RTEMS  5.1
Objects_Information Struct Reference
The information structure used to manage each API class of objects. More...
#include <objectdata.h>
Objects_Id maximum_id
 This is the maximum valid ID of this object API class. More...
Objects_Control ** local_table
 This points to the table of local object control blocks. More...
Objects_Control *(* allocate )(Objects_Information *)
 Allocate an object. More...
void(* deallocate )(Objects_Information *, Objects_Control *)
 Free an object. More...
Objects_Maximum inactive
 This is the number of object control blocks on the inactive chain. More...
Objects_Maximum objects_per_block
 This is the number of object control blocks in an allocation block. More...
uint16_t object_size
 This is the size in bytes of each object control block. More...
uint16_t name_length
 This is the maximum length of names. More...
Chain_Control Inactive
 This is the chain of inactive object control blocks. More...
Objects_Maximum * inactive_per_block
 This is the number of inactive object control blocks per allocation block. More...
Objects_Control ** object_blocks
 This is a table to allocation blocks of object control blocks. More...
Objects_Control * initial_objects
 This points to the object control blocks initially available. More...
If objects for the API class are configured, an instance of this structure is statically allocated and pre-initialized by OBJECTS_INFORMATION_DEFINE() through <rtems/confdefs.h>. The RTEMS library contains a statically allocated and pre-initialized instance for each API class providing zero objects, see OBJECTS_INFORMATION_DEFINE_ZERO().
Field Documentation
◆ allocate
Objects_Control*( * Objects_Information::allocate) (Objects_Information *)
◆ deallocate
void( * Objects_Information::deallocate) (Objects_Information *, Objects_Control *)
Free an object.
In case _Objects_Allocate_none() is used, then this may be the NULL pointer.
See also
_Objects_Free_static(), and _Objects_Free_unlimited().
◆ inactive
Objects_Maximum Objects_Information::inactive
This member is only used if unlimited objects are configured for this API class. It is used to trigger calls to _Objects_Shrink_information() in _Objects_Free().
◆ Inactive
Chain_Control Objects_Information::Inactive
This member is statically initialized to an empty chain. The _Objects_Initialize_information() will populate this chain with the object control blocks initially configured.
◆ inactive_per_block
Objects_Maximum* Objects_Information::inactive_per_block
It is only used if unlimited objects are configured for this API class.
◆ initial_objects
Objects_Control* Objects_Information::initial_objects
This member is statically initialized and read-only. In case objects for this API class are configured, it points to a statically allocated table of object control blocks defined by <rtems/confdefs.h>, otherwise this member is NULL.
◆ local_table
Objects_Control** Objects_Information::local_table
This member is statically initialized. In case objects for this API class are configured, it initially points to a statically allocated table defined by <rtems/confdefs.h>. _Objects_Extend_information() may replace the table with a larger one on demand.
◆ maximum_id
Objects_Id Objects_Information::maximum_id
This member is statically initialized and provides also the object API, class and multiprocessing node information.
It is used by _Objects_Get() to validate an object ID.
◆ name_length
uint16_t Objects_Information::name_length
This member is statically initialized and read-only. A length of zero indicates that this API class has a no string name (OBJECTS_NO_STRING_NAME).
◆ object_blocks
Objects_Control** Objects_Information::object_blocks
It is only used if unlimited objects are configured for this API class. The object control blocks extend and shrink by these allocation blocks.
◆ object_size
uint16_t Objects_Information::object_size
◆ objects_per_block
Objects_Maximum Objects_Information::objects_per_block
This member is statically initialized and read-only. It is only used if unlimited objects are configured for this API class. It defines the count of object control blocks used to extend and shrink this API class.
