RTEMS  5.1
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Thread Handler
Thread Handler. More...
file  thread.h
 Constants and Structures Related with the Thread Control Block.
file  threaddispatch.h
 Constants and Structures Related with Thread Dispatch.
file  threadidledata.h
 Constants for the idle threads.
file  threadimpl.h
 Inlined Routines from the Thread Handler.
file  iterateoverthreads.c
 Iterates Over All Threads.
file  thread.c
 Initialize Thread Handler.
file  threadallocateunlimited.c
file  threadchangepriority.c
 Changes the Priority of a Thread.
file  threadclearstate.c
 Clear Thread state.
file  threadcreateidle.c
 Create Idle Thread.
file  threaddispatch.c
 Dispatch Thread.
file  threadget.c
 Maps Thread IDs to TCB Pointer.
file  threadhandler.c
 Thread Handler.
file  threadinitialize.c
 Initialize Thread.
file  threadloadenv.c
 Initializes Enviroment for A Thread.
file  threadrestart.c
 Restart Thread.
file  threadsetstate.c
 Sets States for a Thread.
file  threadstart.c
 Initializes Thread and Executes it.
file  threadstartmultitasking.c
 Start Thread Multitasking.
file  threadtimeout.c
 Thread Wait Timeout.
file  threadyield.c
 Thread Yield.
struct  Thread_Entry_idle
 Data for idle thread entry. More...
struct  Thread_Entry_numeric
 Data for thread entry with one numeric argument and no return value. More...
struct  Thread_Entry_pointer
 Data for thread entry with one pointer argument and a pointer return value. More...
struct  Thread_Entry_information
 Thread entry information. More...
struct  Thread_Start_information
struct  Thread_Scheduler_control
 Thread scheduler control. More...
union  Thread_Wait_information_Object_argument_type
 Union type to hold a pointer to an immutable or a mutable object. More...
struct  Thread_Wait_information
 Information required to manage a thread while it is blocked. More...
struct  Thread_Timer_information
 Information required to manage a thread timer. More...
struct  Thread_Proxy_control
struct  Thread_Action
 Thread action. More...
struct  Thread_Keys_information
 Per-thread information for POSIX Keys. More...
struct  Thread_Action_control
 Control block to manage thread actions. More...
struct  Thread_Life_control
 Thread life control. More...
struct  Thread_Capture_control
struct  _Thread_Control
struct  Thread_Control_add_on
 Thread control add-on. More...
struct  Thread_Information
 The thread object information. More...
struct  Thread_Configuration
 The configuration of a new thread to initialize. More...
struct  Thread_Close_context
#define RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE
#define RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT
#define THREAD_API_FIRST   THREAD_API_RTEMS
#define THREAD_API_LAST   THREAD_API_POSIX
#define THREAD_DEFAULT_MAXIMUM_NAME_SIZE   16
 The default maximum size of a thread name in characters (including the terminating '\0' character). More...
#define _Thread_queue_Heads_size   sizeof(Thread_queue_Heads)
 Size of the thread queue heads of a particular application. More...
#define THREAD_INFORMATION_DEFINE_ZERO(name, api, cls)
#define THREAD_INFORMATION_DEFINE(name, api, cls, max)
#define RTEMS_SCORE_ROBUST_THREAD_DISPATCH
 Enables a robust thread dispatch. More...
#define THREAD_WAIT_FLAGS_INITIAL   0x0U
 The initial thread wait flags value set by _Thread_Initialize().
#define THREAD_WAIT_STATE_MASK   0xffU
 Mask to get the thread wait state flags.
#define THREAD_WAIT_STATE_INTEND_TO_BLOCK   0x1U
 Indicates that the thread begins with the blocking operation. More...
#define THREAD_WAIT_STATE_BLOCKED   0x2U
 Indicates that the thread completed the blocking operation.
#define THREAD_WAIT_STATE_READY_AGAIN   0x4U
 Indicates that a condition to end the thread wait occurred. More...
#define THREAD_WAIT_CLASS_MASK   0xff00U
 Mask to get the thread wait class flags.
#define THREAD_WAIT_CLASS_EVENT   0x100U
 Indicates that the thread waits for an event.
#define THREAD_WAIT_CLASS_SYSTEM_EVENT   0x200U
 Indicates that the thread waits for a system event.
#define THREAD_WAIT_CLASS_OBJECT   0x400U
 Indicates that the thread waits for an object.
#define THREAD_WAIT_CLASS_PERIOD   0x800U
 Indicates that the thread waits for a period.
typedef void *Thread RTEMS_DEPRECATED
typedef CPU_Uint32ptr Thread_Entry_numeric_type
 Type of the numeric argument of a thread entry function with at least one numeric argument. More...
typedef void(* Thread_CPU_budget_algorithm_callout) (Thread_Control *)
typedef unsigned int Thread_Wait_flags
 This type is able to contain several flags used to control the wait class and state of a thread. More...
typedef struct Thread_Action Thread_Action
typedef void(* Thread_Action_handler) (Thread_Control *the_thread, Thread_Action *action, ISR_lock_Context *lock_context)
 Thread action handler. More...
typedef void(* rtems_per_thread_routine) (Thread_Control *)
typedef struct Thread_Configured_control Thread_Configured_control
 The configured thread control block. More...
typedef Thread_queue_Heads Thread_queue_Configured_heads
 The configured thread queue heads. More...
typedef void *(* Thread_Idle_body) (uintptr_t)
 The idle thread body type.
typedef bool(* Thread_Visitor) (Thread_Control *the_thread, void *arg)
enum  Thread_CPU_budget_algorithms { THREAD_CPU_BUDGET_ALGORITHM_NONE, THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE, THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE, THREAD_CPU_BUDGET_ALGORITHM_CALLOUT }
enum  Thread_APIs { THREAD_API_RTEMS, THREAD_API_POSIX }
enum  Thread_Life_state {
  THREAD_LIFE_PROTECTED = 0x1, THREAD_LIFE_RESTARTING = 0x2, THREAD_LIFE_TERMINATING = 0x4, THREAD_LIFE_CHANGE_DEFERRED = 0x8,
  THREAD_LIFE_DETACHED = 0x10
 Thread life states. More...
void rtems_iterate_over_all_threads (rtems_per_thread_routine routine) RTEMS_DEPRECATED
 Deprecated, use rtems_task_iterate() instead. More...
Objects_Control * _Thread_Allocate_unlimited (Objects_Information *information)
 Return an inactive thread object or NULL. More...
RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled (void)
 Indicates if the executing thread is inside a thread dispatch critical section. More...
RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_get_disable_level (void)
 Gets thread dispatch disable level. More...
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization (void)
 Thread dispatch initialization. More...
void _Thread_Dispatch (void)
 Performs a thread dispatch if necessary. More...
void _Thread_Dispatch_direct (Per_CPU_Control *cpu_self)
 Directly do a thread dispatch. More...
void _Thread_Do_dispatch (Per_CPU_Control *cpu_self, ISR_Level level)
 Performs a thread dispatch on the current processor. More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable_with_CPU (Per_CPU_Control *cpu_self, const ISR_lock_Context *lock_context)
 Disables thread dispatching inside a critical section (interrupts disabled) with the current processor. More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable_critical (const ISR_lock_Context *lock_context)
 Disables thread dispatching inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Dispatch_disable (void)
 Disables thread dispatching. More...
void _Thread_Dispatch_enable (Per_CPU_Control *cpu_self)
 Enables thread dispatching. More...
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest (Per_CPU_Control *cpu_self)
 Unnests thread dispatching. More...
