RTEMS  5.1
percpu.h
1
8 /*
9  * COPYRIGHT (c) 1989-2011.
10  * On-Line Applications Research Corporation (OAR).
11  *
12  * Copyright (c) 2012, 2018 embedded brains GmbH
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_PERCPU_H
20 #define _RTEMS_PERCPU_H
21
22 #include <rtems/score/cpuimpl.h>
23
24 #if defined( ASM )
25  #include <rtems/asm.h>
26 #else
27  #include <rtems/score/assert.h>
28  #include <rtems/score/chain.h>
29  #include <rtems/score/isrlock.h>
30  #include <rtems/score/smp.h>
31  #include <rtems/score/timestamp.h>
32  #include <rtems/score/watchdog.h>
33 #endif
34
35 #ifdef __cplusplus
36 extern "C" {
37 #endif
38
39 #if defined(RTEMS_SMP)
40  #if defined(RTEMS_PROFILING)
41  #define PER_CPU_CONTROL_SIZE_APPROX \
42  ( 512 + CPU_PER_CPU_CONTROL_SIZE + CPU_INTERRUPT_FRAME_SIZE )
43  #elif defined(RTEMS_DEBUG) || CPU_SIZEOF_POINTER > 4
44  #define PER_CPU_CONTROL_SIZE_APPROX \
45  ( 256 + CPU_PER_CPU_CONTROL_SIZE + CPU_INTERRUPT_FRAME_SIZE )
46  #else
47  #define PER_CPU_CONTROL_SIZE_APPROX \
48  ( 180 + CPU_PER_CPU_CONTROL_SIZE + CPU_INTERRUPT_FRAME_SIZE )
49  #endif
50
51  /*
52  * This ensures that on SMP configurations the individual per-CPU controls
53  * are on different cache lines to prevent false sharing. This define can be
54  * used in assembler code to easily get the per-CPU control for a particular
55  * processor.
56  */
57  #if PER_CPU_CONTROL_SIZE_APPROX > 1024
58  #define PER_CPU_CONTROL_SIZE_LOG2 11
59  #elif PER_CPU_CONTROL_SIZE_APPROX > 512
60  #define PER_CPU_CONTROL_SIZE_LOG2 10
61  #elif PER_CPU_CONTROL_SIZE_APPROX > 256
62  #define PER_CPU_CONTROL_SIZE_LOG2 9
63  #elif PER_CPU_CONTROL_SIZE_APPROX > 128
64  #define PER_CPU_CONTROL_SIZE_LOG2 8
65  #else
66  #define PER_CPU_CONTROL_SIZE_LOG2 7
67  #endif
68
69  #define PER_CPU_CONTROL_SIZE ( 1 << PER_CPU_CONTROL_SIZE_LOG2 )
70 #endif
71
72 #if !defined( ASM )
73
74 struct Record_Control;
75
76 struct _Thread_Control;
77
78 struct Scheduler_Context;
79
93 #if defined( RTEMS_SMP )
94
128 typedef enum {
137  PER_CPU_STATE_INITIAL,
138
153  PER_CPU_STATE_READY_TO_START_MULTITASKING,
154
163  PER_CPU_STATE_REQUEST_START_MULTITASKING,
164
168  PER_CPU_STATE_UP,
169
173  PER_CPU_STATE_SHUTDOWN
174 } Per_CPU_State;
175
176 typedef void ( *Per_CPU_Job_handler )( void *arg );
177
184 typedef struct {
188  Per_CPU_Job_handler handler;
189
193  void *arg;
194 } Per_CPU_Job_context;
195
196 /*
197  * Value for the Per_CPU_Job::done member to indicate that a job is done
198  * (handler was called on the target processor). Must not be a valid pointer
199  * value since it overlaps with the Per_CPU_Job::next member.
