RTEMS  5.1
Macros | Enumerations | Functions
watchdogimpl.h File Reference
Inlined Routines in the Watchdog Handler. More...
#include <rtems/score/watchdogticks.h>
#include <rtems/score/isrlock.h>
#include <rtems/score/rbtreeimpl.h>
#include <sys/types.h>
#include <sys/timespec.h>
#define WATCHDOG_INITIALIZER(routine)
 Watchdog initializer for static initialization. More...
#define _Watchdog_Tickle(header, first, now, lock, lock_context)   _Watchdog_Do_tickle( header, first, now, lock_context )
#define WATCHDOG_MAXIMUM_TICKS   UINT64_MAX
 The maximum watchdog ticks value for the far future.
#define WATCHDOG_NANOSECONDS_PER_SECOND   1000000000
#define WATCHDOG_BITS_FOR_1E9_NANOSECONDS   30
 The bits necessary to store 1000000000 (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds. More...
#define WATCHDOG_MAX_SECONDS   0x3ffffffff
 The maximum number of seconds representable in the nanoseconds watchdog format. More...
enum  Watchdog_State { WATCHDOG_SCHEDULED_BLACK, WATCHDOG_SCHEDULED_RED, WATCHDOG_INACTIVE, WATCHDOG_PENDING }
 Watchdog states. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Header_initialize (Watchdog_Header *header)
 Initializes the watchdog header. More...
RTEMS_INLINE_ROUTINE Watchdog_Control * _Watchdog_Header_first (const Watchdog_Header *header)
 Returns the first of the watchdog header. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Header_destroy (Watchdog_Header *header)
 Destroys the watchdog header. More...
void _Watchdog_Tick (struct Per_CPU_Control *cpu)
 Performs a watchdog tick. More...
RTEMS_INLINE_ROUTINE Watchdog_State _Watchdog_Get_state (const Watchdog_Control *the_watchdog)
 Gets the state of the watchdog. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Set_state (Watchdog_Control *the_watchdog, Watchdog_State state)
 Sets the state of the watchdog. More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Watchdog_Get_CPU (const Watchdog_Control *the_watchdog)
 Gets the watchdog's cpu. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Set_CPU (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu)
 Sets the cpu for the watchdog. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Preinitialize (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu)
 Pre-initializes a watchdog. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Initialize (Watchdog_Control *the_watchdog, Watchdog_Service_routine_entry routine)
 Initializes a watchdog with a new service routine. More...
void _Watchdog_Do_tickle (Watchdog_Header *header, Watchdog_Control *first, uint64_t now, ISR_lock_Context *lock_context)
 Calls the routine of each not expired watchdog control node. More...
void _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t expire)
 Inserts a watchdog into the set of scheduled watchdogs according to the specified expiration time. More...
void _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 In the case the watchdog is scheduled, then it is removed from the set of scheduled watchdogs. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Cancel (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t now)
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_scheduled (const Watchdog_Control *the_watchdog)
 Checks if the watchdog is scheduled. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Next_first (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 Sets the first node of the header. More...
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_timespec (const struct timespec *ts)
 Checks if the timespec is a valid timespec for a watchdog. More...
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_interval_timespec (const struct timespec *ts)
 Checks if the timespec is a valid interval timespec for a watchdog. More...
RTEMS_INLINE_ROUTINE const struct timespec * _Watchdog_Future_timespec (struct timespec *now, const struct timespec *delta)
 Adds the delta timespec to the current time if the delta is a valid interval timespec. More...
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_far_future_timespec (const struct timespec *ts)
 Checks if the timespec is too far in the future. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds (uint32_t seconds)
 Converts the seconds to ticks. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec (const struct timespec *ts)
 Converts the timespec in ticks. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_sbintime (int64_t sbt)
 Converts the sbintime in ticks. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_acquire_critical (Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
 Acquires the per cpu watchdog lock in a critical section. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_release_critical (Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
 Releases the per cpu watchdog lock in a critical section. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Interval ticks)
 Sets the watchdog's cpu to the given instance and sets its expiration time to the watchdog expiration time of the cpu plus the ticks. More...
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header, uint64_t expire)
 Sets the watchdog's cpu and inserts it with the given expiration time in the scheduled watchdogs. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header)
 Removes the watchdog from the cpu and the scheduled watchdogs. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_ticks (Watchdog_Control *the_watchdog)
This file contains the static inline implementation of all inlined routines in the Watchdog Handler.