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_request (Per_CPU_Control *cpu_self, Per_CPU_Control *cpu_target)
 Requests a thread dispatch on the target processor. More...
void _Thread_Iterate (Thread_Visitor visitor, void *arg)
 Calls the visitor with all threads and the given argument until it is done. More...
void _Thread_Initialize_information (Thread_Information *information)
 Initializes the thread information. More...
void _Thread_Handler_initialization (void)
 Initializes thread handler. More...
void _Thread_Create_idle (void)
 Creates idle thread. More...
void _Thread_Start_multitasking (void) RTEMS_NO_RETURN
 Starts thread multitasking. More...
bool _Thread_Initialize (Thread_Information *information, Thread_Control *the_thread, const Thread_Configuration *config)
 Initializes thread. More...
bool _Thread_Start (Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
 Initializes thread and executes it. More...
void _Thread_Restart_self (Thread_Control *executing, const Thread_Entry_information *entry, ISR_lock_Context *lock_context) RTEMS_NO_RETURN
 Restarts the currently executing thread. More...
bool _Thread_Restart_other (Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
 Restarts the thread. More...
void _Thread_Yield (Thread_Control *executing)
 Yields the currently executing thread. More...
Thread_Life_state _Thread_Change_life (Thread_Life_state clear, Thread_Life_state set, Thread_Life_state ignore)
 Changes the currently executing thread to a new state with the sets. More...
Thread_Life_state _Thread_Set_life_protection (Thread_Life_state state)
 Set the thread to life protected. More...
void _Thread_Kill_zombies (void)
 Kills all zombie threads in the system. More...
void _Thread_Exit (Thread_Control *executing, Thread_Life_state set, void *exit_value)
 Exits the currently executing thread. More...
void _Thread_Join (Thread_Control *the_thread, States_Control waiting_for_join, Thread_Control *executing, Thread_queue_Context *queue_context)
 Joins the currently executing thread with the given thread to wait for. More...
void _Thread_Cancel (Thread_Control *the_thread, Thread_Control *executing, void *exit_value)
 Cancels the thread. More...
void _Thread_Close (Thread_Control *the_thread, Thread_Control *executing, Thread_Close_context *context)
 Closes the thread. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_ready (const Thread_Control *the_thread)
 Checks if the thread is ready. More...
States_Control _Thread_Clear_state_locked (Thread_Control *the_thread, States_Control state)
 Clears the specified thread state without locking the lock context. More...
States_Control _Thread_Clear_state (Thread_Control *the_thread, States_Control state)
 Clears the specified thread state. More...
States_Control _Thread_Set_state_locked (Thread_Control *the_thread, States_Control state)
 Sets the specified thread state without locking the lock context. More...
States_Control _Thread_Set_state (Thread_Control *the_thread, States_Control state)
 Sets the specified thread state. More...
void _Thread_Load_environment (Thread_Control *the_thread)
 Initializes enviroment for a thread. More...
void _Thread_Entry_adaptor_idle (Thread_Control *executing)
 Calls the start kinds idle entry of the thread. More...
void _Thread_Entry_adaptor_numeric (Thread_Control *executing)
 Calls the start kinds numeric entry of the thread. More...
void _Thread_Entry_adaptor_pointer (Thread_Control *executing)
 Calls the start kinds pointer entry of the thread. More...
void _Thread_Handler (void)
 Wrapper function for all threads. More...
RTEMS_INLINE_ROUTINE void _Thread_State_acquire_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Acquires the lock context in a critical section. More...
RTEMS_INLINE_ROUTINE void _Thread_State_acquire (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Disables interrupts and acquires the lock_context. More...
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_State_acquire_for_executing (ISR_lock_Context *lock_context)
 Disables interrupts and acquires the lock context for the currently executing thread. More...
RTEMS_INLINE_ROUTINE void _Thread_State_release_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Release the lock context in a critical section. More...
RTEMS_INLINE_ROUTINE void _Thread_State_release (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Releases the lock context and enables interrupts. More...
void _Thread_Priority_perform_actions (Thread_Control *start_of_path, Thread_queue_Context *queue_context)
 Checks if the thread is owner of the lock of the join queue. More...
void _Thread_Priority_add (Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
 Adds the specified thread priority node to the corresponding thread priority aggregation. More...
void _Thread_Priority_remove (Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
 Removes the specified thread priority node from the corresponding thread priority aggregation. More...
void _Thread_Priority_changed (Thread_Control *the_thread, Priority_Node *priority_node, bool prepend_it, Thread_queue_Context *queue_context)
 Propagates a thread priority value change in the specified thread priority node to the corresponding thread priority aggregation. More...
RTEMS_INLINE_ROUTINE void _Thread_Priority_change (Thread_Control *the_thread, Priority_Node *priority_node, Priority_Control new_priority, bool prepend_it, Thread_queue_Context *queue_context)
 Changes the thread priority value of the specified thread priority node in the corresponding thread priority aggregation. More...
void _Thread_Priority_replace (Thread_Control *the_thread, Priority_Node *victim_node, Priority_Node *replacement_node)
 Replaces the victim priority node with the replacement priority node in the corresponding thread priority aggregation. More...
void _Thread_Priority_update (Thread_queue_Context *queue_context)
 Updates the priority of all threads in the set. More...
RTEMS_INLINE_ROUTINE bool _Thread_Priority_less_than (Priority_Control left, Priority_Control right)
 Updates the priority of the thread and changes it sticky level. More...
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Priority_highest (Priority_Control left, Priority_Control right)
 Returns the highest priority of the left and right thread priorities in the intuitive sense of priority. More...
RTEMS_INLINE_ROUTINE Objects_Information * _Thread_Get_objects_information (Objects_Id id)
 Gets object information for the object id. More...
Thread_Control * _Thread_Get (Objects_Id id, ISR_lock_Context *lock_context)
 Gets a thread by its identifier. More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Get_CPU (const Thread_Control *thread)
 Gets the cpu of the thread's scheduler. More...
RTEMS_INLINE_ROUTINE void _Thread_Set_CPU (Thread_Control *thread, Per_CPU_Control *cpu)
 Sets the cpu of the thread's scheduler. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_executing (const Thread_Control *the_thread)
 Checks if the thread is the currently executing thread. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_heir (const Thread_Control *the_thread)
 Checks if the thread is the heir. More...
RTEMS_INLINE_ROUTINE void _Thread_Unblock (Thread_Control *the_thread)
 Unblocks the thread. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_allocated_fp (const Thread_Control *the_thread)
 Checks if the floating point context of the thread is currently loaded in the floating point unit. More...
RTEMS_INLINE_ROUTINE void _Thread_Save_fp (Thread_Control *executing)
 Saves the executing thread's floating point area. More...
RTEMS_INLINE_ROUTINE void _Thread_Restore_fp (Thread_Control *executing)
 Restores the executing thread's floating point area. More...
RTEMS_INLINE_ROUTINE void _Thread_Deallocate_fp (void)
 Deallocates the currently loaded floating point context. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_context_switch_necessary (void)
 Checks if dispatching is disabled. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_null (const Thread_Control *the_thread)
 Checks if the thread is NULL. More...
RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_maximum_internal_threads (void)
 Gets the maximum number of internal threads. More...
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Internal_allocate (void)
 Allocates an internal thread and returns it. More...
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Get_heir_and_make_it_executing (Per_CPU_Control *cpu_self)
 Gets the heir of the processor and makes it executing. More...
RTEMS_INLINE_ROUTINE void _Thread_Update_CPU_time_used (Thread_Control *the_thread, Per_CPU_Control *cpu)
 Updates the cpu time used of the thread. More...
void _Thread_Get_CPU_time_used (Thread_Control *the_thread, Timestamp_Control *cpu_time_used)
 Updates the used cpu time for the heir and dispatches a new heir. More...
