RTEMS  5.1
Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Chain Handler
Provides Data Structures Chain Node and Chain Control. More...
file  chain.h
 Chain Handler API.
file  chainimpl.h
 Chain Handler API.
file  chain.c
 Initialize a Chain Header.
struct  Chain_Node_struct
struct  Chain_Control
struct  Chain_Iterator
 A chain iterator which is updated during node extraction if it is properly registered. More...
struct  Chain_Iterator_registry
 A registry for chain iterators. More...
#define CHAIN_INITIALIZER_EMPTY(name)   { { { &(name).Tail.Node, NULL }, &(name).Head.Node } }
 Chain initializer for an empty chain with designator name.
#define CHAIN_INITIALIZER_ONE_NODE(node)   { { { (node), NULL }, (node) } }
 Chain initializer for a chain with one node. More...
#define CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(chain)   { &(chain)->Tail.Node, &(chain)->Head.Node }
 Chain node initializer for a chain containing exactly this node. More...
#define CHAIN_DEFINE_EMPTY(name)   Chain_Control name = CHAIN_INITIALIZER_EMPTY(name)
 Chain definition for an empty chain with designator name.
#define CHAIN_ITERATOR_REGISTRY_INITIALIZER(name)   { CHAIN_INITIALIZER_EMPTY( name.Iterators ) }
 Chain iterator registry initializer for static initialization. More...
typedef struct Chain_Node_struct Chain_Node
typedef bool(* Chain_Node_order) (const void *left, const Chain_Node *right)
 Chain node order. More...
enum  Chain_Iterator_direction { CHAIN_ITERATOR_FORWARD, CHAIN_ITERATOR_BACKWARD }
 The chain iterator direction. More...
void _Chain_Initialize (Chain_Control *the_chain, void *starting_address, size_t number_nodes, size_t node_size)
 Initializes a chain header. More...
size_t _Chain_Node_count_unprotected (const Chain_Control *chain)
 Returns the node count of the chain. More...
RTEMS_INLINE_ROUTINE void _Chain_Set_off_chain (Chain_Node *node)
 Sets off chain. More...
RTEMS_INLINE_ROUTINE void _Chain_Initialize_node (Chain_Node *the_node)
 Initializes a chain node. More...
RTEMS_INLINE_ROUTINE bool _Chain_Is_node_off_chain (const Chain_Node *node)
 Checks if the node is off chain. More...
RTEMS_INLINE_ROUTINE bool _Chain_Are_nodes_equal (const Chain_Node *left, const Chain_Node *right)
 Checks if two nodes are equal. More...
RTEMS_INLINE_ROUTINE bool _Chain_Is_null_node (const Chain_Node *the_node)
 Checks if the chain node pointer is NULL. More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Head (Chain_Control *the_chain)
 Returns pointer to chain head. More...
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_head (const Chain_Control *the_chain)
 Returns pointer to immutable chain head. More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Tail (Chain_Control *the_chain)
 Returns pointer to chain tail. More...
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_tail (const Chain_Control *the_chain)
 Returns pointer to immutable chain tail. More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_First (const Chain_Control *the_chain)
 Returns pointer to chain's first node. More...
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_first (const Chain_Control *the_chain)
 Returns pointer to immutable chain's first node. More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Last (const Chain_Control *the_chain)
 Returns pointer to chain's last node. More...
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_last (const Chain_Control *the_chain)
 Returns pointer to immutable chain's last node. More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Next (const Chain_Node *the_node)
 Returns pointer to the next node from this node. More...
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_next (const Chain_Node *the_node)
 Returns pointer to the immutable next node from this node. More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Previous (const Chain_Node *the_node)
 Returns pointer to the previous node from this node. More...
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_previous (const Chain_Node *the_node)
 Returns pointer to the immutable previous node from this node. More...
RTEMS_INLINE_ROUTINE bool _Chain_Is_empty (const Chain_Control *the_chain)
 Checks if the chain is empty. More...
