RTEMS 5.2
Files | Data Structures | Macros | Functions | Variables
Classic Rate Monotonic Scheduler Implementation
file  ratemondata.h
 Classic Rate Monotonic Scheduler Data Structures.
file  ratemonimpl.h
 Classic Rate Monotonic Scheduler Implementation.
struct  Rate_monotonic_Statistics
struct  Rate_monotonic_Control
 The following structure defines the control block used to manage each period. More...
#define RATE_MONOTONIC_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Rate Monotonic objects. More...
#define RATE_MONOTONIC_INTEND_TO_BLOCK    ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_INTEND_TO_BLOCK )
#define RATE_MONOTONIC_BLOCKED    ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_BLOCKED )
#define RATE_MONOTONIC_READY_AGAIN    ( THREAD_WAIT_CLASS_PERIOD | THREAD_WAIT_STATE_READY_AGAIN )
RTEMS_INLINE_ROUTINE Rate_monotonic_Control_Rate_monotonic_Allocate (void)
 Allocates a period control block from the inactive chain of free period control blocks. More...
RTEMS_INLINE_ROUTINE void _Rate_monotonic_Acquire_critical (Rate_monotonic_Control *the_period, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Rate_monotonic_Release (Rate_monotonic_Control *the_period, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE Rate_monotonic_Control_Rate_monotonic_Get (Objects_Id id, ISR_lock_Context *lock_context)
void _Rate_monotonic_Timeout (Watchdog_Control *watchdog)
bool _Rate_monotonic_Get_status (const Rate_monotonic_Control *the_period, Timestamp_Control *wall_since_last_period, Timestamp_Control *cpu_since_last_period)
 _Rate_monotonic_Get_status( More...
void _Rate_monotonic_Restart (Rate_monotonic_Control *the_period, Thread_Control *owner, ISR_lock_Context *lock_context)
void _Rate_monotonic_Cancel (Rate_monotonic_Control *the_period, Thread_Control *owner, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Rate_monotonic_Reset_min_time (Timestamp_Control *min_time)
RTEMS_INLINE_ROUTINE void _Rate_monotonic_Reset_statistics (Rate_monotonic_Control *the_period)
Objects_Information _Rate_monotonic_Information
 The Classic Rate Monotonic objects information.
◆ RATE_MONOTONIC_INFORMATION_DEFINE
#define RATE_MONOTONIC_INFORMATION_DEFINE (   max)
Value:
_Rate_monotonic, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_PERIODS, \
max, \
NULL \
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:101
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:427
Definition: ratemondata.h:69
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
◆ _Rate_monotonic_Allocate()
RTEMS_INLINE_ROUTINE Rate_monotonic_Control * _Rate_monotonic_Allocate ( void  )
This function allocates a period control block from the inactive chain of free period control blocks.
◆ _Rate_monotonic_Get_status()
bool _Rate_monotonic_Get_status ( const Rate_monotonic_Control the_period,
Timestamp_Control wall_since_last_period,
Timestamp_Control cpu_since_last_period
This routine is invoked to compute the elapsed wall time and cpu time for a period.
Parameters
[in]the_periodpoints to the period being operated upon.
[out]wall_since_last_periodis set to the wall time elapsed since the period was initiated.
[out]cpu_since_last_periodis set to the cpu time used by the owning thread since the period was initiated.
Return values
Thisroutine returns true if the status can be determined and false otherwise.