200  */
201 #define PER_CPU_JOB_DONE 1
202
209 typedef struct Per_CPU_Job {
210  union {
214  struct Per_CPU_Job *next;
215
222  Atomic_Ulong done;
223  };
224
228  const Per_CPU_Job_context *context;
229 } Per_CPU_Job;
230
231 #endif /* defined( RTEMS_SMP ) */
232
236 typedef struct {
237 #if defined( RTEMS_PROFILING )
238
243  CPU_Counter_ticks thread_dispatch_disabled_instant;
244
249  CPU_Counter_ticks max_thread_dispatch_disabled_time;
250
258  CPU_Counter_ticks max_interrupt_time;
259
264  CPU_Counter_ticks max_interrupt_delay;
265
272  uint64_t thread_dispatch_disabled_count;
273
283  uint64_t total_thread_dispatch_disabled_time;
284
291  uint64_t interrupt_count;
292
301  uint64_t total_interrupt_time;
302 #endif /* defined( RTEMS_PROFILING ) */
303 } Per_CPU_Stats;
304
308 typedef enum {
317
326
335
341
347 typedef struct Per_CPU_Control {
348  #if CPU_PER_CPU_CONTROL_SIZE > 0
349
352  CPU_Per_CPU_control cpu_per_cpu;
353  #endif
354
359
364
369  uint32_t isr_nest_level;
370
380
385  volatile uint32_t thread_dispatch_disable_level;
386
400  volatile bool dispatch_necessary;
401
402  /*
403  * Ensure that the executing member is at least 4-byte aligned, see
404  * PER_CPU_OFFSET_EXECUTING. This is necessary on CPU ports with relaxed
405  * alignment restrictions, e.g. type alignment is less than the type size.
406  */
407  bool reserved_for_executing_alignment[ 3 ];
408
421
437
438 #if defined(RTEMS_SMP)
439  CPU_Interrupt_frame Interrupt_frame;
440 #endif
441
453
457  struct {
461  ISR_LOCK_MEMBER( Lock )
462
463
467  uint64_t ticks;
468
475  } Watchdog;
476
477  #if defined( RTEMS_SMP )
478
481  ISR_lock_Control Lock;
482
490  ISR_lock_Context Lock_context;
491
497  Chain_Control Threads_in_need_for_help;
498
505  Atomic_Ulong message;
506
507  struct {
514  const struct _Scheduler_Control *control;
515
522  const struct Scheduler_Context *context;
523
528  struct _Thread_Control *idle_if_online_and_unused;
529  } Scheduler;
530
536  struct _Thread_Control *ancestor;
537
543  char *data;
544
552  Per_CPU_State state;
553
559  struct {
564  ISR_lock_Control Lock;
565
572  struct Per_CPU_Job *head;
573
582  struct Per_CPU_Job **tail;
583  } Jobs;
584
589  bool online;
590
595  bool boot;
596  #endif
597
598  struct Record_Control *record;
599
600  Per_CPU_Stats Stats;
602
603 #if defined( RTEMS_SMP )
604 typedef struct {
605  Per_CPU_Control per_cpu;
606  char unused_space_for_cache_line_alignment
607  [ PER_CPU_CONTROL_SIZE - sizeof( Per_CPU_Control ) ];
609 #else
610 typedef struct {
611  Per_CPU_Control per_cpu;
613 #endif
614
620 extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
621
622 #define _Per_CPU_Acquire( cpu, lock_context ) \
623  _ISR_lock_Acquire( &( cpu )->Lock, lock_context )
624
625 #define _Per_CPU_Release( cpu, lock_context ) \
626  _ISR_lock_Release( &( cpu )->Lock, lock_context )
627
628 /*
629  * If we get the current processor index in a context which allows thread
630  * dispatching, then we may already run on another processor right after the
631  * read instruction. There are very few cases in which this makes sense (here
632  * we can use _Per_CPU_Get_snapshot()). All other places must use
633  * _Per_CPU_Get() so that we can add checks for RTEMS_DEBUG.