RTEMS_INLINE_ROUTINE bool _Chain_Is_first (const Chain_Node *the_node)
 Checks if this is the first node on the chain. More...
RTEMS_INLINE_ROUTINE bool _Chain_Is_last (const Chain_Node *the_node)
 Checks if this is the last node on the chain. More...
RTEMS_INLINE_ROUTINE bool _Chain_Has_only_one_node (const Chain_Control *the_chain)
 Checks if this chain has only one node. More...
RTEMS_INLINE_ROUTINE bool _Chain_Is_head (const Chain_Control *the_chain, const Chain_Node *the_node)
 Checks if this node is the chain head. More...
RTEMS_INLINE_ROUTINE bool _Chain_Is_tail (const Chain_Control *the_chain, const Chain_Node *the_node)
 Checks if this node is the chain tail. More...
RTEMS_INLINE_ROUTINE void _Chain_Initialize_empty (Chain_Control *the_chain)
 Initializes this chain as empty. More...
RTEMS_INLINE_ROUTINE void _Chain_Initialize_one (Chain_Control *the_chain, Chain_Node *the_node)
 Initializes this chain to contain exactly the specified node. More...
RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected (Chain_Node *the_node)
 Extracts this node (unprotected). More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Get_first_unprotected (Chain_Control *the_chain)
 Gets the first node (unprotected). More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Get_unprotected (Chain_Control *the_chain)
RTEMS_INLINE_ROUTINE void _Chain_Insert_unprotected (Chain_Node *after_node, Chain_Node *the_node)
 Inserts a node (unprotected). More...
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected (Chain_Control *the_chain, Chain_Node *the_node)
 Appends a node (unprotected). More...
RTEMS_INLINE_ROUTINE void _Chain_Append_if_is_off_chain_unprotected (Chain_Control *the_chain, Chain_Node *the_node)
 Appends a node on the end of a chain if the node is in the off chain state (unprotected). More...
RTEMS_INLINE_ROUTINE void _Chain_Prepend_unprotected (Chain_Control *the_chain, Chain_Node *the_node)
 Prepends a node (unprotected). More...
RTEMS_INLINE_ROUTINE bool _Chain_Append_with_empty_check_unprotected (Chain_Control *the_chain, Chain_Node *the_node)
 Appends a node and checks if the chain was empty before (unprotected). More...
RTEMS_INLINE_ROUTINE bool _Chain_Prepend_with_empty_check_unprotected (Chain_Control *the_chain, Chain_Node *the_node)
 Prepends a node and checks if the chain was empty before (unprotected). More...
RTEMS_INLINE_ROUTINE bool _Chain_Get_with_empty_check_unprotected (Chain_Control *the_chain, Chain_Node **the_node)
 Gets the first node and checks if the chain is empty afterwards (unprotected). More...
RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected (Chain_Control *the_chain, Chain_Node *to_insert, const void *left, Chain_Node_order order)
 Inserts a node into the chain according to the order relation. More...
RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_initialize (Chain_Iterator_registry *the_registry)
 Initializes a chain iterator registry. More...
RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_update (Chain_Iterator_registry *the_registry, Chain_Node *the_node_to_extract)
 Updates all iterators present in the chain iterator registry in case of a node extraction. More...
RTEMS_INLINE_ROUTINE void _Chain_Iterator_initialize (Chain_Control *the_chain, Chain_Iterator_registry *the_registry, Chain_Iterator *the_iterator, Chain_Iterator_direction direction)
 Initializes the chain iterator. More...
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Iterator_next (const Chain_Iterator *the_iterator)
 Returns the next node in the iterator direction. More...
RTEMS_INLINE_ROUTINE void _Chain_Iterator_set_position (Chain_Iterator *the_iterator, Chain_Node *the_node)
 Sets the iterator position. More...
RTEMS_INLINE_ROUTINE void _Chain_Iterator_destroy (Chain_Iterator *the_iterator)
 Destroys the iterator. More...
The Chain Handler is used to manage sets of entities. This handler provides two data structures. The Chain Node data structure is included as the first part of every data structure that will be placed on a chain. The second data structure is Chain Control which is used to manage a set of Chain Nodes.
