 const char *pathname,
1430 uint32_t flag,
1431 uint32_t mode
1432);
1433
1434typedef int (*rtems_libio_close_t)(
1435 int fd
1436);
1437
1438typedef ssize_t (*rtems_libio_read_t)(
1439 int fd,
1440 void *buffer,
1441 size_t count
1442);
1443
1444typedef ssize_t (*rtems_libio_write_t)(
1445 int fd,
1446 const void *buffer,
1447 size_t count
1448);
1449
1450typedef int (*rtems_libio_ioctl_t)(
1451 int fd,
1452 uint32_t command,
1453 void *buffer
1454);
1455
1456typedef off_t (*rtems_libio_lseek_t)(
1457 int fd,
1458 off_t offset,
1459 int whence
1460);
1461
1469/*
1470 * The following macros are used to build up the permissions sets
1471 * used to check permissions. These are similar in style to the
1472 * mode_t bits and should stay compatible with them.
1473 */
1474#define RTEMS_FS_PERMS_READ 0x4
1475#define RTEMS_FS_PERMS_WRITE 0x2
1476#define RTEMS_FS_PERMS_EXEC 0x1
1477#define RTEMS_FS_PERMS_RWX \
1478 (RTEMS_FS_PERMS_READ | RTEMS_FS_PERMS_WRITE | RTEMS_FS_PERMS_EXEC)
1479#define RTEMS_FS_FOLLOW_HARD_LINK 0x8
1480#define RTEMS_FS_FOLLOW_SYM_LINK 0x10
1481#define RTEMS_FS_FOLLOW_LINK \
1482 (RTEMS_FS_FOLLOW_HARD_LINK | RTEMS_FS_FOLLOW_SYM_LINK)
1483#define RTEMS_FS_MAKE 0x20
1484#define RTEMS_FS_EXCLUSIVE 0x40
1485#define RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS 0x80
1486#define RTEMS_FS_REJECT_TERMINAL_DOT 0x100
1487
1491 dev_t device;
1492 struct {
1493 rtems_device_major_number major;
1494 rtems_device_minor_number minor;
1495 } __overlay;
1496};
1497
1498static inline dev_t rtems_filesystem_make_dev_t(
1499 rtems_device_major_number _major,
1500 rtems_device_minor_number _minor
1501)
1502{
1503 union __rtems_dev_t temp;
1504
1505 temp.__overlay.major = _major;
1506 temp.__overlay.minor = _minor;
1507 return temp.device;
1508}
1509
1510static inline dev_t rtems_filesystem_make_dev_t_from_pointer(
1511 const void *pointer
1512)
1513{
1514 uint64_t temp = (((uint64_t) 1) << 63) | (((uintptr_t) pointer) >> 1);
1515
1516 return rtems_filesystem_make_dev_t((uint32_t) (temp >> 32), (uint32_t) temp);
1517}
1518
1519static inline rtems_device_major_number rtems_filesystem_dev_major_t(
1520 dev_t device
1521)
1522{
1523 union __rtems_dev_t temp;
1524
1525 temp.device = device;
1526 return temp.__overlay.major;
1527}
1528
1529
1530static inline rtems_device_minor_number rtems_filesystem_dev_minor_t(
1531 dev_t device
1532)
1533{
1534 union __rtems_dev_t temp;
1535
1536 temp.device = device;
1537 return temp.__overlay.minor;
1538}
1539
1540#define rtems_filesystem_split_dev_t( _dev, _major, _minor ) \
1541 do { \
1542 (_major) = rtems_filesystem_dev_major_t ( _dev ); \
1543 (_minor) = rtems_filesystem_dev_minor_t( _dev ); \
1544 } while(0)
1545
1546/*
1547 * Prototypes for filesystem
1548 */
1549
1558void rtems_filesystem_initialize( void );
1559
1560void rtems_libio_post_driver(void);
1561
1562void rtems_libio_exit(void);
1563
1573extern int rtems_mkdir(const char *path, mode_t mode);
1574
1591#define RTEMS_FILESYSTEM_TYPE_IMFS "imfs"
1592#define RTEMS_FILESYSTEM_TYPE_FTPFS "ftpfs"
1593#define RTEMS_FILESYSTEM_TYPE_TFTPFS "tftpfs"
1594#define RTEMS_FILESYSTEM_TYPE_NFS "nfs"
1595#define RTEMS_FILESYSTEM_TYPE_DOSFS "dosfs"
1596#define RTEMS_FILESYSTEM_TYPE_RFS "rfs"
1597#define RTEMS_FILESYSTEM_TYPE_JFFS2 "jffs2"
1598
1605 rtems_chain_node mt_node;
1606 void *fs_info;
1608 const void *immutable_fs_info;
1609 rtems_chain_control location_chain;
1612 bool mounted;
1613 bool writeable;
1614 const rtems_filesystem_limits_and_options_t *pathconf_limits_and_options;
1615
1616 /*
1617 * The target or mount point of the file system.
