RTEMS  5.1
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Watchdog Handler
Watchdog Handler. More...
file  watchdog.h
 Constants and Structures Associated with Watchdog Timers.
file  watchdogimpl.h
 Inlined Routines in the Watchdog Handler.
file  watchdogticks.h
 Constants for the watchdog ticks.
file  watchdoginsert.c
 Watchdog Insert.
file  watchdogremove.c
 Remove Watchdog.
file  watchdogtickssinceboot.c
 Watchdog Ticks Since Boot.
struct  Watchdog_Header
 The watchdog header to manage scheduled watchdogs. More...
struct  Watchdog_Control
 The control block used to manage each watchdog timer. More...
#define WATCHDOG_INITIALIZER(routine)
 Watchdog initializer for static initialization. More...
#define _Watchdog_Tickle(header, first, now, lock, lock_context)   _Watchdog_Do_tickle( header, first, now, lock_context )
#define WATCHDOG_MAXIMUM_TICKS   UINT64_MAX
 The maximum watchdog ticks value for the far future.
#define WATCHDOG_NANOSECONDS_PER_SECOND   1000000000
#define WATCHDOG_BITS_FOR_1E9_NANOSECONDS   30
 The bits necessary to store 1000000000 (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds. More...
#define WATCHDOG_MAX_SECONDS   0x3ffffffff
 The maximum number of seconds representable in the nanoseconds watchdog format. More...
#define WATCHDOG_NO_TIMEOUT   0
 Special watchdog ticks value to indicate an infinite wait.
#define WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT   50
 Default value for the watchdog ticks per timeslice.
typedef struct Watchdog_Control Watchdog_Control
typedef void Watchdog_Service_routine
 Return type from a Watchdog Service Routine. More...
typedef Watchdog_Service_routine(* Watchdog_Service_routine_entry) (Watchdog_Control *)
 Pointer to a watchdog service routine. More...
typedef uint32_t Watchdog_Interval
 Type is used to specify the length of intervals. More...
enum  Watchdog_State { WATCHDOG_SCHEDULED_BLACK, WATCHDOG_SCHEDULED_RED, WATCHDOG_INACTIVE, WATCHDOG_PENDING }
 Watchdog states. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Header_initialize (Watchdog_Header *header)
 Initializes the watchdog header. More...
RTEMS_INLINE_ROUTINE Watchdog_Control * _Watchdog_Header_first (const Watchdog_Header *header)
 Returns the first of the watchdog header. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Header_destroy (Watchdog_Header *header)
 Destroys the watchdog header. More...
void _Watchdog_Tick (struct Per_CPU_Control *cpu)
 Performs a watchdog tick. More...
RTEMS_INLINE_ROUTINE Watchdog_State _Watchdog_Get_state (const Watchdog_Control *the_watchdog)
 Gets the state of the watchdog. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Set_state (Watchdog_Control *the_watchdog, Watchdog_State state)
 Sets the state of the watchdog. More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Watchdog_Get_CPU (const Watchdog_Control *the_watchdog)
 Gets the watchdog's cpu. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Set_CPU (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu)
 Sets the cpu for the watchdog. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Preinitialize (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu)
 Pre-initializes a watchdog. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Initialize (Watchdog_Control *the_watchdog, Watchdog_Service_routine_entry routine)
 Initializes a watchdog with a new service routine. More...
void _Watchdog_Do_tickle (Watchdog_Header *header, Watchdog_Control *first, uint64_t now, ISR_lock_Context *lock_context)
 Calls the routine of each not expired watchdog control node. More...
void _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t expire)
 Inserts a watchdog into the set of scheduled watchdogs according to the specified expiration time. More...
void _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 In the case the watchdog is scheduled, then it is removed from the set of scheduled watchdogs. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Cancel (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t now)
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_scheduled (const Watchdog_Control *the_watchdog)
 Checks if the watchdog is scheduled. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Next_first (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 Sets the first node of the header. More...