◆ CHAIN_INITIALIZER_ONE_NODE
#define CHAIN_INITIALIZER_ONE_NODE (   node)    { { { (node), NULL }, (node) } }
See also
CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN().
◆ CHAIN_ITERATOR_REGISTRY_INITIALIZER
#define CHAIN_ITERATOR_REGISTRY_INITIALIZER (   name)    { CHAIN_INITIALIZER_EMPTY( name.Iterators ) }
Parameters
nameThe designator of the chain iterator registry.
◆ CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN
#define CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN (   chain)    { &(chain)->Tail.Node, &(chain)->Head.Node }
See also
CHAIN_INITIALIZER_ONE_NODE().
Typedef Documentation
◆ Chain_Node
This type definition promotes the name for the Chain Node used by all RTEMS code. It is a separate type definition because a forward reference is required to define it. See Chain_Node_struct for detailed information.
◆ Chain_Node_order
typedef bool( * Chain_Node_order) (const void *left, const Chain_Node *right)
Chain node order.
Parameters
leftThe left hand side.
rightThe right hand side.
Return values
trueAccording to the order the left node precedes the right node.
falseOtherwise.
◆ Chain_Iterator_direction
Iteration from head to tail.
Iteration from tail to head.
◆ _Chain_Append_if_is_off_chain_unprotected()
RTEMS_INLINE_ROUTINE void _Chain_Append_if_is_off_chain_unprotected ( Chain_Control *  the_chain,
Chain_Node *  the_node
Parameters
[in,out]the_chainThe chain to be operated upon.
[in,out]the_nodeThe node to be appended if it is in the off chain.
Note
It does NOT disable interrupts to ensure the atomicity of the append operation.
See also
_Chain_Append_unprotected() and _Chain_Is_node_off_chain().
◆ _Chain_Append_unprotected()
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected ( Chain_Control *  the_chain,
This routine appends the_node onto the end of the_chain.
Parameters
[out]the_nodeThe node to be appended to the end of the_chain.
Note
◆ _Chain_Append_with_empty_check_unprotected()
RTEMS_INLINE_ROUTINE bool _Chain_Append_with_empty_check_unprotected ( Chain_Control *  the_chain,
Parameters
Note
Return values
trueThe chain was empty before.
falseThe chain contained at least one node before.
◆ _Chain_Are_nodes_equal()
RTEMS_INLINE_ROUTINE bool _Chain_Are_nodes_equal ( const Chain_Node *  left,
const Chain_Node *  right
This function returns true if left and right are equal, and false otherwise.
Parameters
leftThe node on the left hand side of the comparison.
rightThe node on the right hand side of the comparison.
Return values
trueleft and right are equal.
falseleft and right are not equal.
◆ _Chain_Extract_unprotected()
RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected ( Chain_Node *  the_node)
This routine extracts the_node from the chain on which it resides. It does NOT disable interrupts to ensure the atomicity of the extract operation.
Parameters
[out]the_nodeThe node to be extracted.
◆ _Chain_First()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_First ( const Chain_Control *  the_chain)
This function returns a pointer to the first node on the chain after the head.
Parameters
Returns
This method returns the first node of the chain.
◆ _Chain_Get_first_unprotected()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Get_first_unprotected ( Chain_Control *  the_chain)
This function removes the first node from the_chain and returns a pointer to that node. It does NOT disable interrupts to ensure the atomicity of the get operation.
Parameters
[in,out]the_chainThe chain to attempt to get the first node from.
Returns
This method returns the first node on the chain even if it is the Chain Tail.
Note
This routine assumes that there is at least one node on the chain and always returns a node even if it is the Chain Tail.
◆ _Chain_Get_unprotected()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Get_unprotected ( Chain_Control *  the_chain)
This function removes the first node from the_chain and returns a pointer to that node. If the_chain is empty, then NULL is returned.
Parameters
Return values
pointerPointer to the first node. The chain contained at least one node.