1618 */
1619 const char *target;
1620
1621 /*
1622 * The type of filesystem or the name of the filesystem.
1623 */
1624 const char *type;
1625
1626 /*
1627 * When someone adds a mounted filesystem on a real device,
1628 * this will need to be used.
1629 *
1630 * The lower layers can manage how this is managed. Leave as a
1631 * string.
1632 */
1633 char *dev;
1634
1642};
1643
1647typedef enum {
1648 RTEMS_FILESYSTEM_READ_ONLY,
1649 RTEMS_FILESYSTEM_READ_WRITE,
1650 RTEMS_FILESYSTEM_BAD_OPTIONS
1652
1657 const char *type;
1660
1667
1668extern rtems_chain_control rtems_filesystem_mount_table;
1669
1679 const char *type,
1681);
1682
1690 const char *type
1691);
1692
1715int unmount(
1716 const char *mount_path
1717);
1718
1766int mount(
1767 const char *source,
1768 const char *target,
1769 const char *filesystemtype,
1771 const void *data
1772);
1773
1786 const char *source,
1787 const char *target,
1788 const char *filesystemtype,
1790 const void *data
1791);
1792
1802 const rtems_filesystem_table_t *fs_entry,
1803 void *arg
1804);
1805
1821 void *routine_arg
1822);
1823
1834 void *arg
1835);
1836
1852 void *visitor_arg
1853);
1854
1855typedef struct {
1856 const char *source;
1857 const char *target;
1858 const char *filesystemtype;
1860 const void *data;
1862
1864 rtems_filesystem_root_configuration;
1865
1877struct rtems_termios_tty;
1878
1880 int (*firstOpen)(int major, int minor, void *arg);
1881 int (*lastClose)(int major, int minor, void *arg);
1882 int (*pollRead)(int minor);
1883 ssize_t (*write)(int minor, const char *buf, size_t len);
1884 int (*setAttributes)(int minor, const struct termios *t);
1885 int (*stopRemoteTx)(int minor);
1886 int (*startRemoteTx)(int minor);
1887 int outputUsesInterrupts;
1889
1890RTEMS_INLINE_ROUTINE void rtems_termios_initialize( void )
1891{
1892 /* Nothing to do, provided for backward compatibility */
1893}
1894
1895/*
1896 * CCJ: Change before opening a tty. Newer code from Eric is coming
1897 * so extra work to handle an open tty is not worth it. If the tty
1898 * is open, close then open it again.
1899 */
1900rtems_status_code rtems_termios_bufsize (
1901 size_t cbufsize, /* cooked buffer size */
1902 size_t raw_input, /* raw input buffer size */
1903 size_t raw_output /* raw output buffer size */
1904);
1905
1910typedef enum {
1918
1930
1938
1956 unsigned char c,
1957 struct rtems_termios_tty *tty
1958);
1959
1979 unsigned char c,
1980 struct rtems_termios_tty *tty
1981);
1982
1997 unsigned char c,
1998 struct rtems_termios_tty *tty
1999);
2000
2015);
2016
2017int rtems_termios_enqueue_raw_characters(
2018 void *ttyp,
2019 const char *buf,
2020 int len
2021);
2022
2023rtems_status_code rtems_termios_open (
2024 rtems_device_major_number major,
2025 rtems_device_minor_number minor,
2026 void *arg,
2027 const rtems_termios_callbacks *callbacks
2028);
2029
2030rtems_status_code rtems_termios_close(
2031 void *arg
2032);
2033
2034rtems_status_code rtems_termios_read(
2035 void *arg
2036);
2037
2038rtems_status_code rtems_termios_write(
2039 void *arg
2040);
2041
2042rtems_status_code rtems_termios_ioctl(
2043 void *arg
2044);
2045
2046int rtems_termios_dequeue_characters(
2047 void *ttyp,
2048 int len
2049);
2050
2056#define rtems_filesystem_pathconf(_mte) ((_mte)->pathconf_limits_and_options)
2057
2061#define rtems_filesystem_type(_mte) ((_mte)->type)
2062
2066#define rtems_filesystem_mount_point(_mte) ((_mte)->target)
2067
2071#define rtems_filesystem_mount_device(_mte) ((_mte)->dev)
2072
2073#ifdef __cplusplus
2074}
2075#endif
2076
2077#endif /* _RTEMS_LIBIO_H */
Chain API.
rtems_status_code
Classic API Status.