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_timespec (const struct timespec *ts)
 Checks if the timespec is a valid timespec for a watchdog. More...
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_interval_timespec (const struct timespec *ts)
 Checks if the timespec is a valid interval timespec for a watchdog. More...
RTEMS_INLINE_ROUTINE const struct timespec * _Watchdog_Future_timespec (struct timespec *now, const struct timespec *delta)
 Adds the delta timespec to the current time if the delta is a valid interval timespec. More...
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_far_future_timespec (const struct timespec *ts)
 Checks if the timespec is too far in the future. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds (uint32_t seconds)
 Converts the seconds to ticks. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec (const struct timespec *ts)
 Converts the timespec in ticks. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_sbintime (int64_t sbt)
 Converts the sbintime in ticks. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_acquire_critical (Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
 Acquires the per cpu watchdog lock in a critical section. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_release_critical (Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
 Releases the per cpu watchdog lock in a critical section. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Interval ticks)
 Sets the watchdog's cpu to the given instance and sets its expiration time to the watchdog expiration time of the cpu plus the ticks. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header, uint64_t expire)
 Sets the watchdog's cpu and inserts it with the given expiration time in the scheduled watchdogs. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header)
 Removes the watchdog from the cpu and the scheduled watchdogs. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_ticks (Watchdog_Control *the_watchdog)
volatile Watchdog_Interval _Watchdog_Ticks_since_boot
 The watchdog ticks counter. More...
const uint32_t _Watchdog_Microseconds_per_tick
 The watchdog microseconds per tick. More...
const uint32_t _Watchdog_Nanoseconds_per_tick
 The watchdog nanoseconds per tick. More...
const uint32_t _Watchdog_Ticks_per_second
 The watchdog ticks per second. More...
const uint32_t _Watchdog_Ticks_per_timeslice
 The watchdog ticks per timeslice. More...
Watchdog Handler.
This handler encapsulates functionality related to the scheduling of watchdog functions to be called at specific times in the future.
Note
This handler does not have anything to do with hardware watchdog timers.
◆ WATCHDOG_BITS_FOR_1E9_NANOSECONDS
The expiration time is an unsigned 64-bit integer. To store nanoseconds timeouts we use 30 bits (2**30 == 1073741824) for the nanoseconds and 34 bits for the seconds since UNIX Epoch. This leads to a year 2514 problem.
◆ WATCHDOG_INITIALIZER
#define WATCHDOG_INITIALIZER (   routine)
Value:
{ { { NULL, NULL, NULL, WATCHDOG_INACTIVE } } }, \
( routine ), \
0 \
The watchdog is inactive.
Definition: watchdogimpl.h:61
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
The processor of this watchdog is set to processor with index zero.
See also
_Watchdog_Preinitialize().
◆ WATCHDOG_MAX_SECONDS
We have 2**34 bits for the seconds part.
Typedef Documentation
◆ Watchdog_Interval
This type is used to specify the length of intervals.
◆ Watchdog_Service_routine
This type defines the return type from a Watchdog Service Routine.
◆ Watchdog_Service_routine_entry
typedef Watchdog_Service_routine( * Watchdog_Service_routine_entry) (Watchdog_Control *)
This type define a pointer to a watchdog service routine.
◆ Watchdog_State
Watchdog states.
The watchdog is scheduled and a black node in the red-black tree.
The watchdog is scheduled and a red node in the red-black tree.
WATCHDOG_INACTIVE
WATCHDOG_PENDING
The watchdog is on a chain of pending watchdogs.
This state is used by the timer server for example.
◆ _Watchdog_Cancel()
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Cancel ( Watchdog_Header *  header,
Watchdog_Control *  the_watchdog,
uint64_t  now
The watchdog must be initialized before this call.
Parameters
[in,out]headerThe scheduled watchdogs.
[in,out]the_watchdogThe watchdog to remove.
nowThe current time.