634  */
635 #if defined( _CPU_Get_current_per_CPU_control )
636  #define _Per_CPU_Get_snapshot() _CPU_Get_current_per_CPU_control()
637 #else
638  #define _Per_CPU_Get_snapshot() \
639  ( &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu )
640 #endif
641
642 #if defined( RTEMS_SMP )
643 static inline Per_CPU_Control *_Per_CPU_Get( void )
644 {
645  Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
646
647  _Assert(
648  cpu_self->thread_dispatch_disable_level != 0 || _ISR_Get_level() != 0
649  );
650
651  return cpu_self;
652 }
653 #else
654 #define _Per_CPU_Get() _Per_CPU_Get_snapshot()
655 #endif
656
657 static inline Per_CPU_Control *_Per_CPU_Get_by_index( uint32_t index )
658 {
659  return &_Per_CPU_Information[ index ].per_cpu;
660 }
661
662 static inline uint32_t _Per_CPU_Get_index( const Per_CPU_Control *cpu )
663 {
664 #if defined(RTEMS_SMP)
665  const Per_CPU_Control_envelope *per_cpu_envelope =
666  ( const Per_CPU_Control_envelope * ) cpu;
667
668  return ( uint32_t ) ( per_cpu_envelope - &_Per_CPU_Information[ 0 ] );
669 #else
670  (void) cpu;
671  return 0;
672 #endif
673 }
674
675 static inline struct _Thread_Control *_Per_CPU_Get_executing(
676  const Per_CPU_Control *cpu
677 )
678 {
679  return cpu->executing;
680 }
681
682 static inline bool _Per_CPU_Is_processor_online(
683  const Per_CPU_Control *cpu
684 )
685 {
686 #if defined( RTEMS_SMP )
687  return cpu->online;
688 #else
689  (void) cpu;
690
691  return true;
692 #endif
693 }
694
695 static inline bool _Per_CPU_Is_boot_processor(
696  const Per_CPU_Control *cpu
697 )
698 {
699 #if defined( RTEMS_SMP )
700  return cpu->boot;
701 #else
702  (void) cpu;
703
704  return true;
705 #endif
706 }
707
708 RTEMS_INLINE_ROUTINE void _Per_CPU_Acquire_all(
709  ISR_lock_Context *lock_context
710 )
711 {
712 #if defined(RTEMS_SMP)
713  uint32_t cpu_max;
714  uint32_t cpu_index;
715  Per_CPU_Control *previous_cpu;
716
717  cpu_max = _SMP_Get_processor_maximum();
718  previous_cpu = _Per_CPU_Get_by_index( 0 );
719
720  _ISR_lock_ISR_disable( lock_context );
721  _Per_CPU_Acquire( previous_cpu, lock_context );
722
723  for ( cpu_index = 1 ; cpu_index < cpu_max ; ++cpu_index ) {
724  Per_CPU_Control *cpu;
725
726  cpu = _Per_CPU_Get_by_index( cpu_index );
727  _Per_CPU_Acquire( cpu, &previous_cpu->Lock_context );
728  previous_cpu = cpu;
729  }
730 #else
731  _ISR_lock_ISR_disable( lock_context );
732 #endif
733 }
734
735 RTEMS_INLINE_ROUTINE void _Per_CPU_Release_all(
736  ISR_lock_Context *lock_context
737 )
738 {
739 #if defined(RTEMS_SMP)
740  uint32_t cpu_max;
741  uint32_t cpu_index;
742  Per_CPU_Control *cpu;
743
744  cpu_max = _SMP_Get_processor_maximum();
745  cpu = _Per_CPU_Get_by_index( cpu_max - 1 );
746
747  for ( cpu_index = cpu_max - 1 ; cpu_index > 0 ; --cpu_index ) {
748  Per_CPU_Control *previous_cpu;
749
750  previous_cpu = _Per_CPU_Get_by_index( cpu_index - 1 );
751  _Per_CPU_Release( cpu, &previous_cpu->Lock_context );
752  cpu = previous_cpu;
753  }
754
755  _Per_CPU_Release( cpu, lock_context );
756  _ISR_lock_ISR_enable( lock_context );
757 #else
758  _ISR_lock_ISR_enable( lock_context );
759 #endif
760 }
761
762 #if defined( RTEMS_SMP )
763
769 void _Per_CPU_Initialize(void);
770
771 void _Per_CPU_State_change(
772  Per_CPU_Control *cpu,
773  Per_CPU_State new_state
774 );
775
801 bool _Per_CPU_State_wait_for_non_initial_state(
802  uint32_t cpu_index,
803  uint32_t timeout_in_ns
804 );
805
811 void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu );
812
824 void _Per_CPU_Add_job( Per_CPU_Control *cpu, Per_CPU_Job *job );
825
835 void _Per_CPU_Wait_for_job(
836  const Per_CPU_Control *cpu,
837  const Per_CPU_Job *job
838 );
839
840 #endif /* defined( RTEMS_SMP ) */
841
842 /*
843  * On a non SMP system, the _SMP_Get_current_processor() is defined to 0.