Definition: status.h:43
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
bool rtems_filesystem_mount_iterate(rtems_filesystem_mt_entry_visitor visitor, void *visitor_arg)
Iterates over all file system mount entries.
Definition: sup_fs_mount_iterate.c:29
int mount_and_make_target_path(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system and makes the target path.
Definition: mount-mktgt.c:30
bool rtems_filesystem_iterate(rtems_per_filesystem_routine routine, void *routine_arg)
Iterates over all file system types.
Definition: mount-mgr.c:39
struct rtems_filesystem_table_t rtems_filesystem_table_t
File system table entry.
int unmount(const char *mount_path)
Unmounts the file system instance at the specified mount path.
Definition: unmount.c:43
int rtems_filesystem_unregister(const char *type)
Unregisters a file system type.
Definition: mount-mgr.c:141
const rtems_filesystem_table_t rtems_filesystem_table[]
Static table of file systems.
bool(* rtems_filesystem_mt_entry_visitor)(const rtems_filesystem_mount_table_entry_t *mt_entry, void *arg)
Mount table entry visitor.
Definition: libio.h:1832
bool(* rtems_per_filesystem_routine)(const rtems_filesystem_table_t *fs_entry, void *arg)
Per file system type routine.
Definition: libio.h:1801
int rtems_filesystem_register(const char *type, rtems_filesystem_fsmount_me_t mount_h)
Registers a file system type.
Definition: mount-mgr.c:107
File system options.
Definition: libio.h:1647
int mount(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system instance at the specified target path.
Definition: mount.c:178
int(* rtems_filesystem_ioctl_t)(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
IO control of a node.
Definition: libio.h:844
int rtems_filesystem_default_fcntl(rtems_libio_t *iop, int cmd)
Definition: default_fcntl.c:22
int(* rtems_filesystem_poll_t)(rtems_libio_t *iop, int events)
Poll and select support.
Definition: libio.h:959
int rtems_filesystem_default_ftruncate(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate.c:25
int rtems_filesystem_default_ftruncate_directory(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate_directory.c:30
off_t rtems_filesystem_default_lseek_directory(rtems_libio_t *iop, off_t offset, int whence)
An offset 0 with a whence of SEEK_SET will perform a directory rewind operation.
Definition: default_lseek_directory.c:29
ssize_t(* rtems_filesystem_read_t)(rtems_libio_t *iop, void *buffer, size_t count)
Reads from a node.
Definition: libio.h:760
int(* rtems_filesystem_fcntl_t)(rtems_libio_t *iop, int cmd)
File control.
Definition: libio.h:944
int rtems_filesystem_default_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
Definition: default_ioctl.c:24
int rtems_filesystem_default_poll(rtems_libio_t *iop, int events)
Default poll handler.
Definition: default_poll.c:31
int rtems_filesystem_default_fsync_or_fdatasync(rtems_libio_t *iop)
Definition: default_fsync.c:24
const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default
File system node handler table with default node handlers.
Definition: default_handlers.c:24
off_t rtems_filesystem_default_lseek_file(rtems_libio_t *iop, off_t offset, int whence)
Default lseek() handler for files.
Definition: default_lseek_file.c:29
int(* rtems_filesystem_kqfilter_t)(rtems_libio_t *iop, struct knote *kn)
Kernel event filter support.
Definition: libio.h:975
int rtems_filesystem_default_fstat(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Sets the mode to S_IRWXU | S_IRWXG | S_IRWXO.
Definition: default_fstat.c:24
int rtems_filesystem_default_fsync_or_fdatasync_success(rtems_libio_t *iop)
Definition: default_fsync_success.c:29
int rtems_filesystem_default_kqfilter(rtems_libio_t *iop, struct knote *kn)
Default kernel event filter handler.
Definition: default_kqfilter.c:29
ssize_t rtems_filesystem_default_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the write handler for each IO vector entry.
Definition: default_writev.c:32
int(* rtems_filesystem_close_t)(rtems_libio_t *iop)
Closes a node.
Definition: libio.h:742
ssize_t rtems_filesystem_default_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the read handler for each IO vector entry.