NULLThe chain is empty.
Note
◆ _Chain_Get_with_empty_check_unprotected()
RTEMS_INLINE_ROUTINE bool _Chain_Get_with_empty_check_unprotected ( Chain_Control *  the_chain,
Chain_Node **  the_node
This function removes the first node from the_chain and returns a pointer to that node in the_node. If the_chain is empty, then NULL is returned.
Parameters
[out]the_nodeThe first node on the chain or NULL if the chain is empty.
Note
Return values
trueThe chain is empty now.
falseThe chain contains at least one node now.
◆ _Chain_Has_only_one_node()
RTEMS_INLINE_ROUTINE bool _Chain_Has_only_one_node ( const Chain_Control *  the_chain)
This function returns true if there is only one node on the_chain and false otherwise.
Parameters
the_chainis the chain to be operated upon.
Return values
trueThere is only one node on the_chain.
falseThere is more than one node on the_chain.
◆ _Chain_Head()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Head ( Chain_Control *  the_chain)
This function returns a pointer to the head node on the chain.
Parameters
[in]the_chainThe chain to be operated upon.
Returns
This method returns the permanent head node of the chain.
◆ _Chain_Immutable_first()
RTEMS_INLINE_ROUTINE const Chain_Node* _Chain_Immutable_first ( const Chain_Control *  the_chain)
Parameters
Returns
◆ _Chain_Immutable_head()
RTEMS_INLINE_ROUTINE const Chain_Node* _Chain_Immutable_head ( const Chain_Control *  the_chain)
Parameters
Returns
◆ _Chain_Immutable_last()
RTEMS_INLINE_ROUTINE const Chain_Node* _Chain_Immutable_last ( const Chain_Control *  the_chain)
This function returns a pointer to the last node on the chain just before the tail.
Parameters
Returns
This method returns the last node of the chain.
◆ _Chain_Immutable_next()
RTEMS_INLINE_ROUTINE const Chain_Node* _Chain_Immutable_next ( const Chain_Node *  the_node)
This function returns a pointer to the next node after this node.
Parameters
the_nodeThe node to be operated upon.
Returns
This method returns the next node on the chain.
◆ _Chain_Immutable_previous()
RTEMS_INLINE_ROUTINE const Chain_Node* _Chain_Immutable_previous ( const Chain_Node *  the_node)
This function returns a pointer to the previous node on this chain.
Parameters
Returns
This method returns the previous node on the chain.
◆ _Chain_Immutable_tail()
RTEMS_INLINE_ROUTINE const Chain_Node* _Chain_Immutable_tail ( const Chain_Control *  the_chain)
This function returns a pointer to the tail node on the chain.
Parameters
Returns
This method returns the permanent tail node of the chain.
◆ _Chain_Initialize()
void _Chain_Initialize ( Chain_Control *  the_chain,
void *  starting_address,
size_t  node_size
This routine initializes the_chain structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
Parameters
[out]the_chainSpecifies the chain to initialize.
starting_addressThe starting address of the array of elements.
number_nodesThe number of nodes that will be in the chain.
node_sizeThe size of each node.
◆ _Chain_Initialize_empty()
RTEMS_INLINE_ROUTINE void _Chain_Initialize_empty ( Chain_Control *  the_chain)
This routine initializes the specified chain to contain zero nodes.
Parameters
[out]the_chainThe chain to be initialized.
◆ _Chain_Initialize_node()
RTEMS_INLINE_ROUTINE void _Chain_Initialize_node ( Chain_Node *  the_node)
In debug configurations, the node is set off chain. In all other configurations, this function does nothing.
Parameters
[out]the_nodeThe chain node to initialize.
◆ _Chain_Initialize_one()
RTEMS_INLINE_ROUTINE void _Chain_Initialize_one ( Chain_Control *  the_chain,
Parameters
[out]the_chainThe chain to be initialized to contain exactly the specified node.
[out]the_nodeThe one and only node of the chain to be initialized.
