Inlined Routines from the POSIX RWLock Manager. More...
#include <rtems/posix/rwlock.h>#include <rtems/score/corerwlockimpl.h>#include <rtems/score/objectimpl.h>#include <pthread.h>
| void | _POSIX_RWLock_Manager_initialization (void) |
| POSIX RWLock manager initialization. More... | |
| int | _POSIX_RWLock_Translate_core_RWLock_return_code (CORE_RWLock_Status the_RWLock_status) |
| POSIX translate core RWLock return code. More... | |
| RTEMS_INLINE_ROUTINE POSIX_RWLock_Control * | _POSIX_RWLock_Allocate (void) |
| Allocate a RWLock control block. More... | |
| RTEMS_INLINE_ROUTINE void | _POSIX_RWLock_Free (POSIX_RWLock_Control *the_RWLock) |
| Free a RWLock control block. More... | |
| POSIX_RWLock_Control * | _POSIX_RWLock_Get (pthread_rwlock_t *rwlock, Objects_Locations *location) |
| POSIX_EXTERN Objects_Information | _POSIX_RWLock_Information |
| The following defines the information control block used to manage this class of objects. | |
This file contains the static inlin implementation of the inlined routines from the POSIX RWLock Manager.
| RTEMS_INLINE_ROUTINE POSIX_RWLock_Control* _POSIX_RWLock_Allocate | ( | void | ) |
This function allocates a RWLock control block from the inactive chain of free RWLock control blocks.
References _Objects_Allocate().
| RTEMS_INLINE_ROUTINE void _POSIX_RWLock_Free | ( | POSIX_RWLock_Control * | the_RWLock | ) |
This routine frees a RWLock control block to the inactive chain of free RWLock control blocks.
| void _POSIX_RWLock_Manager_initialization | ( | void | ) |
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _POSIX_RWLock_Information.
| int _POSIX_RWLock_Translate_core_RWLock_return_code | ( | CORE_RWLock_Status | the_RWLock_status | ) |
This routine translates SuperCore RWLock status codes into the corresponding POSIX ones.
| [in] | the_RWLock_status | is the SuperCore status. |
| 0 | The status indicates that the operation completed successfully. |
| EINVAL | The status indicates that the thread was blocked waiting for an operation to complete and the RWLock was deleted. |
| EBUSY | This status indicates that the RWLock was not immediately available. |
| ETIMEDOUT | This status indicates that the calling task was willing to block but the operation was unable to complete within the time allotted because the resource never became available. |
References CORE_RWLOCK_STATUS_LAST.