RTEMS_INLINE_ROUTINE void _Thread_Action_control_initialize (Thread_Action_control *action_control)
 Initializes the control chain of the action control. More...
RTEMS_INLINE_ROUTINE void _Thread_Action_initialize (Thread_Action *action)
 Initializes the Thread action. More...
RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action (Thread_Control *the_thread, Thread_Action *action, Thread_Action_handler handler)
 Adds a post switch action to the thread with the given handler. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarting (Thread_Life_state life_state)
 Checks if the thread life state is restarting. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminating (Thread_Life_state life_state)
 Checks if the thread life state is terminating. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_change_allowed (Thread_Life_state life_state)
 Checks if the thread life state allos life change. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_changing (Thread_Life_state life_state)
 Checks if the thread life state is life changing. More...
RTEMS_INLINE_ROUTINE bool _Thread_Is_joinable (const Thread_Control *the_thread)
 Checks if the thread is joinable. More...
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_increment (Thread_Control *the_thread)
 Increments the thread's resource count. More...
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_decrement (Thread_Control *the_thread)
 Decrements the thread's resource count. More...
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Thread_Scheduler_get_home (const Thread_Control *the_thread)
 Gets the home scheduler of the thread. More...
RTEMS_INLINE_ROUTINE Scheduler_Node * _Thread_Scheduler_get_home_node (const Thread_Control *the_thread)
 Gets the scheduler's home node. More...
RTEMS_INLINE_ROUTINE Scheduler_Node * _Thread_Scheduler_get_node_by_index (const Thread_Control *the_thread, size_t scheduler_index)
 Gets the thread's scheduler node by index. More...
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_priority (const Thread_Control *the_thread)
 Returns the priority of the thread. More...
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_priority (const Thread_Control *the_thread)
 Returns the unmapped priority of the thread. More...
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_real_priority (const Thread_Control *the_thread)
 Returns the unmapped real priority of the thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_default_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Acquires the thread wait default lock inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Wait_acquire_default_for_executing (ISR_lock_Context *lock_context)
 Acquires the thread wait default lock and returns the executing thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_default (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Acquires the thread wait default lock and disables interrupts. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_default_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Releases the thread wait default lock inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_default (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Releases the thread wait default lock and restores the previous interrupt status. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_critical (Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Acquires the thread wait lock inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire (Thread_Control *the_thread, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_critical (Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Releases the thread wait lock inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_release (Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Releases the thread wait lock and restores the previous interrupt status. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_claim (Thread_Control *the_thread, Thread_queue_Queue *queue)
 Claims the thread wait queue. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_claim_finalize (Thread_Control *the_thread, const Thread_queue_Operations *operations)
 Finalizes the thread wait queue claim via registration of the corresponding thread queue operations. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_remove_request (Thread_Control *the_thread, Thread_queue_Lock_context *queue_lock_context)
 Removes a thread wait lock request. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_restore_default (Thread_Control *the_thread)
 Restores the default thread wait queue and operations. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_tranquilize (Thread_Control *the_thread)
 Tranquilizes the thread after a wait on a thread queue. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_cancel (Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Cancels a thread wait on a thread queue. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_flags_set (Thread_Control *the_thread, Thread_Wait_flags flags)
 Sets the thread's wait flags. More...
RTEMS_INLINE_ROUTINE Thread_Wait_flags _Thread_Wait_flags_get (const Thread_Control *the_thread)
 Gets the thread's wait flags according to the ATOMIC_ORDER_RELAXED. More...
RTEMS_INLINE_ROUTINE Thread_Wait_flags _Thread_Wait_flags_get_acquire (const Thread_Control *the_thread)
 Gets the thread's wait flags according to the ATOMIC_ORDER_ACQUIRE. More...
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_release (Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags)
 Tries to change the thread wait flags with release semantics in case of success. More...
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_acquire (Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags)
 Tries to change the thread wait flags with acquire semantics. More...
Objects_Id _Thread_Wait_get_id (const Thread_Control *the_thread)
 Returns the object identifier of the object containing the current thread wait queue. More...
RTEMS_INLINE_ROUTINE Status_Control _Thread_Wait_get_status (const Thread_Control *the_thread)
 Get the status of the wait return code of the thread. More...
void _Thread_Continue (Thread_Control *the_thread, Status_Control status)
 Cancels a blocking operation so that the thread can continue its execution. More...
void _Thread_Timeout (Watchdog_Control *the_watchdog)
 General purpose thread wait timeout. More...
RTEMS_INLINE_ROUTINE void _Thread_Timer_initialize (Thread_Timer_information *timer, Per_CPU_Control *cpu)
 Initializes the thread timer. More...
RTEMS_INLINE_ROUTINE void _Thread_Add_timeout_ticks (Thread_Control *the_thread, Per_CPU_Control *cpu, Watchdog_Interval ticks)
 Adds timeout ticks to the thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_realtime (Thread_Control *the_thread, Per_CPU_Control *cpu, Watchdog_Service_routine_entry routine, uint64_t expire)
 Inserts the cpu's watchdog realtime into the thread's timer. More...
RTEMS_INLINE_ROUTINE void _Thread_Timer_remove (Thread_Control *the_thread)
 Remove the watchdog timer from the thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Remove_timer_and_unblock (Thread_Control *the_thread, Thread_queue_Queue *queue)
 Remove the watchdog timer from the thread and unblock if necessary. More...
Status_Control _Thread_Set_name (Thread_Control *the_thread, const char *name)
 Sets the name of the thread. More...
size_t _Thread_Get_name (const Thread_Control *the_thread, char *buffer, size_t buffer_size)
 Gets the name of the thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Pin (Thread_Control *executing)
 Pin the executing thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Unpin (Thread_Control *executing, Per_CPU_Control *cpu_self)
 Unpins the thread. More...
const Thread_Control_add_on _Thread_Control_add_ons []
 Thread control add-ons. More...
const size_t _Thread_Control_add_on_count
 Thread control add-on count. More...
const size_t _Thread_Initial_thread_count
 Count of configured threads. More...
const size_t _Thread_Maximum_name_size
 Maximum size of a thread name in characters (including the terminating '\0' character). More...
Thread_Information _Thread_Information
 The internal thread objects information.
char _Thread_Idle_stacks []
 The idle thread stacks. More...
const size_t _Thread_Idle_stack_size
 The idle thread stack size in bytes. More...
const Thread_Idle_body _Thread_Idle_body
 The idle thread body. More...
void * rtems_ada_self
Objects_Id _Thread_Global_constructor
 Object identifier of the global constructor thread. More...
Thread_Control * _Thread_Allocated_fp
Thread Handler.
This handler encapsulates functionality related to the management of threads. This includes the creation, deletion, and scheduling of threads.
The following variables are maintained as part of the per cpu data structure.
◆ _Thread_queue_Heads_size
In SMP configurations, this value is provided via <rtems/confdefs.h>.
◆ RTEMS_SCORE_ROBUST_THREAD_DISPATCH
On each change of the thread dispatch disable level from one to zero the interrupt status is checked. In case interrupts are disabled and SMP is enabled or the CPU port needs it, then the system terminates with the fatal internal error INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT.
◆ THREAD_API_FIRST
This macro defines the first API which has threads.
◆ THREAD_API_LAST
This macro defines the last API which has threads.
◆ THREAD_DEFAULT_MAXIMUM_NAME_SIZE
This is the default value for the application configuration option CONFIGURE_MAXIMUM_THREAD_NAME_SIZE.