◆ _Chain_Insert_ordered_unprotected()
RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected ( Chain_Control *  the_chain,
Chain_Node *  to_insert,
const void *  left,
After the operation the chain contains the node to insert and the order relation holds for all nodes from the head up to the inserted node. Nodes after the inserted node are not moved.
Parameters
[out]to_insertThe node to insert.
leftThe left hand side passed to the order relation. It must correspond to the node to insert. The separate left hand side parameter may help the compiler to generate better code if it is stored in a local variable.
orderThe order relation.
◆ _Chain_Insert_unprotected()
RTEMS_INLINE_ROUTINE void _Chain_Insert_unprotected ( Chain_Node *  after_node,
This routine inserts the_node on a chain immediately following after_node.
Parameters
[in,out]after_nodeThe node which will precede the_node on the chain.
[out]the_nodeThe node to be inserted after after_node.
Note
◆ _Chain_Is_empty()
RTEMS_INLINE_ROUTINE bool _Chain_Is_empty ( const Chain_Control *  the_chain)
This function returns true if there are no nodes on the_chain and false otherwise.
Parameters
the_chainThe chain to check if it is empty.
Return values
trueThere are no nodes on the_chain.
falseThere are nodes on the_chain.
◆ _Chain_Is_first()
RTEMS_INLINE_ROUTINE bool _Chain_Is_first ( const Chain_Node *  the_node)
This function returns true if the_node is the first node on a chain and false otherwise.
Parameters
the_nodeThe node of which the caller wants to know if it is the first node on a chain.
Return values
truethe_node is the first node on a chain.
falsethe_node is not the first node on a chain.
◆ _Chain_Is_head()
RTEMS_INLINE_ROUTINE bool _Chain_Is_head ( const Chain_Control *  the_chain,
This function returns true if the_node is the head of the_chain and false otherwise.
Parameters
the_nodeThe node to check for being the Chain Head.
Return values
truethe_node is the head of the_chain.
falsethe_node is not the head of the_chain.
◆ _Chain_Is_last()
RTEMS_INLINE_ROUTINE bool _Chain_Is_last ( const Chain_Node *  the_node)
This function returns true if the_node is the last node on a chain and false otherwise.
Parameters
the_nodeThe node of which the caller wants to know if it is the last node on a chain.
Return values
truethe_node is the last node on a chain.
falsethe_node is not the last node on a chain.
◆ _Chain_Is_node_off_chain()
RTEMS_INLINE_ROUTINE bool _Chain_Is_node_off_chain ( const Chain_Node *  node)
This function returns true if the node is not on a chain. A node is off chain if the next field is set to NULL.
Parameters
nodeThe node to check if it is off chain.
Return values
trueThe node is off chain.
falseThe node is not off chain.
◆ _Chain_Is_null_node()
RTEMS_INLINE_ROUTINE bool _Chain_Is_null_node ( const Chain_Node *  the_node)
This function returns true if the_node is NULL and false otherwise.
Parameters
the_nodeThe node pointer to check.
Return values
truethe_node is NULL.
falsethe_node is not NULL.
◆ _Chain_Is_tail()
RTEMS_INLINE_ROUTINE bool _Chain_Is_tail ( const Chain_Control *  the_chain,
This function returns true if the_node is the tail of the_chain and false otherwise.
Parameters
the_nodeThe node to check for being the Chain Tail.
Return values
truethe_node is the tail of the_chain.
falsethe_node is not the tail of the_chain.
◆ _Chain_Iterator_destroy()
RTEMS_INLINE_ROUTINE void _Chain_Iterator_destroy ( Chain_Iterator *  the_iterator)
Removes the iterator from its registry.
Parameters
[out]the_iteratorThe chain iterator.