844  * Thus when built for non-SMP, there should be no performance penalty.
845  */
846 #define _Thread_Dispatch_disable_level \
847  _Per_CPU_Get()->thread_dispatch_disable_level
848 #define _Thread_Heir \
849  _Per_CPU_Get()->heir
850
851 #if defined(_CPU_Get_thread_executing)
852 #define _Thread_Executing \
853  _CPU_Get_thread_executing()
854 #else
855 #define _Thread_Executing \
856  _Per_CPU_Get_executing( _Per_CPU_Get() )
857 #endif
858
859 #define _ISR_Nest_level \
860  _Per_CPU_Get()->isr_nest_level
861 #define _CPU_Interrupt_stack_low \
862  _Per_CPU_Get()->interrupt_stack_low
863 #define _CPU_Interrupt_stack_high \
864  _Per_CPU_Get()->interrupt_stack_high
865 #define _Thread_Dispatch_necessary \
866  _Per_CPU_Get()->dispatch_necessary
867
879 {
880  struct _Thread_Control *executing;
881
882  #if defined(RTEMS_SMP) && !defined(_CPU_Get_thread_executing)
883  ISR_Level level;
884
885  _ISR_Local_disable( level );
886  #endif
887
888  executing = _Thread_Executing;
889
890  #if defined(RTEMS_SMP) && !defined(_CPU_Get_thread_executing)
891  _ISR_Local_enable( level );
892  #endif
893
894  return executing;
895 }
896
899 #endif /* !defined( ASM ) */
900
901 #if defined( ASM ) || defined( _RTEMS_PERCPU_DEFINE_OFFSETS )
902
903 #define PER_CPU_INTERRUPT_STACK_LOW \
904  CPU_PER_CPU_CONTROL_SIZE
905 #define PER_CPU_INTERRUPT_STACK_HIGH \
906  PER_CPU_INTERRUPT_STACK_LOW + CPU_SIZEOF_POINTER
907
908 #define INTERRUPT_STACK_LOW \
909  (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_LOW)
910 #define INTERRUPT_STACK_HIGH \
911  (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_HIGH)
912
913 /*
914  * These are the offsets of the required elements in the per CPU table.
915  */
916 #define PER_CPU_ISR_NEST_LEVEL \
917  PER_CPU_INTERRUPT_STACK_HIGH + CPU_SIZEOF_POINTER
918 #define PER_CPU_ISR_DISPATCH_DISABLE \
919  PER_CPU_ISR_NEST_LEVEL + 4
920 #define PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL \
921  PER_CPU_ISR_DISPATCH_DISABLE + 4
922 #define PER_CPU_DISPATCH_NEEDED \
923  PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL + 4
924 #define PER_CPU_OFFSET_EXECUTING \
925  PER_CPU_DISPATCH_NEEDED + 4
926 #define PER_CPU_OFFSET_HEIR \
927  PER_CPU_OFFSET_EXECUTING + CPU_SIZEOF_POINTER
928 #if defined(RTEMS_SMP)
929 #define PER_CPU_INTERRUPT_FRAME_AREA \
930  PER_CPU_OFFSET_HEIR + CPU_SIZEOF_POINTER
931 #endif
932
933 #define THREAD_DISPATCH_DISABLE_LEVEL \
934  (SYM(_Per_CPU_Information) + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)
935 #define ISR_NEST_LEVEL \
936  (SYM(_Per_CPU_Information) + PER_CPU_ISR_NEST_LEVEL)
937 #define DISPATCH_NEEDED \
938  (SYM(_Per_CPU_Information) + PER_CPU_DISPATCH_NEEDED)
939
940 #endif /* defined( ASM ) || defined( _RTEMS_PERCPU_DEFINE_OFFSETS ) */
941
942 #ifdef __cplusplus
943 }
944 #endif
945
946 #endif
947 /* end of include file */
Per-CPU statistics.