◆ THREAD_INFORMATION_DEFINE
#define THREAD_INFORMATION_DEFINE (   name,
  api,
  cls,
  max
Value:
static Objects_Control * \
name##_Local_table[ _Objects_Maximum_per_allocation( max ) ]; \
static Thread_Configured_control \
name##_Objects[ _Objects_Maximum_per_allocation( max ) ]; \
static Thread_queue_Configured_heads \
name##_Heads[ _Objects_Maximum_per_allocation( max ) ]; \
Thread_Information name##_Information = { \
_Objects_Build_id( api, cls, 1, _Objects_Maximum_per_allocation( max ) ), \
name##_Local_table, \
_Objects_Is_unlimited( max ) ? \
_Thread_Allocate_unlimited : _Objects_Allocate_static, \
_Objects_Free_unlimited : _Objects_Free_static, \
0, \
_Objects_Is_unlimited( max ) ? _Objects_Maximum_per_allocation( max ) : 0, \
CHAIN_INITIALIZER_EMPTY( name##_Information.Objects.Inactive ), \
NULL, \
NULL, \
&name##_Objects[ 0 ].Control.Object \
OBJECTS_INFORMATION_MP( name##_Information.Objects, NULL ) \
&name##_Heads[ 0 ] \
Definition: objectdata.h:39
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:101
#define CHAIN_INITIALIZER_EMPTY(name)
Chain initializer for an empty chain with designator name.
Definition: chainimpl.h:39
void _Objects_Free_static(Objects_Information *information, Objects_Control *the_object)
Free the object.
Definition: objectfreestatic.c:41
Definition: thread.h:969
Objects_Control * _Objects_Allocate_static(Objects_Information *information)
Return an inactive object or NULL.
Definition: objectallocatestatic.c:41
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
◆ THREAD_INFORMATION_DEFINE_ZERO
#define THREAD_INFORMATION_DEFINE_ZERO (   name,
  api,
  cls
Value:
_Objects_Build_id( api, cls, 1, 0 ), \
NULL, \
_Objects_Allocate_none, \
NULL, \
0, \
0, \
0, \
0, \
NULL, \
NULL, \
NULL \
OBJECTS_INFORMATION_MP( name##_Information.Objects, NULL ), \
NULL \
Definition: thread.h:997
#define NULL
◆ THREAD_WAIT_STATE_INTEND_TO_BLOCK
A blocking operation consists of an optional watchdog initialization and the setting of the appropriate thread blocking state with the corresponding scheduler block operation.
◆ THREAD_WAIT_STATE_READY_AGAIN
This could be a timeout, a signal, an event or a resource availability.
Typedef Documentation
◆ Thread_Action_handler
typedef void( * Thread_Action_handler) (Thread_Control *the_thread, Thread_Action *action, ISR_lock_Context *lock_context)
The thread action handler will be called with interrupts disabled and a corresponding lock acquired, e.g. _Thread_State_acquire(). The handler must release the corresponding lock, e.g. _Thread_State_release(). So, the corresponding lock may be used to protect private data used by the particular action.
Since the action is passed to the handler additional data may be accessed via RTEMS_CONTAINER_OF().
Parameters
[in]the_threadThe thread performing the action.
[in]actionThe thread action.
[in]lock_contextThe lock context to use for the lock release.
◆ Thread_Configured_control
This type is defined in <rtems/confdefs.h> and depends on the application configuration.
◆ Thread_CPU_budget_algorithm_callout
This defines thes the entry point for the thread specific timeslice budget management algorithm.
◆ Thread_Entry_numeric_type
This numeric argument type designates an unsigned integer type with the property that any valid pointer to void can be converted to this type and then converted back to a pointer to void. The result will compare equal to the original pointer.
◆ Thread_queue_Configured_heads
In SMP configurations, this type is defined in <rtems/confdefs.h> and depends on the application configuration.
◆ Thread_Wait_flags
The mutually exclusive wait class flags are
The mutually exclusive wait state flags are
◆ Thread_APIs
The following record defines the control block used to manage each thread.
Note
It is critical that proxies and threads have identical memory images for the shared part.
THREAD_API_RTEMS
This value is for the Classic RTEMS API.
THREAD_API_POSIX
This value is for the POSIX API.
◆ Thread_CPU_budget_algorithms
The following lists the algorithms used to manage the thread cpu budget.
Reset Timeslice: At each context switch, reset the time quantum. Exhaust Timeslice: Only reset the quantum once it is consumed. Callout: Execute routine when budget is consumed.
◆ Thread_Life_state
Thread life states.
The thread life states are orthogonal to the thread states used for synchronization primitives and blocking operations. They reflect the state changes triggered with thread restart and delete requests.
The individual state values must be a power of two to allow use of bit operations to manipulate and evaluate the thread life state.
◆ _Thread_Action_control_initialize()
RTEMS_INLINE_ROUTINE void _Thread_Action_control_initialize ( Thread_Action_control *  action_control)
Parameters
[out]action_controlThe action control to initialize.
◆ _Thread_Action_initialize()
RTEMS_INLINE_ROUTINE void _Thread_Action_initialize ( Thread_Action *  action)
Parameters
[out]actionThe Thread_Action to initialize.
◆ _Thread_Add_post_switch_action()
RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action ( Thread_Control *  the_thread,
Thread_Action *  action,
Parameters
[in,out]the_threadThe thread.
[in,out]actionThe action to add.
handlerThe handler for the action.
◆ _Thread_Add_timeout_ticks()
RTEMS_INLINE_ROUTINE void _Thread_Add_timeout_ticks ( Thread_Control *  the_thread,
Per_CPU_Control *  cpu,
Parameters
[in,out]the_threadThe thread to add the timeout ticks to.
cpuThe cpu for the operation.
ticksThe ticks to add to the timeout ticks.
◆ _Thread_Allocate_unlimited()
Objects_Control* _Thread_Allocate_unlimited ( Objects_Information *  information)
Return values
NULLNo inactive object is available.
objectAn inactive object.
◆ _Thread_Cancel()
void _Thread_Cancel ( Thread_Control *  the_thread,
Thread_Control *  executing,
void *  exit_value
Cancels the thread.
Parameters
[in,out]the_threadThe thread to cancel.
executingThe currently executing thread.
exit_valueThe exit value for the thread.
◆ _Thread_Change_life()
Thread_Life_state _Thread_Change_life ( Thread_Life_state  clear,
Parameters
clearStates to clear.
setStates to set.
ignoreStates to ignore.
Returns
The previous state the thread was in.
◆ _Thread_Clear_state()
States_Control _Thread_Clear_state ( Thread_Control *  the_thread,
In the case the previous state is a non-ready state and the next state is the ready state, then the thread is unblocked by the scheduler.
Parameters
stateThe state to clear. It must not be zero.
Returns
The previous state.
◆ _Thread_Clear_state_locked()
States_Control _Thread_Clear_state_locked ( Thread_Control *  the_thread,
Parameters
Returns
The thread's previous state.
◆ _Thread_Close()
void _Thread_Close ( Thread_Control *  the_thread,
Thread_Close_context *  context
Closes the thread.
Closes the thread object and starts the thread termination sequence. In case the executing thread is not terminated, then this function waits until the terminating thread reached the zombie state.
Parameters
the_threadThe thread to close.
[in,out]contextThe thread close context.
◆ _Thread_Continue()
void _Thread_Continue ( Thread_Control *  the_thread,
In case this function actually cancelled the blocking operation, then the thread wait return code is set to the specified status.
A specialization of this function is _Thread_Timeout().
Parameters
statusThe thread wait status.
