Macros | Functions
cpu.c File Reference
SPARC CPU Dependent Source. More...
#include <rtems/score/isr.h>
#include <rtems/score/tls.h>
#include <rtems/rtems/cache.h>
Include dependency graph for cpu.c:
#define SPARC_ASSERT_OFFSET(field, off)
#define SPARC_ASSERT_ISF_OFFSET(field, off)
#define HIGH_BITS_MASK   0xFFFFFC00
#define HIGH_BITS_SHIFT   10
#define LOW_BITS_MASK   0x000003FF
 RTEMS_STATIC_ASSERT (offsetof(Per_CPU_Control, cpu_per_cpu.isr_dispatch_disable)==SPARC_PER_CPU_ISR_DISPATCH_DISABLE, SPARC_PER_CPU_ISR_DISPATCH_DISABLE)
 SPARC_ASSERT_OFFSET (g5, G5)
 SPARC_ASSERT_OFFSET (g7, G7)
 RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)==L0_OFFSET, Context_Control_offset_L0)
 RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)+4==L1_OFFSET, Context_Control_offset_L1)
 SPARC_ASSERT_OFFSET (l2, L2)
 SPARC_ASSERT_OFFSET (l3, L3)
 SPARC_ASSERT_OFFSET (l4, L4)
 SPARC_ASSERT_OFFSET (l5, L5)
 SPARC_ASSERT_OFFSET (l6, L6)
 SPARC_ASSERT_OFFSET (l7, L7)
 SPARC_ASSERT_OFFSET (i0, I0)
 SPARC_ASSERT_OFFSET (i1, I1)
 SPARC_ASSERT_OFFSET (i2, I2)
 SPARC_ASSERT_OFFSET (i3, I3)
 SPARC_ASSERT_OFFSET (i4, I4)
 SPARC_ASSERT_OFFSET (i5, I5)
 SPARC_ASSERT_OFFSET (i6_fp, I6_FP)
 SPARC_ASSERT_OFFSET (i7, I7)
 SPARC_ASSERT_OFFSET (o6_sp, O6_SP)
 SPARC_ASSERT_OFFSET (o7, O7)
 SPARC_ASSERT_OFFSET (psr, PSR)
 SPARC_ASSERT_OFFSET (isr_dispatch_disable, ISR_DISPATCH_DISABLE_STACK)
 SPARC_ASSERT_ISF_OFFSET (psr, PSR)
 SPARC_ASSERT_ISF_OFFSET (pc, PC)
 SPARC_ASSERT_ISF_OFFSET (npc, NPC)
 SPARC_ASSERT_ISF_OFFSET (g1, G1)
 SPARC_ASSERT_ISF_OFFSET (g2, G2)
 SPARC_ASSERT_ISF_OFFSET (g3, G3)
 SPARC_ASSERT_ISF_OFFSET (g4, G4)
 SPARC_ASSERT_ISF_OFFSET (g5, G5)
 SPARC_ASSERT_ISF_OFFSET (g7, G7)
 SPARC_ASSERT_ISF_OFFSET (i0, I0)
 SPARC_ASSERT_ISF_OFFSET (i1, I1)
 SPARC_ASSERT_ISF_OFFSET (i2, I2)
 SPARC_ASSERT_ISF_OFFSET (i3, I3)
 SPARC_ASSERT_ISF_OFFSET (i4, I4)
 SPARC_ASSERT_ISF_OFFSET (i5, I5)
 SPARC_ASSERT_ISF_OFFSET (i6_fp, I6_FP)
 SPARC_ASSERT_ISF_OFFSET (i7, I7)
 SPARC_ASSERT_ISF_OFFSET (y, Y)
 SPARC_ASSERT_ISF_OFFSET (tpc, TPC)
 RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame)==CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE, CPU_Interrupt_frame_size)
 RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame) % CPU_ALIGNMENT==0, CPU_Interrupt_frame_alignment)
void _CPU_Initialize (void)
 CPU initialization. More...
uint32_t _CPU_ISR_Get_level (void)
 Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
void _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs an interrupt vector. More...
void _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
 Initialize the context to a state suitable for starting a task after a context restore operation. More...
◆ SPARC_ASSERT_ISF_OFFSET
#define SPARC_ASSERT_ISF_OFFSET (   field,
  off
Value:
RTEMS_STATIC_ASSERT( \
offsetof(CPU_Interrupt_frame, field) == ISF_ ## off ## _OFFSET, \
CPU_Interrupt_frame_offset_ ## field \
This defines the set of integer and processor state registers that must be saved during an interrupt...
Definition: cpu.h:425
◆ SPARC_ASSERT_OFFSET
#define SPARC_ASSERT_OFFSET (   field,
  off
Value:
offsetof(Context_Control, field) == off ## _OFFSET, \
Context_Control_offset_ ## field \
This defines the minimal set of integer and processor state registers that must be saved during a vol...
Definition: cpu.h:248
