24 #ifndef _RTEMS_SCORE_CPU_H 25 #define _RTEMS_SCORE_CPU_H 31 #include <rtems/score/types.h> 43 #define CPU_INLINE_ENABLE_DISPATCH TRUE 55 #define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE 68 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE 79 #define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE 88 #define CPU_ALLOCATE_INTERRUPT_STACK TRUE 96 #define CPU_ISR_PASSES_FRAME_POINTER 0 105 #if ( SPARC_HAS_FPU == 1 ) 106 #define CPU_HARDWARE_FP TRUE 108 #define CPU_HARDWARE_FP FALSE 110 #define CPU_SOFTWARE_FP FALSE 119 #define CPU_ALL_TASKS_ARE_FP FALSE 129 #define CPU_IDLE_TASK_IS_FP FALSE 146 #define CPU_USE_DEFERRED_FP_SWITCH TRUE 159 #define CPU_PROVIDES_IDLE_THREAD_BODY FALSE 171 #define CPU_STACK_GROWS_UP FALSE 187 #define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (16))) 189 #define CPU_TIMESTAMP_USE_INT64_INLINE TRUE 196 #define CPU_BIG_ENDIAN TRUE 197 #define CPU_LITTLE_ENDIAN FALSE 207 #define CPU_MODES_INTERRUPT_MASK 0x0000000F 209 #define CPU_PER_CPU_CONTROL_SIZE 0 237 void *structure_return_address;
253 #define CPU_STACK_FRAME_L0_OFFSET 0x00 254 #define CPU_STACK_FRAME_L1_OFFSET 0x08 255 #define CPU_STACK_FRAME_L2_OFFSET 0x10 256 #define CPU_STACK_FRAME_L3_OFFSET 0x18 257 #define CPU_STACK_FRAME_L4_OFFSET 0x20 258 #define CPU_STACK_FRAME_L5_OFFSET 0x28 259 #define CPU_STACK_FRAME_L6_OFFSET 0x30 260 #define CPU_STACK_FRAME_L7_OFFSET 0x38 261 #define CPU_STACK_FRAME_I0_OFFSET 0x40 262 #define CPU_STACK_FRAME_I1_OFFSET 0x48 263 #define CPU_STACK_FRAME_I2_OFFSET 0x50 264 #define CPU_STACK_FRAME_I3_OFFSET 0x58 265 #define CPU_STACK_FRAME_I4_OFFSET 0x60 266 #define CPU_STACK_FRAME_I5_OFFSET 0x68 267 #define CPU_STACK_FRAME_I6_FP_OFFSET 0x70 268 #define CPU_STACK_FRAME_I7_OFFSET 0x78 269 #define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET 0x80 270 #define CPU_STACK_FRAME_SAVED_ARG0_OFFSET 0x88 271 #define CPU_STACK_FRAME_SAVED_ARG1_OFFSET 0x90 272 #define CPU_STACK_FRAME_SAVED_ARG2_OFFSET 0x98 273 #define CPU_STACK_FRAME_SAVED_ARG3_OFFSET 0xA0 274 #define CPU_STACK_FRAME_SAVED_ARG4_OFFSET 0xA8 275 #define CPU_STACK_FRAME_SAVED_ARG5_OFFSET 0xB0 276 #define CPU_STACK_FRAME_PAD0_OFFSET 0xB8 278 #define CPU_MINIMUM_STACK_FRAME_SIZE 0xC0 336 uint32_t isr_dispatch_disable;
340 #define _CPU_Context_Get_SP( _context ) \ 349 #define G1_OFFSET 0x00 350 #define G2_OFFSET 0x08 351 #define G3_OFFSET 0x10 352 #define G4_OFFSET 0x18 353 #define G5_OFFSET 0x20 354 #define G6_OFFSET 0x28 355 #define G7_OFFSET 0x30 357 #define L0_OFFSET 0x38 358 #define L1_OFFSET 0x40 359 #define L2_OFFSET 0x48 360 #define L3_OFFSET 0x50 361 #define L4_OFFSET 0x58 362 #define L5_OFFSET 0x60 363 #define L6_OFFSET 0x68 364 #define L7_OFFSET 0x70 366 #define I0_OFFSET 0x78 367 #define I1_OFFSET 0x80 368 #define I2_OFFSET 0x88 369 #define I3_OFFSET 0x90 370 #define I4_OFFSET 0x98 371 #define I5_OFFSET 0xA0 372 #define I6_FP_OFFSET 0xA8 373 #define I7_OFFSET 0xB0 375 #define O0_OFFSET 0xB8 376 #define O1_OFFSET 0xC0 377 #define O2_OFFSET 0xC8 378 #define O3_OFFSET 0xD0 379 #define O4_OFFSET 0xD8 380 #define O5_OFFSET 0xE0 381 #define O6_SP_OFFSET 0xE8 382 #define O7_OFFSET 0xF0 384 #define ISR_DISPATCH_DISABLE_STACK_OFFSET 0xF8 385 #define ISR_PAD_OFFSET 0xFC 435 #define FO_OFFSET 0x00 436 #define F2_OFFSET 0x08 437 #define F4_OFFSET 0x10 438 #define F6_OFFSET 0x18 439 #define F8_OFFSET 0x20 440 #define F1O_OFFSET 0x28 441 #define F12_OFFSET 0x30 442 #define F14_OFFSET 0x38 443 #define F16_OFFSET 0x40 444 #define F18_OFFSET 0x48 445 #define F2O_OFFSET 0x50 446 #define F22_OFFSET 0x58 447 #define F24_OFFSET 0x60 448 #define F26_OFFSET 0x68 449 #define F28_OFFSET 0x70 450 #define F3O_OFFSET 0x78 451 #define F32_OFFSET 0x80 452 #define F34_OFFSET 0x88 453 #define F36_OFFSET 0x90 454 #define F38_OFFSET 0x98 455 #define F4O_OFFSET 0xA0 456 #define F42_OFFSET 0xA8 457 #define F44_OFFSET 0xB0 458 #define F46_OFFSET 0xB8 459 #define F48_OFFSET 0xC0 460 #define F5O_OFFSET 0xC8 461 #define F52_OFFSET 0xD0 462 #define F54_OFFSET 0xD8 463 #define F56_OFFSET 0xE0 464 #define F58_OFFSET 0xE8 465 #define F6O_OFFSET 0xF0 466 #define F62_OFFSET 0xF8 467 #define FSR_OFFSET 