◆ _Thread_Create_idle()
void _Thread_Create_idle ( void  )
This routine creates the idle thread.
Warning
No thread should be created before this one.
◆ _Thread_Deallocate_fp()
RTEMS_INLINE_ROUTINE void _Thread_Deallocate_fp ( void  )
This routine is invoked when the currently loaded floating point context is now longer associated with an active thread.
◆ _Thread_Dispatch()
void _Thread_Dispatch ( void  )
This routine is responsible for transferring control of the processor from the executing thread to the heir thread. Once the heir is running an attempt is made to run the pending post-switch thread actions.
As part of this process, it is responsible for the following actions
  • update timing information of the executing thread,
  • save the context of the executing thread,
  • invokation of the thread switch user extensions,
  • restore the context of the heir thread, and
  • run of pending post-switch thread actions of the resulting executing thread.
On entry the thread dispatch level must be equal to zero.
◆ _Thread_Dispatch_direct()
void _Thread_Dispatch_direct ( Per_CPU_Control *  cpu_self)
Must be called with a thread dispatch disable level of one, otherwise the INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL will occur. This function is useful for operations which synchronously block, e.g. self restart, self deletion, yield, sleep.
Parameters
cpu_selfThe current processor.
See also
_Thread_Dispatch().
◆ _Thread_Dispatch_disable()
RTEMS_INLINE_ROUTINE Per_CPU_Control* _Thread_Dispatch_disable ( void  )
Returns
◆ _Thread_Dispatch_disable_critical()
RTEMS_INLINE_ROUTINE Per_CPU_Control* _Thread_Dispatch_disable_critical ( const ISR_lock_Context *  lock_context)
Parameters
lock_contextThe lock context of the corresponding _ISR_lock_ISR_disable() that started the critical section.
Returns
◆ _Thread_Dispatch_disable_with_CPU()
RTEMS_INLINE_ROUTINE Per_CPU_Control* _Thread_Dispatch_disable_with_CPU ( Per_CPU_Control *  cpu_self,
Parameters
Returns
◆ _Thread_Dispatch_enable()
void _Thread_Dispatch_enable ( Per_CPU_Control *  cpu_self)
May perform a thread dispatch if necessary as a side-effect.
Parameters
[in,out]cpu_selfThe current processor.
◆ _Thread_Dispatch_get_disable_level()
RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_get_disable_level ( void  )
Returns
The value of the thread dispatch level.
◆ _Thread_Dispatch_initialization()
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization ( void  )
This routine initializes the thread dispatching subsystem.
◆ _Thread_Dispatch_is_enabled()
RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled ( void  )
Return values
trueThread dispatching is enabled.
falseThe executing thread is inside a thread dispatch critical section and dispatching is not allowed.
◆ _Thread_Dispatch_request()
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_request ( Per_CPU_Control *  cpu_self,
Per_CPU_Control *  cpu_target
Parameters
[in,out]cpu_targetThe target processor to request a thread dispatch.
◆ _Thread_Dispatch_unnest()
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest ( Per_CPU_Control *  cpu_self)
Parameters
◆ _Thread_Do_dispatch()
void _Thread_Do_dispatch ( Per_CPU_Control *  cpu_self,
ISR_Level  level
On entry the thread dispatch disable level must be equal to one and interrupts must be disabled.
This function assumes that a thread dispatch is necessary.
Parameters
levelThe previous interrupt level.
See also
_Thread_Dispatch().
◆ _Thread_Entry_adaptor_idle()
void _Thread_Entry_adaptor_idle ( Thread_Control *  executing)
Parameters
◆ _Thread_Entry_adaptor_numeric()
void _Thread_Entry_adaptor_numeric ( Thread_Control *  executing)
Parameters
◆ _Thread_Entry_adaptor_pointer()
void _Thread_Entry_adaptor_pointer ( Thread_Control *  executing)
Stores the return value in the Wait.return_argument of the thread.
Parameters
◆ _Thread_Exit()
void _Thread_Exit ( Thread_Control *  executing,
void *  exit_value
Parameters
[in,out]executingThe currently executing thread.
setThe states to set.
[out]exit_valueContains the exit value of the thread.
◆ _Thread_Get()
Thread_Control* _Thread_Get ( Objects_Id  id,
See also
_Objects_Get().
Parameters
idThe id of the thread.
lock_contextThe lock context.
◆ _Thread_Get_CPU()
RTEMS_INLINE_ROUTINE Per_CPU_Control* _Thread_Get_CPU ( const Thread_Control *  thread)
Parameters
threadThe thread.
Returns
The cpu of the thread's scheduler.
◆ _Thread_Get_CPU_time_used()
void _Thread_Get_CPU_time_used ( Thread_Control *  the_thread,
Timestamp_Control *  cpu_time_used
Parameters
[in,out]cpu_for_heirThe processor to do a dispatch on.
heirThe new heir for cpu_for_heir.Gets the used cpu time of the thread and stores it in the given Timestamp_Control.
the_threadThe thread to get the used cpu time of.
[out]cpu_time_usedStores the used cpu time of the_thread.
◆ _Thread_Get_heir_and_make_it_executing()
RTEMS_INLINE_ROUTINE Thread_Control* _Thread_Get_heir_and_make_it_executing ( Per_CPU_Control *  cpu_self)
Must be called with interrupts disabled. The thread dispatch necessary indicator is cleared as a side-effect.
Parameters
[in,out]cpu_selfThe processor to get the heir of.
Returns
The heir thread.
See also
_Thread_Dispatch(), _Thread_Start_multitasking() and _Thread_Dispatch_update_heir().
◆ _Thread_Get_maximum_internal_threads()
RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_maximum_internal_threads ( void  )
Returns
The maximum number of internal threads.
◆ _Thread_Get_name()
size_t _Thread_Get_name ( const Thread_Control *  the_thread,
char *  buffer,
size_t  buffer_size
Parameters
the_threadThe thread to get the name of.
[out]bufferContains the thread's name.
buffer_sizeThe size of buffer.
Returns
The number of bytes copied to buffer.
◆ _Thread_Get_objects_information()
RTEMS_INLINE_ROUTINE Objects_Information* _Thread_Get_objects_information ( Objects_Id  id)
Parameters
idThe id of the object information.
Return values
pointerThe object information for this id.
NULLThe object id is not valid.
◆ _Thread_Get_priority()
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_priority ( const Thread_Control *  the_thread)
Returns the user API and thread wait information relevant thread priority. This includes temporary thread priority adjustments due to locking protocols, a job release or the POSIX sporadic server for example.
Parameters
the_threadThe thread of which to get the priority.
Returns
The priority of the thread.
◆ _Thread_Get_unmapped_priority()
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_priority ( const Thread_Control *  the_thread)
Parameters
the_threadThe thread of which to get the unmapped priority.
Returns
The unmapped priority of the thread.
◆ _Thread_Get_unmapped_real_priority()
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_real_priority ( const Thread_Control *  the_thread)
Parameters
the_threadThe thread of which to get the unmapped real priority.
Returns
The unmapped real priority of the thread.
◆ _Thread_Handler()
void _Thread_Handler ( void  )
This routine is the wrapper function for all threads. It is the starting point for all threads. The user provided thread entry point is invoked by this routine. Operations which must be performed immediately before and after the user's thread executes are found here.
Note
On entry, it is assumed all interrupts are blocked and that this routine needs to set the initial isr level. This may or may not actually be needed by the context switch routine and as a result interrupts may already be at there proper level. Either way, setting the initial isr level properly here is safe.
◆ _Thread_Handler_initialization()
void _Thread_Handler_initialization ( void  )
This routine performs the initialization necessary for this handler.
