On some CPUs, RTEMS supports a software managed interrupt stack. More...
| #define | CPU_MODES_INTERRUPT_MASK 0x00000001 |
| The following defines the number of bits actually used in the interrupt field of the task mode. More... | |
| #define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
| Amount of extra stack (above minimum stack size) required by MPCI receive server thread. More... | |
| #define | CPU_INTERRUPT_NUMBER_OF_VECTORS 16 |
| This defines the number of entries in the _ISR_Vector_table managed by RTEMS. More... | |
| #define | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
| This defines the highest interrupt vector number for this port. | |
| #define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
| This is defined if the port has a special way to report the ISR nesting level. More... | |
| #define | _CPU_Initialize_vectors() |
| Support routine to initialize the RTEMS vector table after it is allocated. More... | |
| #define | _CPU_ISR_Disable(_level) |
| Disable all interrupts for an RTEMS critical section. More... | |
| #define | _CPU_ISR_Enable(_level) |
| Enable interrupts to the previous level (returned by _CPU_ISR_Disable). More... | |
| #define | _CPU_ISR_Flash(_level) |
| This temporarily restores the interrupt to _isr_cookie before immediately disabling them again. More... | |
| #define | _CPU_ISR_Set_level(_new_level) |
| This routine and _CPU_ISR_Get_level Map the interrupt level in task mode onto the hardware that the CPU actually provides. More... | |
| #define | CPU_INTERRUPT_NUMBER_OF_VECTORS 32 |
| #define | _CPU_ISR_Disable(_isr_cookie) lm32_disable_interrupts( _isr_cookie ); |
| #define | _CPU_ISR_Enable(_isr_cookie) lm32_enable_interrupts( _isr_cookie ); |
| #define | _CPU_ISR_Flash(_isr_cookie) lm32_flash_interrupts( _isr_cookie ); |
| #define | _CPU_ISR_Set_level(new_level) |
| This defines the highest interrupt vector number for this port. More... | |
| #define | _CPU_ISR_Disable(_isr_cookie) |
| #define | _CPU_ISR_Enable(_isr_cookie) |
| #define | _CPU_ISR_Flash(_isr_cookie) |
| This defines the number of entries in the _ISR_Vector_table managed by RTEMS in case CPU_SIMPLE_VECTORED_INTERRUPTS is defined to TRUE. More... | |
| This defines the highest interrupt vector number for this port in case CPU_SIMPLE_VECTORED_INTERRUPTS is defined to TRUE. More... | |
| uint32_t | _CPU_ISR_Get_level (void) |
| Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More... | |
| void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs a "raw" interrupt handler directly into the processor's vector table. More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs an interrupt vector. More... | |
| void | _CPU_Install_interrupt_stack (void) |
| This routine installs the hardware interrupt stack pointer. More... | |
This variable is optional.
This stack is allocated by the Interrupt Manager and the switch is performed in _ISR_Handler. These variables contain pointers to the lowest and highest addresses in the chunk of memory allocated for the interrupt stack. Since it is unknown whether the stack grows up or down (in general), this give the CPU dependent code the option of picking the version it wants to use.
Port Specific Information:
XXX document implementation including references if appropriate
It is used on CPUs on which it is difficult to generate an "uninitialized" FP context. It is filled in by _CPU_Initialize and copied into the task's FP context area during _CPU_Context_Initialize.
On some CPUs, RTEMS supports a software managed interrupt stack. This stack is allocated by the Interrupt Manager and the switch is performed in _ISR_Handler. These variables contain pointers to the lowest and highest addresses in the chunk of memory allocated for the interrupt stack. Since it is unknown whether the stack grows up or down (in general), this give the CPU dependent code the option of picking the version it wants to use.
NOTE: These two variables are required if the macro CPU_HAS_SOFTWARE_INTERRUPT_STACK is defined as TRUE.
| #define _CPU_Initialize_vectors | ( | ) |
| #define _CPU_ISR_Disable | ( | _isr_cookie | ) |
The previous level is returned in _isr_cookie.
| [out] | _isr_cookie | will contain the previous level cookie |
On the v850, we need to save the PSW and use "di" to disable interrupts.
| #define _CPU_ISR_Disable | ( | _level | ) |
| #define _CPU_ISR_Disable | ( | _isr_cookie | ) | lm32_disable_interrupts( _isr_cookie ); |
TODO: As of 8 October 2014, this method is not implemented.
| #define _CPU_ISR_Enable | ( | _isr_cookie | ) |
This indicates the end of an RTEMS critical section. The parameter _isr_cookie is not modified.
| [in] | _isr_cookie | contain the previous level cookie |
On the v850, we simply need to restore the PSW.
| #define _CPU_ISR_Enable | ( | _level | ) |
| #define _CPU_ISR_Enable | ( | _isr_cookie | ) | lm32_enable_interrupts( _isr_cookie ); |
| #define _CPU_ISR_Flash | ( | _isr_cookie | ) |
This is used to divide long RTEMS critical sections into two or more parts. The parameter _isr_cookie is not modified.
This saves at least one instruction over using enable/disable back to back.
| #define _CPU_ISR_Flash | ( | _level | ) |
| #define _CPU_ISR_Flash | ( | _isr_cookie | ) | lm32_flash_interrupts( _isr_cookie ); |
| #define _CPU_ISR_Set_level | ( | new_level | ) |
Currently, interrupt levels which do not map onto the CPU in a generic fashion are undefined. Someday, it would be nice if these were "mapped" by the application via a callout. For example, m68k has 8 levels 0 - 7, levels 8 - 255 would be available for bsp/application specific meaning. This could be used to manage a programmable interrupt controller via the rtems_task_mode directive.
On the v850, level 0 is enabled. Non-zero is disabled.
| #define _CPU_ISR_Set_level | ( | _new_level | ) |
| #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
It must be less than CPU_INTERRUPT_NUMBER_OF_VECTORS. It may be not a compile-time constant.
It must be undefined in case CPU_SIMPLE_VECTORED_INTERRUPTS is defined to FALSE.
| #define CPU_INTERRUPT_NUMBER_OF_VECTORS 32 |
| #define CPU_INTERRUPT_NUMBER_OF_VECTORS 16 |
It must be a compile-time constant.
| #define CPU_MODES_INTERRUPT_MASK 0x00000001 |
How those bits map to the CPU interrupt levels is defined by the routine _CPU_ISR_Set_level.
The v850 only has a single bit in the CPU for interrupt disable/enable.
| #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
Remember that in a multiprocessor system this thread must exist and be able to process all directives.
There is no reason to think the v850 needs extra MPCI receive server stack.
| #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
Most ports maintain the variable _ISR_Nest_level.
| void _CPU_Install_interrupt_stack | ( | void | ) |
NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK is TRUE.
| uint32_t _CPU_ISR_Get_level | ( | void | ) |
NOTE: This routine usually must be implemented as a subroutine.
This method is implemented in C on the v850.
| [in] | vector | is the vector number |
| [in] | new_handler | is the raw ISR handler to install |
| [in] | old_handler | is the previously installed ISR Handler |
| [in] | new_handler | is the RTEMS ISR handler to install |