◆ _Chain_Iterator_initialize()
RTEMS_INLINE_ROUTINE void _Chain_Iterator_initialize ( Chain_Control *  the_chain,
Chain_Iterator_registry *  the_registry,
Chain_Iterator *  the_iterator,
In the following example nodes inserted during the iteration are visited in case they are inserted after the current position in iteration order.
typedef struct {
} Some_Control;
void iterate(
Some_Control *the_some,
void ( *visitor )( Chain_Node * )
ISR_lock_Context lock_context;
Chain_Node *node;
const Chain_Node *end;
end = _Chain_Immutable_tail( &the_some->Chain );
_ISR_lock_ISR_disable_and_acquire( &the_some->Lock, &lock_context );
&the_some->Chain,
&the_some->Iterators,
&iter,
while ( ( node = _Chain_Iterator_next( &iter ) ) != end ) {
_ISR_lock_Release_and_ISR_enable( &the_some->Lock, &lock_context );
( *visitor )( node );
Parameters
[out]the_chainThe chain to iterate.
[in,out]the_registryThe registry for the chain iterator.
[out]the_iteratorThe chain iterator to initialize.
[out]directionThe iteration direction.
See also
_Chain_Iterator_next(), _Chain_Iterator_set_position() and Chain_Iterator_destroy().
Warning
Think twice before you use a chain iterator. Its current implementation is unfit for use in performance relevant components, due to the linear time complexity in _Chain_Iterator_registry_update().
◆ _Chain_Iterator_next()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Iterator_next ( const Chain_Iterator *  the_iterator)
In case a next node exists, then the iterator should be updated via _Chain_Iterator_set_position() to continue with the next iteration step.
Parameters
[in,out]the_iteratorThe chain iterator.
Returns
The next node in the iterator direction
◆ _Chain_Iterator_registry_initialize()
RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_initialize ( Chain_Iterator_registry *  the_registry)
Parameters
[out]the_registryThe chain iterator registry to be initialized.
◆ _Chain_Iterator_registry_update()
RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_update ( Chain_Iterator_registry *  the_registry,
Chain_Node *  the_node_to_extract
Must be called before _Chain_Extract_unprotected().
Warning
This function will look at all registered chain iterators to determine if an update is necessary.
Parameters
[in,out]the_registrythe chain iterator registry.
[out]the_node_to_extractThe node that will be extracted.
◆ _Chain_Iterator_set_position()
RTEMS_INLINE_ROUTINE void _Chain_Iterator_set_position ( Chain_Iterator *  the_iterator,
Parameters
[out]the_nodeThe new iterator position.
◆ _Chain_Last()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Last ( const Chain_Control *  the_chain)
Parameters
Returns
◆ _Chain_Next()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Next ( const Chain_Node *  the_node)
Parameters
Returns
◆ _Chain_Node_count_unprotected()
size_t _Chain_Node_count_unprotected ( const Chain_Control *  chain)
Parameters
chainThe chain to return the node count from.
Note
It does NOT disable interrupts to ensure the atomicity of the operation.
Returns
The node count of the chain.
◆ _Chain_Prepend_unprotected()
RTEMS_INLINE_ROUTINE void _Chain_Prepend_unprotected ( Chain_Control *  the_chain,
This routine prepends the_node onto the front of the_chain.
Parameters
[in,out]the_nodeThe node to be prepended to the front of the_chain.
Note
It does NOT disable interrupts to ensure the atomicity of the prepend operation.
◆ _Chain_Prepend_with_empty_check_unprotected()
RTEMS_INLINE_ROUTINE bool _Chain_Prepend_with_empty_check_unprotected ( Chain_Control *  the_chain,
Parameters
[out]the_nodeThe node to be prepended to the front of the_chain.
Note
Return values
◆ _Chain_Previous()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Previous ( const Chain_Node *  the_node)
Parameters
Returns
◆ _Chain_Set_off_chain()
RTEMS_INLINE_ROUTINE void _Chain_Set_off_chain ( Chain_Node *  node)
Sets off chain.
This function sets the next field of the node to NULL indicating the node is not part of a chain.
Parameters
[out]nodeThe node to set off chain.
◆ _Chain_Tail()
RTEMS_INLINE_ROUTINE Chain_Node* _Chain_Tail ( Chain_Control *  the_chain)
Parameters
Returns