◆ _Thread_Initialize()
bool _Thread_Initialize ( Thread_Information *  information,
const Thread_Configuration *  config
Initializes thread.
This routine initializes the specified the thread. It allocates all memory associated with this thread. It completes by adding the thread to the local object table so operations on this thread id are allowed.
Note
If stack_area is NULL, it is allocated from the workspace.
If the stack is allocated from the workspace, then it is guaranteed to be of at least minimum size.
Parameters
informationThe thread information.
the_threadThe thread to initialize.
configThe configuration of the thread to initialize.
Return values
trueThe thread initialization was successful.
falseThe thread initialization failed.
◆ _Thread_Initialize_information()
void _Thread_Initialize_information ( Thread_Information *  information)
Parameters
[out]informationInformation to initialize.
◆ _Thread_Internal_allocate()
RTEMS_INLINE_ROUTINE Thread_Control* _Thread_Internal_allocate ( void  )
Return values
pointerPointer to the allocated Thread_Control.
NULLThe operation failed.
◆ _Thread_Is_allocated_fp()
RTEMS_INLINE_ROUTINE bool _Thread_Is_allocated_fp ( const Thread_Control *  the_thread)
This function returns true if the floating point context of the_thread is currently loaded in the floating point unit, and false otherwise.
Parameters
the_threadThe thread for the verification.
Return values
trueThe floating point context of the_thread is currently loaded in the floating point unit.
falseThe floating point context of the_thread is currently not loaded in the floating point unit.
◆ _Thread_Is_context_switch_necessary()
RTEMS_INLINE_ROUTINE bool _Thread_Is_context_switch_necessary ( void  )
This function returns true if dispatching is disabled, and false otherwise.
Return values
trueDispatching is disabled.
falseDispatching is enabled.
◆ _Thread_Is_executing()
RTEMS_INLINE_ROUTINE bool _Thread_Is_executing ( const Thread_Control *  the_thread)
This function returns true if the_thread is the currently executing thread, and false otherwise.
Parameters
the_threadThe thread to verify if it is the currently executing thread.
Return values
truethe_thread is the currently executing one.
falsethe_thread is not the currently executing one.
◆ _Thread_Is_heir()
RTEMS_INLINE_ROUTINE bool _Thread_Is_heir ( const Thread_Control *  the_thread)
This function returns true if the_thread is the heir thread, and false otherwise.
Parameters
Return values
truethe_thread is the heir.
falsethe_thread is not the heir.
◆ _Thread_Is_joinable()
RTEMS_INLINE_ROUTINE bool _Thread_Is_joinable ( const Thread_Control *  the_thread)
Parameters
Return values
truelife_state is joinable.
falselife_state is not joinable.
◆ _Thread_Is_life_change_allowed()
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_change_allowed ( Thread_Life_state  life_state)
Parameters
life_stateThe thread life state for the verification.
Return values
truelife_state allows life change.
falselife_state does not allow life change.
◆ _Thread_Is_life_changing()
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_changing ( Thread_Life_state  life_state)
Parameters
Return values
truelife_state is life changing.
falselife_state is not life changing.
◆ _Thread_Is_life_restarting()
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarting ( Thread_Life_state  life_state)
Parameters
Return values
truelife_state is restarting.
falselife_state is not restarting.
◆ _Thread_Is_life_terminating()
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminating ( Thread_Life_state  life_state)
Parameters
Return values
truelife_state is terminating.
falselife_state is not terminating.
◆ _Thread_Is_null()
RTEMS_INLINE_ROUTINE bool _Thread_Is_null ( const Thread_Control *  the_thread)
Parameters
Return values
trueThe thread is NULL.
falseThe thread is not NULL.
◆ _Thread_Is_ready()
RTEMS_INLINE_ROUTINE bool _Thread_Is_ready ( const Thread_Control *  the_thread)
Parameters
the_threadThe thread to check if it is ready.
Return values
trueThe thread is currently in the ready state.
falseThe thread is currently not ready.
◆ _Thread_Iterate()
void _Thread_Iterate ( Thread_Visitor  visitor,
void *  arg
Parameters
visitorFunction that gets a thread and arg as parameters and returns if it is done.
argParameter for visitor
◆ _Thread_Join()
void _Thread_Join ( Thread_Control *  the_thread,
Thread_queue_Context *  queue_context
Parameters
[in,out]the_threadThe thread to wait for.
waiting_for_joinThe states control for the join.
queue_contextThe thread queue context.
◆ _Thread_Kill_zombies()
void _Thread_Kill_zombies ( void  )
Threads change into the zombie state as the last step in the thread termination sequence right before a context switch to the heir thread is initiated. Since the thread stack is still in use during this phase we have to postpone the thread stack reclamation until this point. On SMP configurations we may have to busy wait for context switch completion here.
◆ _Thread_Load_environment()
void _Thread_Load_environment ( Thread_Control *  the_thread)
This routine initializes the context of the_thread to its appropriate starting state.
Parameters
[in,out]the_threadThe pointer to the thread control block.
◆ _Thread_Pin()
RTEMS_INLINE_ROUTINE void _Thread_Pin ( Thread_Control *  executing)
Parameters
◆ _Thread_Priority_add()
void _Thread_Priority_add ( Thread_Control *  the_thread,
Priority_Node *  priority_node,
The caller must be the owner of the thread wait lock.
Parameters
priority_nodeThe thread priority node to add.
queue_contextThe thread queue context to return an updated set of threads for _Thread_Priority_update(). The thread queue context must be initialized via _Thread_queue_Context_clear_priority_updates() before a call of this function.
See also
_Thread_Wait_acquire().
◆ _Thread_Priority_change()
RTEMS_INLINE_ROUTINE void _Thread_Priority_change ( Thread_Control *  the_thread,
bool  prepend_it,
Parameters
[out]priority_nodeThe thread priority node to change.
new_priorityThe new thread priority value of the thread priority node to change.
prepend_itIn case this is true, then the thread is prepended to its priority group in its home scheduler instance, otherwise it is appended.
See also
◆ _Thread_Priority_changed()
void _Thread_Priority_changed ( Thread_Control *  the_thread,
bool  prepend_it,
Parameters
See also
◆ _Thread_Priority_highest()
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Priority_highest ( Priority_Control  left,
Parameters
leftThe left thread priority.
rightThe right thread priority.
Returns
The highest priority in the intuitive sense of priority.
◆ _Thread_Priority_less_than()
RTEMS_INLINE_ROUTINE bool _Thread_Priority_less_than ( Priority_Control  left,
Parameters
sticky_level_changeThe new value for the sticky level.Checks if the left thread priority is less than the right thread priority in the intuitive sense of priority.
Return values
trueThe left priority is less in the intuitive sense.
falseThe left priority is greater or equal in the intuitive sense.
◆ _Thread_Priority_perform_actions()
void _Thread_Priority_perform_actions ( Thread_Control *  start_of_path,
Parameters
Return values
trueThe thread is owner of the lock of the join queue.
falseThe thread is not owner of the lock of the join queue.Performs the priority actions specified by the thread queue context along the thread queue path.
Parameters
start_of_pathThe start thread of the thread queue path.
queue_contextThe thread queue context specifying the thread queue path and initial thread priority actions.
See also
_Thread_queue_Path_acquire_critical().
◆ _Thread_Priority_remove()
void _Thread_Priority_remove ( Thread_Control *  the_thread,
Parameters
priority_nodeThe thread priority node to remove.