0x100 469 #define CONTEXT_CONTROL_FP_SIZE 0x108 515 #define ISF_TSTATE_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x00 516 #define ISF_TPC_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x08 517 #define ISF_TNPC_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x10 518 #define ISF_PIL_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x18 519 #define ISF_Y_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x20 520 #define ISF_G1_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x28 521 #define ISF_G2_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x30 522 #define ISF_G3_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x38 523 #define ISF_G4_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x40 524 #define ISF_G5_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x48 525 #define ISF_G6_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x50 526 #define ISF_G7_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x58 527 #define ISF_O0_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x60 528 #define ISF_O1_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x68 529 #define ISF_O2_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x70 530 #define ISF_O3_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x78 531 #define ISF_O4_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x80 532 #define ISF_O5_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x88 533 #define ISF_O6_SP_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x90 534 #define ISF_O7_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0x98 535 #define ISF_TVEC_OFFSET CPU_MINIMUM_STACK_FRAME_SIZE + 0xA0 537 #define CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE CPU_MINIMUM_STACK_FRAME_SIZE + 0xA8 554 SCORE_EXTERN volatile uint32_t _CPU_ISR_Dispatch_disable;
577 uint32_t rdpr_tstate_g4;
578 uint32_t sethi_of_hh_handler_to_g2;
579 uint32_t or_g2_hm_handler_to_g2;
580 uint32_t sllx_g2_by_32_to_g2;
581 uint32_t sethi_of_handler_to_g3;
582 uint32_t or_g3_g2_to_g3;
583 uint32_t jmp_to_low_of_handler_plus_g3;
584 uint32_t mov_vector_g2;
603 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) 613 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024 641 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 512 642 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER 1023 644 #define SPARC_SYNCHRONOUS_TRAP_BIT_MASK 0x200 645 #define SPARC_ASYNCHRONOUS_TRAP( _trap ) (_trap) 646 #define SPARC_SYNCHRONOUS_TRAP( _trap ) ((_trap) + 512 ) 648 #define SPARC_REAL_TRAP_NUMBER( _trap ) ((_trap) % 512) 655 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE 666 #define CPU_STACK_MINIMUM_SIZE (1024*8) 668 #define CPU_SIZEOF_POINTER 8 680 #define CPU_ALIGNMENT 8 694 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT 708 #define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT 724 #define CPU_STACK_ALIGNMENT 16 736 #define _CPU_Initialize_vectors() 743 #define _CPU_ISR_Disable( _level ) \ 744 (_level) = sparc_disable_interrupts() 752 #define _CPU_ISR_Enable( _level ) \ 753 sparc_enable_interrupts( _level ) 762 #define _CPU_ISR_Flash( _level ) \ 763 sparc_flash_interrupts( _level ) 771 #define _CPU_ISR_Set_level( _newlevel ) \ 772 sparc_enable_interrupts( _newlevel) 818 #define _CPU_Context_Initialization_at_thread_begin() \ 820 __asm__ volatile ("set _Thread_Handler,%%i7\n"::); \ 832 #define _CPU_Context_Restart_self( _the_context ) \ 833 _CPU_Context_restore( (_the_context) ); 840 #define _CPU_Context_Fp_start( _base, _offset ) \ 841 ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) 852 #define _CPU_Context_Initialize_fp( _destination ) \ 854 *(*(_destination)) = _CPU_Null_fp_context; \ 867 #define _CPU_Fatal_halt( _source, _error ) \ 871 level = sparc_disable_interrupts(); \ 872 __asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) ); \ 885 #if ( SPARC_HAS_BITSCAN == 0 ) 886 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE 887 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE 889 #error "scan instruction not currently supported by RTEMS!!" 901 #if ( SPARC_HAS_BITSCAN == 1 ) 902 #error "scan instruction not currently supported by RTEMS!!" 942 #if (CPU_PROVIDES_IDLE_THREAD_BODY == TRUE) 1033 static inline uint32_t CPU_swap_u32(