Definition: percpu.h:236
void * interrupt_stack_high
The interrupt stack high address for this processor.
Definition: percpu.h:363
Index for realtime clock per-CPU watchdog header.
Definition: percpu.h:325
Definition: media-server.c:33
int64_t Timestamp_Control
Definition: timestamp.h:57
Count of per-CPU watchdog headers.
Definition: percpu.h:339
Watchdog_Header Header[PER_CPU_WATCHDOG_COUNT]
Header for watchdogs.
Definition: percpu.h:474
Scheduler context.
Definition: scheduler.h:252
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:57
struct _Thread_Control * executing
This is the thread executing on this processor.
Definition: percpu.h:420
Definition: record.h:44
uint64_t ticks
Protects all watchdog operations on this processor.
Definition: percpu.h:467
Interrupt stack frame (ISF).
Definition: cpu.h:191
Definition: chain.h:86
Helpers for Manipulating Timestamps.
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition: isrlock.h:419
Thread_Scheduler_control Scheduler
Scheduler related control.
Definition: thread.h:771
Per_CPU_Control_envelope _Per_CPU_Information [] CPU_STRUCTURE_ALIGNMENT
Set of Per CPU Core Information.
#define _ISR_Get_level()
Return current interrupt level.
Definition: isrlevel.h:128
Timestamp_Control cpu_usage_timestamp
The CPU usage timestamp contains the time point of the last heir thread change or last CPU usage upda...
Definition: percpu.h:452
ISR lock control.
Definition: isrlock.h:56
SuperCore SMP Support API.
Definition: percpu.h:610
Information for the Assert Handler.
Per_CPU_Watchdog_index
Per-CPU watchdog header index.
Definition: percpu.h:308
The CPU specific per-CPU control.
Definition: cpuimpl.h:54
Definition: thread.h:732
#define ISR_LOCK_MEMBER(_designator)
Defines an ISR lock member.
Definition: isrlock.h:89
Per CPU Core Structure.
Definition: percpu.h:347
uint32_t ISR_Level
Definition: isrlevel.h:41
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:74
Definition: percpu.h:369
void * interrupt_stack_low
The interrupt stack low address for this processor.
Definition: percpu.h:358
Constants and Structures Associated with Watchdog Timers.
uint32_t isr_dispatch_disable
Indicates if an ISR thread dispatch is disabled.
Definition: percpu.h:379
Definition: intercom.c:74
This is set to true when this processor needs to run the thread dispatcher.
Definition: percpu.h:400
struct _Thread_Control * heir
This is the heir thread for this processor.
Definition: percpu.h:436
struct Per_CPU_Control Per_CPU_Control
The watchdog header to manage scheduled watchdogs.
Definition: watchdog.h:71
unsigned context
Definition: tlb.h:108
Chain Handler API.
RTEMS_INLINE_ROUTINE struct _Thread_Control * _Thread_Get_executing(void)
Returns the thread control block of the executing thread.
Definition: percpu.h:878
Scheduler control.
Definition: scheduler.h:269
The thread dispatch critical section nesting counter which is used to prevent context switches at ino...
Definition: percpu.h:385
#define _ISR_lock_ISR_disable(_context)
Disables interrupts and saves the previous interrupt state in the ISR lock context.
Definition: isrlock.h:398
Index for monotonic clock per-CPU watchdog header.
Definition: percpu.h:334
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Index for tick clock per-CPU watchdog header.
Definition: percpu.h:316
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
ISR Locks.
struct Per_CPU_Control::@3977 Watchdog
Watchdog state for this processor.
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