See also
◆ _Thread_Priority_replace()
void _Thread_Priority_replace ( Thread_Control *  the_thread,
Priority_Node *  victim_node,
Priority_Node *  replacement_node
Parameters
victim_nodeThe victim thread priority node.
replacement_nodeThe replacement thread priority node.
See also
◆ _Thread_Priority_update()
void _Thread_Priority_update ( Thread_queue_Context *  queue_context)
Parameters
See also
_Thread_Priority_add(), _Thread_Priority_change(), _Thread_Priority_changed() and _Thread_Priority_remove().
◆ _Thread_Remove_timer_and_unblock()
RTEMS_INLINE_ROUTINE void _Thread_Remove_timer_and_unblock ( Thread_Control *  the_thread,
Thread_queue_Queue *  queue
Parameters
[in,out]the_threadThe thread to remove the watchdog from and unblock if necessary.
queueThe thread queue.
◆ _Thread_Resource_count_decrement()
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_decrement ( Thread_Control *  the_thread)
Parameters
[in,out]the_threadThe thread to decrement the resource count of.
◆ _Thread_Resource_count_increment()
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_increment ( Thread_Control *  the_thread)
Parameters
[in,out]the_threadThe thread to increase the resource count of.
◆ _Thread_Restart_other()
bool _Thread_Restart_other ( Thread_Control *  the_thread,
const Thread_Entry_information *  entry,
Parameters
[in,out]the_threadThe thread to restart.
entryThe start entry information for the_thread.
Return values
trueThe operation was successful.
falseThe operation failed.
◆ _Thread_Restart_self()
void _Thread_Restart_self ( Thread_Control *  executing,
Parameters
entryThe start entry information for executing.
◆ _Thread_Restore_fp()
RTEMS_INLINE_ROUTINE void _Thread_Restore_fp ( Thread_Control *  executing)
Parameters
◆ _Thread_Save_fp()
RTEMS_INLINE_ROUTINE void _Thread_Save_fp ( Thread_Control *  executing)
Parameters
◆ _Thread_Scheduler_get_home()
RTEMS_INLINE_ROUTINE const Scheduler_Control* _Thread_Scheduler_get_home ( const Thread_Control *  the_thread)
Parameters
the_threadThe thread to get the home scheduler of.
Returns
The thread's home scheduler.
◆ _Thread_Scheduler_get_home_node()
RTEMS_INLINE_ROUTINE Scheduler_Node* _Thread_Scheduler_get_home_node ( const Thread_Control *  the_thread)
Parameters
the_threadThe thread to get the home node of.
Returns
The thread's home node.
◆ _Thread_Scheduler_get_node_by_index()
RTEMS_INLINE_ROUTINE Scheduler_Node* _Thread_Scheduler_get_node_by_index ( const Thread_Control *  the_thread,
Parameters
the_threadThe thread of which to get a scheduler node.
scheduler_indexThe index of the desired scheduler node.
Returns
The scheduler node with the specified index.
◆ _Thread_Set_CPU()
RTEMS_INLINE_ROUTINE void _Thread_Set_CPU ( Thread_Control *  thread,
Parameters
[out]threadThe thread.
cpuThe cpu to set.
◆ _Thread_Set_life_protection()
Thread_Life_state _Thread_Set_life_protection ( Thread_Life_state  state)
Calls _Thread_Change_life with the given state AND THREAD_LIFE_PROTECTED to set and THREAD_LIFE_PROTECTED to clear.
Parameters
stateThe states to set.
Returns
◆ _Thread_Set_name()
Status_Control _Thread_Set_name ( Thread_Control *  the_thread,
const char *  name
Parameters
[out]the_threadThe thread to change the name of.
nameThe new name for the thread.
Return values
STATUS_SUCCESSFULThe operation succeeded.
STATUS_RESULT_TOO_LARGEThe name was too long.
◆ _Thread_Set_state()
States_Control _Thread_Set_state ( Thread_Control *  the_thread,
In the case the previous state is the ready state, then the thread is blocked by the scheduler.
Parameters
stateThe state to set. It must not be zero.
Returns
The previous state.
◆ _Thread_Set_state_locked()
States_Control _Thread_Set_state_locked ( Thread_Control *  the_thread,
Parameters
Returns
The previous state.
◆ _Thread_Start()
bool _Thread_Start ( Thread_Control *  the_thread,
This routine initializes the executable information for a thread and makes it ready to execute. After this routine executes, the thread competes with all other threads for CPU time.
Parameters
the_threadThe thread to be started.
entryThe thread entry information.
◆ _Thread_Start_multitasking()
void _Thread_Start_multitasking ( void  )
This routine initiates multitasking. It is invoked only as part of initialization and its invocation is the last act of the non-multitasking part of the system initialization.
◆ _Thread_State_acquire()
RTEMS_INLINE_ROUTINE void _Thread_State_acquire ( Thread_Control *  the_thread,
Parameters
the_threadThe thread to acquire the lock context.
◆ _Thread_State_acquire_critical()
RTEMS_INLINE_ROUTINE void _Thread_State_acquire_critical ( Thread_Control *  the_thread,
Parameters
◆ _Thread_State_acquire_for_executing()
RTEMS_INLINE_ROUTINE Thread_Control* _Thread_State_acquire_for_executing ( ISR_lock_Context *  lock_context)
Parameters
Returns
◆ _Thread_State_release()
RTEMS_INLINE_ROUTINE void _Thread_State_release ( Thread_Control *  the_thread,
Parameters
[in,out]the_threadThe thread to release the lock context.
[out]lock_contextThe lock context.
◆ _Thread_State_release_critical()
RTEMS_INLINE_ROUTINE void _Thread_State_release_critical ( Thread_Control *  the_thread,
Parameters
◆ _Thread_Timeout()
void _Thread_Timeout ( Watchdog_Control *  the_watchdog)
Parameters
the_watchdogThe thread timer watchdog.
◆ _Thread_Timer_initialize()
RTEMS_INLINE_ROUTINE void _Thread_Timer_initialize ( Thread_Timer_information *  timer,
Parameters
[in,out]timerThe timer to initialize.
◆ _Thread_Timer_insert_realtime()
RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_realtime ( Thread_Control *  the_thread,
uint64_t  expire
Parameters
[in,out]the_threadfor the operation.
cpuThe cpu to get the watchdog header from.
routineThe watchdog routine for the thread.
expireExpiration for the watchdog.
◆ _Thread_Timer_remove()
RTEMS_INLINE_ROUTINE void _Thread_Timer_remove ( Thread_Control *  the_thread)
Parameters
[in,out]the_threadThe thread to remove the watchdog from.
◆ _Thread_Unblock()
RTEMS_INLINE_ROUTINE void _Thread_Unblock ( Thread_Control *  the_thread)
This routine clears any blocking state for the_thread. It performs any necessary scheduling operations including the selection of a new heir thread.
Parameters
[in,out]the_threadThe thread to unblock.
◆ _Thread_Unpin()
RTEMS_INLINE_ROUTINE void _Thread_Unpin ( Thread_Control *  executing,
Unpins the thread.
Parameters
cpu_selfThe cpu for the operation.
◆ _Thread_Update_CPU_time_used()
RTEMS_INLINE_ROUTINE void _Thread_Update_CPU_time_used ( Thread_Control *  the_thread,
Parameters
[in,out]the_threadThe thread to add additional cpu time that is used.
cpuThe cpu.
◆ _Thread_Wait_acquire()
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire ( Thread_Control *  the_thread,
Parameters
[in,out]queue_contextThe thread queue context for the corresponding _Thread_Wait_release().
◆ _Thread_Wait_acquire_critical()
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_critical ( Thread_Control *  the_thread,
Parameters
[in,out]queue_contextThe thread queue context for the corresponding _Thread_Wait_release_critical().
