RTEMS 5.2
ratemondata.h
1
9/* COPYRIGHT (c) 1989-2009, 2016.
10 * On-Line Applications Research Corporation (OAR).
11 * COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_RTEMS_RATEMONDATA_H
19#define _RTEMS_RTEMS_RATEMONDATA_H
20
21#include <rtems/rtems/ratemon.h>
23#include <rtems/score/thread.h>
25
26#ifdef __cplusplus
27extern "C" {
28#endif
29
40typedef struct {
42 uint32_t count;
44 uint32_t missed_count;
45
52
60
69typedef struct {
72
76 ISR_LOCK_MEMBER( Lock )
77
78
80
83
88 Priority_Node Priority;
89
94 uint32_t next_length;
95
101
107 Timestamp_Control cpu_usage_period_initiated;
108
113 Timestamp_Control time_period_initiated;
114
119
124 uint32_t postponed_jobs;
125
130 uint64_t latest_deadline;
132
137
147#define RATE_MONOTONIC_INFORMATION_DEFINE( max ) \
148 OBJECTS_INFORMATION_DEFINE( \
149 _Rate_monotonic, \
150 OBJECTS_CLASSIC_API, \
151 OBJECTS_RTEMS_PERIODS, \
152 Rate_monotonic_Control, \
153 max, \
154 OBJECTS_NO_STRING_NAME, \
155 NULL \
156 )
157
160#ifdef __cplusplus
161}
162#endif
163
164#endif
165/* end of include file */
Constants and Structures Associated with Watchdog Timers.
Objects_Information _Rate_monotonic_Information
The Classic Rate Monotonic objects information.
rtems_rate_monotonic_period_states
Definition: ratemon.h:64
#define ISR_LOCK_MEMBER(_designator)
Defines an ISR lock member.
Definition: isrlock.h:89
int64_t Timestamp_Control
Definition: timestamp.h:57
Constants and Structures Related with the Thread Control Block.
Definition: objectdata.h:39
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
The priority node to build up a priority aggregation.
Definition: priority.h:98
The following structure defines the control block used to manage each period.
Definition: ratemondata.h:69
Objects_Control Object
Definition: ratemondata.h:71
Definition: ratemondata.h:40
Timestamp_Control min_wall_time
Definition: ratemondata.h:54
Timestamp_Control min_cpu_time
Definition: ratemondata.h:47
Timestamp_Control max_cpu_time
Definition: ratemondata.h:49
Timestamp_Control total_cpu_time
Definition: ratemondata.h:51
uint32_t count
Definition: ratemondata.h:42
Definition: ratemondata.h:44
Timestamp_Control max_wall_time
Definition: ratemondata.h:56
Timestamp_Control total_wall_time
Definition: ratemondata.h:58
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
Definition: thread.h:732
Helpers for Manipulating Timestamps.
