cpu.h File Reference
SPARC64 CPU Department Source. More...
#include <rtems/score/types.h>
#include <rtems/score/sparc64.h>
Include dependency graph for cpu.h:
struct  CPU_Minimum_stack_frame
 This structure represents the organization of the minimum stack frame for the SPARC. More...
struct  Context_Control
 This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More...
struct  Context_Control_fp
 This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More...
struct  CPU_Interrupt_frame
 This defines the set of integer and processor state registers that must be saved during an interrupt. More...
struct  CPU_Trap_table_entry
 The following type defines an entry in the SPARC's trap table. More...
#define CPU_INLINE_ENABLE_DISPATCH   TRUE
#define CPU_HAS_SOFTWARE_INTERRUPT_STACK   TRUE
#define CPU_SIMPLE_VECTORED_INTERRUPTS   TRUE
#define CPU_HAS_HARDWARE_INTERRUPT_STACK   FALSE
#define CPU_ALLOCATE_INTERRUPT_STACK   TRUE
#define CPU_ISR_PASSES_FRAME_POINTER   0
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_PROVIDES_IDLE_THREAD_BODY   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_STRUCTURE_ALIGNMENT   __attribute__ ((aligned (16)))
#define CPU_TIMESTAMP_USE_INT64_INLINE   TRUE
#define CPU_BIG_ENDIAN   TRUE
#define CPU_LITTLE_ENDIAN   FALSE
#define CPU_MODES_INTERRUPT_MASK   0x0000000F
#define CPU_PER_CPU_CONTROL_SIZE   0
#define CPU_STACK_FRAME_L0_OFFSET   0x00
#define CPU_STACK_FRAME_L1_OFFSET   0x08
#define CPU_STACK_FRAME_L2_OFFSET   0x10
#define CPU_STACK_FRAME_L3_OFFSET   0x18
#define CPU_STACK_FRAME_L4_OFFSET   0x20
#define CPU_STACK_FRAME_L5_OFFSET   0x28
#define CPU_STACK_FRAME_L6_OFFSET   0x30
#define CPU_STACK_FRAME_L7_OFFSET   0x38
#define CPU_STACK_FRAME_I0_OFFSET   0x40
#define CPU_STACK_FRAME_I1_OFFSET   0x48
#define CPU_STACK_FRAME_I2_OFFSET   0x50
#define CPU_STACK_FRAME_I3_OFFSET   0x58
#define CPU_STACK_FRAME_I4_OFFSET   0x60
#define CPU_STACK_FRAME_I5_OFFSET   0x68
#define CPU_STACK_FRAME_I6_FP_OFFSET   0x70
#define CPU_STACK_FRAME_I7_OFFSET   0x78
#define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET   0x80
#define CPU_STACK_FRAME_SAVED_ARG0_OFFSET   0x88
#define CPU_STACK_FRAME_SAVED_ARG1_OFFSET   0x90
#define CPU_STACK_FRAME_SAVED_ARG2_OFFSET   0x98
#define CPU_STACK_FRAME_SAVED_ARG3_OFFSET   0xA0
#define CPU_STACK_FRAME_SAVED_ARG4_OFFSET   0xA8
#define CPU_STACK_FRAME_SAVED_ARG5_OFFSET   0xB0
#define CPU_STACK_FRAME_PAD0_OFFSET   0xB8
#define CPU_MINIMUM_STACK_FRAME_SIZE   0xC0
#define _CPU_Context_Get_SP(_context)   (_context)->o6_sp
#define G1_OFFSET   0x00
#define G2_OFFSET   0x08
#define G3_OFFSET   0x10
#define G4_OFFSET   0x18
#define G5_OFFSET   0x20
#define G6_OFFSET   0x28
#define G7_OFFSET   0x30
#define L0_OFFSET   0x38
#define L1_OFFSET   0x40
#define L2_OFFSET   0x48
#define L3_OFFSET   0x50
#define L4_OFFSET   0x58
#define L5_OFFSET   0x60
#define L6_OFFSET   0x68
#define L7_OFFSET   0x70
#define I0_OFFSET   0x78
#define I1_OFFSET   0x80
#define I2_OFFSET   0x88
#define I3_OFFSET   0x90
#define I4_OFFSET   0x98
#define I5_OFFSET   0xA0
#define I6_FP_OFFSET   0xA8
#define I7_OFFSET   0xB0
#define O0_OFFSET   0xB8
#define O1_OFFSET   0xC0
#define O2_OFFSET   0xC8
#define O3_OFFSET   0xD0
#define O4_OFFSET   0xD8
#define O5_OFFSET   0xE0
#define O6_SP_OFFSET   0xE8
#define O7_OFFSET   0xF0
#define ISR_DISPATCH_DISABLE_STACK_OFFSET   0xF8
#define ISR_PAD_OFFSET   0xFC
#define FO_OFFSET   0x00
#define F2_OFFSET   0x08
#define F4_OFFSET   0x10
#define F6_OFFSET   0x18
#define F8_OFFSET   0x20
#define F1O_OFFSET   0x28
#define F12_OFFSET   0x30
#define F14_OFFSET   0x38
#define F16_OFFSET   0x40
#define F18_OFFSET   0x48
#define F2O_OFFSET   0x50
#define F22_OFFSET   0x58
#define F24_OFFSET   0x60
#define F26_OFFSET   0x68
#define F28_OFFSET   0x70
#define F3O_OFFSET   0x78
#define F32_OFFSET   0x80
#define F34_OFFSET   0x88
#define F36_OFFSET   0x90
#define F38_OFFSET   0x98
#define F4O_OFFSET   0xA0
#define F42_OFFSET   0xA8
#define F44_OFFSET   0xB0
#define F46_OFFSET   0xB8
#define F48_OFFSET   0xC0
#define F5O_OFFSET   0xC8
#define F52_OFFSET   0xD0
#define F54_OFFSET   0xD8
#define F56_OFFSET   0xE0
#define F58_OFFSET   0xE8
#define F6O_OFFSET   0xF0
#define F62_OFFSET   0xF8
#define FSR_OFFSET   0x100
#define CONTEXT_CONTROL_FP_SIZE   0x108
#define ISF_TSTATE_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x00
#define ISF_TPC_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x08
#define ISF_TNPC_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x10
#define ISF_PIL_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x18