◆ _Thread_Wait_acquire_default()
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_default ( Thread_Control *  the_thread,
Parameters
[out]lock_contextThe lock context used for the corresponding lock release.
See also
_Thread_Wait_release_default().
◆ _Thread_Wait_acquire_default_critical()
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_default_critical ( Thread_Control *  the_thread,
Parameters
See also
_Thread_Wait_release_default_critical().
◆ _Thread_Wait_acquire_default_for_executing()
RTEMS_INLINE_ROUTINE Thread_Control* _Thread_Wait_acquire_default_for_executing ( ISR_lock_Context *  lock_context)
Parameters
Returns
The executing thread.
See also
◆ _Thread_Wait_cancel()
RTEMS_INLINE_ROUTINE void _Thread_Wait_cancel ( Thread_Control *  the_thread,
Parameters
queue_contextThe thread queue context used for corresponding _Thread_Wait_acquire().
◆ _Thread_Wait_claim()
RTEMS_INLINE_ROUTINE void _Thread_Wait_claim ( Thread_Control *  the_thread,
The caller must not be the owner of the default thread wait lock. The caller must be the owner of the corresponding thread queue lock. The registration of the corresponding thread queue operations is deferred and done after the deadlock detection. This is crucial to support timeouts on SMP configurations.
Parameters
[in,out]queueThe new thread queue.
See also
_Thread_Wait_claim_finalize() and _Thread_Wait_restore_default().
◆ _Thread_Wait_claim_finalize()
RTEMS_INLINE_ROUTINE void _Thread_Wait_claim_finalize ( Thread_Control *  the_thread,
const Thread_queue_Operations *  operations
Parameters
operationsThe corresponding thread queue operations.
◆ _Thread_Wait_flags_get()
RTEMS_INLINE_ROUTINE Thread_Wait_flags _Thread_Wait_flags_get ( const Thread_Control *  the_thread)
Parameters
the_threadThe thread to get the wait flags of.
Returns
The thread's wait flags.
◆ _Thread_Wait_flags_get_acquire()
RTEMS_INLINE_ROUTINE Thread_Wait_flags _Thread_Wait_flags_get_acquire ( const Thread_Control *  the_thread)
Parameters
Returns
◆ _Thread_Wait_flags_set()
RTEMS_INLINE_ROUTINE void _Thread_Wait_flags_set ( Thread_Control *  the_thread,
Parameters
[in,out]the_threadThe thread to set the wait flags of.
flagsThe flags to set.
◆ _Thread_Wait_flags_try_change_acquire()
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_acquire ( Thread_Control *  the_thread,
In case the wait flags are equal to the expected wait flags, then the wait flags are set to the desired wait flags.
Parameters
expected_flagsThe expected wait flags.
desired_flagsThe desired wait flags.
Return values
trueThe wait flags were equal to the expected wait flags.
falseThe wait flags were not equal to the expected wait flags.
◆ _Thread_Wait_flags_try_change_release()
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_release ( Thread_Control *  the_thread,
Must be called inside a critical section (interrupts disabled).
Parameters
Return values
◆ _Thread_Wait_get_id()
Objects_Id _Thread_Wait_get_id ( const Thread_Control *  the_thread)
This function may be used for debug and system information purposes. The caller must be the owner of the thread lock.
Parameters
Return values
0The thread waits on no thread queue currently, the thread wait queue is not contained in an object, or the current thread state provides insufficient information, e.g. the thread is in the middle of a blocking operation.
otherThe object identifier of the object containing the thread wait queue.
◆ _Thread_Wait_get_status()
RTEMS_INLINE_ROUTINE Status_Control _Thread_Wait_get_status ( const Thread_Control *  the_thread)
Parameters
the_threadThe thread to get the status of the wait return code of.
◆ _Thread_Wait_release()
RTEMS_INLINE_ROUTINE void _Thread_Wait_release ( Thread_Control *  the_thread,
Parameters
[in,out]queue_contextThe thread queue context used for corresponding _Thread_Wait_acquire().
◆ _Thread_Wait_release_critical()
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_critical ( Thread_Control *  the_thread,
The previous interrupt status is not restored.
Parameters
[in,out]queue_contextThe thread queue context used for corresponding _Thread_Wait_acquire_critical().
◆ _Thread_Wait_release_default()
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_default ( Thread_Control *  the_thread,
Parameters
[out]lock_contextThe lock context used for the corresponding lock acquire.
◆ _Thread_Wait_release_default_critical()
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_default_critical ( Thread_Control *  the_thread,
Parameters
◆ _Thread_Wait_remove_request()
RTEMS_INLINE_ROUTINE void _Thread_Wait_remove_request ( Thread_Control *  the_thread,
Thread_queue_Lock_context *  queue_lock_context
On SMP configurations, removes a thread wait lock request.
On other configurations, this function does nothing.
Parameters
[in,out]queue_lock_contextThe thread queue lock context used for corresponding _Thread_Wait_acquire().
◆ _Thread_Wait_restore_default()
RTEMS_INLINE_ROUTINE void _Thread_Wait_restore_default ( Thread_Control *  the_thread)
The caller must be the owner of the current thread wait queue lock.
On SMP configurations, the pending requests are updated to use the stale thread queue operations.
Parameters
See also
_Thread_Wait_claim().
◆ _Thread_Wait_tranquilize()
RTEMS_INLINE_ROUTINE void _Thread_Wait_tranquilize ( Thread_Control *  the_thread)
After the violent blocking procedure this function makes the thread calm and peaceful again so that it can carry out its normal work.
On SMP configurations, ensures that all pending thread wait lock requests completed before the thread is able to begin a new thread wait procedure.
It must be called after a _Thread_Wait_claim() exactly once
  • after the corresponding thread queue lock was released, and
  • the default wait state is restored or some other processor is about to do this.
Parameters
◆ _Thread_Yield()
void _Thread_Yield ( Thread_Control *  executing)
Parameters
[in,out]executingThe thread that performs a yield.
◆ rtems_iterate_over_all_threads()
void rtems_iterate_over_all_threads ( rtems_per_thread_routine  routine)
Use rtems_task_iterate() instead.
Variable Documentation
◆ _Thread_Allocated_fp
Thread_Control* _Thread_Allocated_fp
The following points to the thread whose floating point context is currently loaded.
◆ _Thread_Control_add_on_count
Count of entries in _Thread_Control_add_ons.
This value is provided via <rtems/confdefs.h>.
◆ _Thread_Control_add_ons
const Thread_Control_add_on _Thread_Control_add_ons[]
The thread control block contains fields that point to application configuration dependent memory areas, like the scheduler information, the API control blocks, the user extension context table, and the Newlib re-entrancy support. Account for these areas in the configuration and avoid extra workspace allocations for these areas.
This array is provided via <rtems/confdefs.h>.
See also
_Thread_Control_add_on_count.
◆ _Thread_Global_constructor
This variable is set by _RTEMS_tasks_Initialize_user_tasks_body() or _POSIX_Threads_Initialize_user_threads_body().
It is consumed by _Thread_Handler().
◆ _Thread_Idle_body
This constant is defined by the application configuration via <rtems/confdefs.h>.
◆ _Thread_Idle_stack_size
◆ _Thread_Idle_stacks
char _Thread_Idle_stacks[]
Provided by the application via <rtems/confdefs.h>.
◆ _Thread_Initial_thread_count
◆ _Thread_Maximum_name_size
◆ rtems_ada_self
void* rtems_ada_self
Self for the GNU Ada Run-Time