Definition: default_readv.c:32
off_t(* rtems_filesystem_lseek_t)(rtems_libio_t *iop, off_t offset, int whence)
Moves the read/write file offset.
Definition: libio.h:864
off_t rtems_filesystem_default_lseek(rtems_libio_t *iop, off_t offset, int whence)
Definition: default_lseek.c:24
ssize_t(* rtems_filesystem_writev_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Writes an IO vector to a node.
Definition: libio.h:825
int(* rtems_filesystem_fstat_t)(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Gets a node status.
Definition: libio.h:881
int rtems_filesystem_default_mmap(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
Default MMAP handler.
Definition: default_mmap.c:23
ssize_t(* rtems_filesystem_write_t)(rtems_libio_t *iop, const void *buffer, size_t count)
Writes to a node.
Definition: libio.h:803
int rtems_filesystem_default_close(rtems_libio_t *iop)
Definition: default_close.c:18
int(* rtems_filesystem_fsync_t)(rtems_libio_t *iop)
Synchronizes changes to a file.
Definition: libio.h:914
ssize_t rtems_filesystem_default_read(rtems_libio_t *iop, void *buffer, size_t count)
Definition: default_read.c:20
int(* rtems_filesystem_fdatasync_t)(rtems_libio_t *iop)
Synchronizes the data of a file.
Definition: libio.h:929
int rtems_filesystem_default_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Definition: default_open.c:24
int(* rtems_filesystem_mmap_t)(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
MMAP support.
Definition: libio.h:994
ssize_t(* rtems_filesystem_readv_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Reads an IO vector from a node.
Definition: libio.h:782
ssize_t rtems_filesystem_default_write(rtems_libio_t *iop, const void *buffer, size_t count)
Definition: default_write.c:22
int(* rtems_filesystem_ftruncate_t)(rtems_libio_t *iop, off_t length)
Truncates a file to a specified length.
Definition: libio.h:898
int(* rtems_filesystem_open_t)(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Opens a node.
Definition: libio.h:725
int(* rtems_filesystem_statvfs_t)(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Gets file system information.
Definition: libio.h:464
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:22
int(* rtems_filesystem_link_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Creates a new link for the existing file.
Definition: libio.h:174
int(* rtems_filesystem_mount_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Mounts a file system instance in a mount point (directory).
Definition: libio.h:261
int(* rtems_filesystem_fchmod_t)(const rtems_filesystem_location_info_t *loc, mode_t mode)
Changes the mode of a node.
Definition: libio.h:192
void rtems_filesystem_default_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Obtains the IO library mutex.
Definition: default_lock_and_unlock.c:29
int rtems_filesystem_default_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Definition: default_rename.c:25
void(* rtems_filesystem_fsunmount_me_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Destroys a file system instance.
Definition: libio.h:311
int rtems_filesystem_default_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Definition: default_mknod.c:25
int rtems_filesystem_default_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Definition: default_utime.c:25
int rtems_filesystem_default_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Definition: default_fchmod.c:23
void(* rtems_filesystem_eval_path_t)(rtems_filesystem_eval_path_context_t *ctx)
Path evaluation.
Definition: libio.h:157
int(* rtems_filesystem_unmount_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmounts a file system instance in a mount point (directory).
Definition: libio.h:296
int rtems_filesystem_default_clonenode(rtems_filesystem_location_info_t *loc)
Definition: default_clone.c:29
void rtems_filesystem_default_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Releases the IO library mutex.
Definition: default_lock_and_unlock.c:36
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:29
int(* rtems_filesystem_rmnod_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Removes a node.
Definition: libio.h:369
int rtems_filesystem_default_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Definition: default_rmnod.c:25
int(* rtems_filesystem_rename_t)(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Renames a node.
Definition: libio.h:445
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:22
int(* rtems_filesystem_utime_t)(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Set node access and modification times.
Definition: libio.h:386
int(* rtems_filesystem_clonenode_t)(rtems_filesystem_location_info_t *loc)
Clones a location.
Definition: libio.h:230
void rtems_filesystem_default_freenode(const rtems_filesystem_location_info_t *loc)
Definition: default_freenode.c:24
ssize_t(* rtems_filesystem_readlink_t)(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Reads the contents of a symbolic link.
Definition: libio.h:425
void rtems_filesystem_default_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_fsunmount.c:20
int(* rtems_filesystem_mknod_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Creates a new node.
Definition: libio.h:350
bool(* rtems_filesystem_are_nodes_equal_t)(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node of one location is equal to the node of the other location.
Definition: libio.h:329
void(* rtems_filesystem_mt_entry_unlock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Unlocks a file system instance.