Return values
otherThe difference of the now and expiration time.
0The now time is greater than or equal to the expiration time of the watchdog.
◆ _Watchdog_Do_tickle()
void _Watchdog_Do_tickle ( Watchdog_Header *  header,
Watchdog_Control *  first,
uint64_t  now,
ISR_lock_Context *  lock_context
Parameters
headerThe watchdog header.
firstThe first watchdog control node.
nowThe current time to check the expiration time against.
lockThe lock that is released before calling the routine and then acquired after the call.
lock_contextThe lock context for the release before calling the routine and for the acquire after.
◆ _Watchdog_Future_timespec()
RTEMS_INLINE_ROUTINE const struct timespec* _Watchdog_Future_timespec ( struct timespec *  now,
const struct timespec *  delta
Parameters
[in,out]nowThe current time.
deltaThe delta timespec for the addition.
Return values
pointerPointer to the now timespec.
NULLdelta is not a valid interval timespec.
◆ _Watchdog_Get_CPU()
RTEMS_INLINE_ROUTINE Per_CPU_Control* _Watchdog_Get_CPU ( const Watchdog_Control *  the_watchdog)
Parameters
the_watchdogThe watchdog to get the cpu of.
Returns
The cpu of the watchdog.
◆ _Watchdog_Get_state()
RTEMS_INLINE_ROUTINE Watchdog_State _Watchdog_Get_state ( const Watchdog_Control *  the_watchdog)
Parameters
the_watchdogThe watchdog to get the state of.
Returns
The RB_COLOR of the_watchdog.
◆ _Watchdog_Header_destroy()
RTEMS_INLINE_ROUTINE void _Watchdog_Header_destroy ( Watchdog_Header *  header)
Parameters
headerThe watchdog header to destroy.
◆ _Watchdog_Header_first()
RTEMS_INLINE_ROUTINE Watchdog_Control* _Watchdog_Header_first ( const Watchdog_Header *  header)
Parameters
headerThe watchdog header to remove the first of.
Returns
The first of header.
◆ _Watchdog_Header_initialize()
RTEMS_INLINE_ROUTINE void _Watchdog_Header_initialize ( Watchdog_Header *  header)
Parameters
[out]headerThe header to initialize.
◆ _Watchdog_Initialize()
RTEMS_INLINE_ROUTINE void _Watchdog_Initialize ( Watchdog_Control *  the_watchdog,
The watchdog must be inactive.
Parameters
[out]the_watchdogThe watchdog to initialize.
routingThe service routine for the_watchdog.
◆ _Watchdog_Insert()
void _Watchdog_Insert ( Watchdog_Header *  header,
uint64_t  expire
Parameters
[in,out]headerThe set of scheduler watchdogs to insert into.
[in,out]the_watchdogThe watchdog to insert.
expireThe expiration time for the watchdog.
◆ _Watchdog_Is_far_future_timespec()
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_far_future_timespec ( const struct timespec *  ts)
Parameters
tsThe timespec for the verification.
Return values
truets is too far in the future.
falsets is not too far in the future.
◆ _Watchdog_Is_scheduled()
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_scheduled ( const Watchdog_Control *  the_watchdog)
Parameters
the_watchdogThe watchdog for the verification.
Return values
trueThe watchdog is scheduled.
falseThe watchdog is inactive.
◆ _Watchdog_Is_valid_interval_timespec()
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_interval_timespec ( const struct timespec *  ts)
Parameters
Return values
trueThe timespec is a valid interval timespec.
falseThe timespec is invalid.
◆ _Watchdog_Is_valid_timespec()
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_timespec ( const struct timespec *  ts)
Parameters
Return values
trueThe timespec is a valid timespec.
◆ _Watchdog_Next_first()
RTEMS_INLINE_ROUTINE void _Watchdog_Next_first ( Watchdog_Header *  header,
Sets the first node of the header to either the leftmost child node of the watchdog control node, or if not present sets it to the right child node of the watchdog control node. if both are not present, the new first node is the parent node of the current first node.