#define ISF_Y_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x20
#define ISF_G1_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x28
#define ISF_G2_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x30
#define ISF_G3_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x38
#define ISF_G4_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x40
#define ISF_G5_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x48
#define ISF_G6_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x50
#define ISF_G7_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x58
#define ISF_O0_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x60
#define ISF_O1_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x68
#define ISF_O2_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x70
#define ISF_O3_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x78
#define ISF_O4_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x80
#define ISF_O5_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x88
#define ISF_O6_SP_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x90
#define ISF_O7_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x98
#define ISF_TVEC_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0xA0
#define CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE   CPU_MINIMUM_STACK_FRAME_SIZE + 0xA8
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024
#define CPU_INTERRUPT_NUMBER_OF_VECTORS   512
#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER   1023
#define SPARC_SYNCHRONOUS_TRAP_BIT_MASK   0x200
#define SPARC_ASYNCHRONOUS_TRAP(_trap)   (_trap)
#define SPARC_SYNCHRONOUS_TRAP(_trap)   ((_trap) + 512 )
#define SPARC_REAL_TRAP_NUMBER(_trap)   ((_trap) % 512)
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1024*8)
#define CPU_SIZEOF_POINTER   8
#define CPU_ALIGNMENT   8
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_PARTITION_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   16
#define _CPU_Initialize_vectors()
#define _CPU_ISR_Disable(_level)   (_level) = sparc_disable_interrupts()
#define _CPU_ISR_Enable(_level)   sparc_enable_interrupts( _level )
#define _CPU_ISR_Flash(_level)   sparc_flash_interrupts( _level )
#define _CPU_ISR_Set_level(_newlevel)   sparc_enable_interrupts( _newlevel)
#define _CPU_Context_Initialization_at_thread_begin()
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Fp_start(_base, _offset)   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
#define _CPU_Context_Initialize_fp(_destination)
#define _CPU_Fatal_halt(_source, _error)
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_GENERIC_BITFIELD_DATA   TRUE
#define CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff))
typedef CPU_Interrupt_frame CPU_Exception_frame
typedef uint32_t CPU_Counter_ticks
uint32_t _CPU_ISR_Get_level (void)
 Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
void _CPU_ISR_install_vector (uint64_t vector, proc_ptr new_handler, proc_ptr *old_handler)
void * _CPU_Thread_Idle_body (uintptr_t ignored)
 This routine is the CPU dependent IDLE thread body. More...
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context)
 This routine is generally used only to restart self in an efficient manner. More...
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
 This routine saves the floating point context passed to it. More...
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
 This routine restores the floating point context passed to it. More...
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
CPU_Counter_ticks _CPU_Counter_read (void)
 Returns the current CPU counter value. More...
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context CPU_STRUCTURE_ALIGNMENT
 Set of Per CPU Core Information. More...
SCORE_EXTERN volatile uint32_t _CPU_ISR_Dispatch_disable
const CPU_Trap_table_entry _CPU_Trap_slot_template
This include file contains information pertaining to the port of the executive to the SPARC64 processor.
◆ _CPU_Context_Initialization_at_thread_begin
#define _CPU_Context_Initialization_at_thread_begin ( )
Value:
do { \
__asm__ volatile ("set _Thread_Handler,%%i7\n"::); \
} while (0)
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _destination)
Value:
do { \
*(*(_destination)) = _CPU_Null_fp_context; \
} while (0)
This variable is optional.
Definition: cpu.h:494
◆ _CPU_Fatal_halt
#define _CPU_Fatal_halt (   _source,
  _error
Value:
do { \
uint32_t level; \
level = sparc_disable_interrupts(); \
__asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) ); \
while (1); /* loop forever */ \
} while (0)