Definition: libio.h:77
void rtems_filesystem_default_eval_path(rtems_filesystem_eval_path_context_t *ctx)
Terminates the path evaluation and replaces the current location with the null location.
Definition: default_eval_path.c:29
int rtems_filesystem_default_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Definition: default_symlink.c:25
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:23
int(* rtems_filesystem_fsmount_me_t)(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Initializes a file system instance.
Definition: libio.h:277
int(* rtems_filesystem_chown_t)(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Changes owner and group of a node.
Definition: libio.h:209
const rtems_filesystem_operations_table rtems_filesystem_operations_default
File system operations table with default operations.
Definition: default_ops.c:24
void(* rtems_filesystem_freenode_t)(const rtems_filesystem_location_info_t *loc)
Frees the location of a node.
Definition: libio.h:241
void(* rtems_filesystem_mt_entry_lock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Locks a file system instance.
Definition: libio.h:66
int rtems_filesystem_default_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Definition: default_chown.c:23
ssize_t rtems_filesystem_default_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Definition: default_readlink.c:25
int(* rtems_filesystem_symlink_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Makes a symbolic link to a node.
Definition: libio.h:406
int rtems_filesystem_default_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Definition: default_link.c:23
rtems_filesystem_fsmount_me_t rtems_filesystem_get_mount_handler(const char *type)
Gets the mount handler for the file system type.
Definition: mount-mgr.c:90
Creates a directory and all its parent directories according to path.
Definition: rtems_mkdir.c:130
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:32
const rtems_filesystem_limits_and_options_t rtems_filesystem_default_pathconf
Default pathconf settings.
Definition: mount.c:30
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
rtems_termios_iproc_status_code rtems_termios_default_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
Default handler for ISIG (VINTR/VKILL)
Definition: termios.c:1314
rtems_termios_iproc_status_code(* rtems_termios_isig_handler)(unsigned char c, struct rtems_termios_tty *tty)
Type for ISIG (VINTR/VKILL) handler.
Definition: libio.h:1955
The status code returned by all Termios input processing (iproc) functions and input signal (isig) ha...
Definition: libio.h:1910
rtems_status_code rtems_termios_register_isig_handler(rtems_termios_isig_handler handler)
Register handler for ISIG (VINTR/VKILL)
Definition: termios.c:1326
rtems_termios_iproc_status_code rtems_termios_posix_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
POSIX handler for ISIG (VINTR/VKILL)
Definition: termios_posix_isig_handler.c:23
@ RTEMS_TERMIOS_IPROC_DONE
This status indicates that the input processing is done.
Definition: libio.h:1936
@ RTEMS_TERMIOS_IPROC_CONTINUE
This status indicates that the input processing can continue.
Definition: libio.h:1917
@ RTEMS_TERMIOS_IPROC_INTERRUPT
This status indicates that the input processing should stop due to a signal.
Definition: libio.h:1929
Basic Filesystem Types.
Atomic Operations API.
Interface to the statvfs() Set of API Methods.
Definition: chain.h:68
Definition: jffs2.h:92
File system node operations table.
Definition: libio.h:1005
File system operations table.
Definition: libio.h:472
Definition: rtemscompat1.h:15
Definition: iterateoverthreads.c:23
Path evaluation context.
int recursionlevel
Definition: libio.h:126
rtems_filesystem_location_info_t currentloc
Definition: libio.h:135
const char * path
size_t pathlen
Definition: libio.h:93
rtems_filesystem_global_location_t * rootloc
Definition: libio.h:141
size_t tokenlen
Definition: libio.h:105
const char * token
int flags
Definition: libio.h:119
rtems_filesystem_global_location_t * startloc
Definition: libio.h:147
Global file system location.
Definition: fs.h:81
Contain file system specific information which is required to support fpathconf().
Definition: libio.h:1289
File system location.
Definition: fs.h:53
Definition: libio.h:1855
Mount table entry.
Definition: libio.h:1604
rtems_id unmount_task
Definition: libio.h:1641
Definition: libio.h:1656
Parameter block for ioctl.
Definition: libio.h:1355
Parameter block for open/close.
Definition: libio.h:1346
Paramameter block for read/write.
Definition: libio.h:1334
An open file data structure.
Definition: libio.h:1320
Definition: libio.h:1879
Definition: termiostypes.h:283
rtems_termios_device_handler handler
The device handler.
Definition: termiostypes.h:355
Definition: statvfs.h:36
Definition: chain.h:86
Definition: libio.h:1490