Parameters
[in,out]headerThe watchdog header.
the_watchdogThe watchdog control node for the operation.
◆ _Watchdog_Per_CPU_acquire_critical()
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_acquire_critical ( Per_CPU_Control *  cpu,
Parameters
cpuThe cpu to acquire the watchdog lock of.
lock_contextThe lock context.
◆ _Watchdog_Per_CPU_insert()
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert ( Watchdog_Control *  the_watchdog,
uint64_t  expire
Parameters
[in,out]the_watchdogThe watchdog to set cpu and expiration time of.
cpuThe cpu for the operation.
Returns
The expiration time of the watchdog.
◆ _Watchdog_Per_CPU_insert_ticks()
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks ( Watchdog_Control *  the_watchdog,
Parameters
[in,out]the_watchdogThe watchdog to set the cpu and expiration time of.
cpuThe cpu for the watchdog.
ticksThe ticks to add to the expiration time.
Returns
The new expiration time of the watchdog.
◆ _Watchdog_Per_CPU_release_critical()
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_release_critical ( Per_CPU_Control *  cpu,
Parameters
cpuThe cpu to release the watchdog lock of.
◆ _Watchdog_Per_CPU_remove()
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove ( Watchdog_Control *  the_watchdog,
Parameters
cpuThe cpu to remove the watchdog from.
[in,out]Thescheduled watchdogs.
◆ _Watchdog_Per_CPU_remove_ticks()
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_ticks ( Watchdog_Control *  the_watchdog)
Parameters
◆ _Watchdog_Preinitialize()
RTEMS_INLINE_ROUTINE void _Watchdog_Preinitialize ( Watchdog_Control *  the_watchdog,
This routine must be called before a watchdog is used in any way. The exception are statically initialized watchdogs via WATCHDOG_INITIALIZER().
Parameters
[out]the_watchdogThe uninitialized watchdog.
◆ _Watchdog_Remove()
void _Watchdog_Remove ( Watchdog_Header *  header,
Parameters
◆ _Watchdog_Set_CPU()
RTEMS_INLINE_ROUTINE void _Watchdog_Set_CPU ( Watchdog_Control *  the_watchdog,
Parameters
[out]the_watchdogThe watchdog to set the cpu of.
cpuThe cpu to be set as the_watchdog's cpu.
◆ _Watchdog_Set_state()
RTEMS_INLINE_ROUTINE void _Watchdog_Set_state ( Watchdog_Control *  the_watchdog,
Parameters
[out]the_watchdogThe watchdog to set the state of.
stateThe state to set the watchdog to.
◆ _Watchdog_Tick()
void _Watchdog_Tick ( struct Per_CPU_Control *  cpu)
Parameters
cpuThe processor for this watchdog tick.
◆ _Watchdog_Ticks_from_sbintime()
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_sbintime ( int64_t  sbt)
Parameters
sbtThe sbintime to convert to ticks.
Returns
sbt converted to ticks.
◆ _Watchdog_Ticks_from_seconds()
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds ( uint32_t  seconds)
Parameters
secondsThe seconds to convert to ticks.
Returns
seconds converted to ticks.
◆ _Watchdog_Ticks_from_timespec()
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec ( const struct timespec *  ts)
Parameters
tsThe timespec to convert to ticks.
Returns
ts converted to ticks.
Variable Documentation
◆ _Watchdog_Microseconds_per_tick
This constant is defined by the application configuration via <rtems/confdefs.h>.
◆ _Watchdog_Nanoseconds_per_tick
◆ _Watchdog_Ticks_per_second
◆ _Watchdog_Ticks_per_timeslice
◆ _Watchdog_Ticks_since_boot
With a 1ms watchdog tick, this counter overflows after 50 days since boot.