1037 uint32_t byte1, byte2, byte3, byte4, swapped;
1039 byte4 = (value >> 24) & 0xff;
1040 byte3 = (value >> 16) & 0xff;
1041 byte2 = (value >> 8) & 0xff;
1042 byte1 = value & 0xff;
1044 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
1048 #define CPU_swap_u16( value ) \ 1049 (((value&0xff) << 8) | ((value >> 8)&0xff)) 1056 CPU_Counter_ticks second,
1057 CPU_Counter_ticks first
1060 return second - first;
This structure represents the organization of the minimum stack frame for the SPARC.
Definition: cpu.h:259
void _CPU_ISR_install_vector(uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
This routine installs an interrupt vector.
Definition: cpu.c:69
void _CPU_Context_validate(uintptr_t pattern)
Initializes and validates the CPU context with values derived from the pattern parameter.
Definition: cpu.h:1109
uint32_t _CPU_ISR_Get_level(void)
Return the current interrupt disable level for this task in the format used by the interrupt level po...
Definition: cpu.c:39
void _CPU_Context_restore(Context_Control *new_context)
This routine is generally used only to restart self in an efficient manner.
Definition: cpu_asm.c:112
The following type defines an entry in the SPARC's trap table.
Definition: cpu.h:807
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:92
void _CPU_Context_volatile_clobber(uintptr_t pattern)
Clobbers all volatile registers with values derived from the pattern parameter.
Definition: cpu.h:1104
This defines the minimal set of integer and processor state registers that must be saved during a vol...
Definition: cpu.h:248
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:26
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context
This variable is optional.
Definition: cpu.h:494
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1461
This defines the set of integer and processor state registers that must be saved during an interrupt...
Definition: cpu.h:425
void _CPU_ISR_install_raw_handler(uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
This routine installs a "raw" interrupt handler directly into the processor's vector table...
Definition: cpu.c:57
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context CPU_STRUCTURE_ALIGNMENT
This variable is contains the initialize context for the FP unit.
Definition: cpu.h:797
void _CPU_Context_restore_fp(Context_Control_fp **fp_context_ptr)
This routine restores the floating point context passed to it.
Definition: cpu.c:176
Information Required to Build RTEMS for a Particular Member of the SPARC Family.
void _CPU_Context_Initialize(Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
Initialize the context to a state suitable for starting a task after a context restore operation...
Definition: cpu.c:183
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: cpu.c:96
CPU_Counter_ticks _CPU_Counter_difference(CPU_Counter_ticks second, CPU_Counter_ticks first)
Returns the difference between the second and first CPU counter value.
Definition: cpu.h:1160
const CPU_Trap_table_entry _CPU_Trap_slot_template
This is the set of opcodes for the instructions loaded into a trap table entry.
This defines the complete set of floating point registers that must be saved during any context switc...
Definition: cpu.h:294
void _CPU_Context_save_fp(Context_Control_fp **fp_context_ptr)
This routine saves the floating point context passed to it.
Definition: cpu.c:167
#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE
The following macro is a compiler specific way to indicate that the method will NOT return to the cal...
Definition: basedefs.h:162
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: arm-exception-frame-print.c:46
void * _CPU_Thread_Idle_body(uintptr_t ignored)
This routine is the CPU dependent IDLE thread body.
Definition: cpu.c:125
The set of registers that specifies the complete processor state.
Definition: cpu.h:671
#define SCORE_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:81
void * proc_ptr
XXX: Eventually proc_ptr needs to disappear!!!
Definition: basedefs.h:329
