RTEMS File System Information Node. More...
#include <sys/stat.h>#include <rtems/rfs/rtems-rfs-data.h>#include <rtems/rfs/rtems-rfs-file-system.h>
| struct | _rtems_rfs_inode |
| The inode. More... | |
| struct | _rtems_rfs_inode_handle |
| RFS Inode Handle. More... | |
| #define | RTEMS_RFS_S_ISUID S_ISUID |
| The RFS mode definitions. More... | |
| #define | RTEMS_RFS_S_ISGID S_ISGID |
| Set group id on execution. | |
| #define | RTEMS_RFS_S_ISVTX S_ISVTX |
| Save swapped text even after use. | |
| #define | RTEMS_RFS_S_IREAD S_IREAD |
| Read permission, owner. | |
| #define | RTEMS_RFS_S_IWRITE S_IWRITE |
| Write permission, owner. | |
| #define | RTEMS_RFS_S_IEXEC S_IEXEC |
| Execute/search permission, owner. | |
| #define | RTEMS_RFS_S_ENFMT S_ENFMT |
| Enforcement-mode locking. | |
| #define | RTEMS_RFS_S_IFMT S_IFMT |
| Type of file. | |
| #define | RTEMS_RFS_S_IFDIR S_IFDIR |
| Directory. | |
| #define | RTEMS_RFS_S_IFCHR S_IFCHR |
| Character special. | |
| #define | RTEMS_RFS_S_IFBLK S_IFBLK |
| Block special. | |
| #define | RTEMS_RFS_S_IFREG S_IFREG |
| Regular. | |
| #define | RTEMS_RFS_S_IFLNK S_IFLNK |
| Symbolic link. | |
| #define | RTEMS_RFS_S_IFSOCK S_IFSOCK |
| Socket. | |
| #define | RTEMS_RFS_S_IFIFO S_IFIFO |
| Fifo. | |
| #define | RTEMS_RFS_S_IRWXU S_IRWXU |
| #define | RTEMS_RFS_S_IRUSR S_IRUSR |
| #define | RTEMS_RFS_S_IWUSR S_IWUSR |
| #define | RTEMS_RFS_S_IXUSR S_IXUSR |
| #define | RTEMS_RFS_S_IRWXG S_IRWXG |
| #define | RTEMS_RFS_S_IRGRP S_IRGRP |
| Read permission, group. | |
| #define | RTEMS_RFS_S_IWGRP S_IWGRP |
| Write permission, grougroup. | |
| #define | RTEMS_RFS_S_IXGRP S_IXGRP |
| Execute/search permission, group. | |
| #define | RTEMS_RFS_S_IRWXO S_IRWXO |
| #define | RTEMS_RFS_S_IROTH S_IROTH |
| Read permission, other. | |
| #define | RTEMS_RFS_S_IWOTH S_IWOTH |
| Write permission, other. | |
| #define | RTEMS_RFS_S_IXOTH S_IXOTH |
| Execute/search permission, other. | |
| #define | RTEMS_RFS_S_ISBLK(m) S_ISBLK(m) |
| #define | RTEMS_RFS_S_ISCHR(m) S_ISCHR(m) |
| #define | RTEMS_RFS_S_ISDIR(m) S_ISDIR(m) |
| #define | RTEMS_RFS_S_ISFIFO(m) S_ISFIFO(m) |
| #define | RTEMS_RFS_S_ISREG(m) S_ISREG(m) |
| #define | RTEMS_RFS_S_ISLNK(m) S_ISLNK(m) |
| #define | RTEMS_RFS_S_ISSOCK(m) S_ISSOCK(m) |
| #define | RTEMS_RFS_S_SYMLINK RTEMS_RFS_S_IFLNK | RTEMS_RFS_S_IRWXU | RTEMS_RFS_S_IRWXG | RTEMS_RFS_S_IRWXO |
| Permissions of a symlink. | |
| #define | RTEMS_RFS_INODE_DATA_NAME_SIZE (RTEMS_RFS_INODE_BLOCKS * sizeof (rtems_rfs_inode_block)) |
| The size of the data name field in the inode. | |
| #define | RTEMS_RFS_INODE_SIZE (sizeof (rtems_rfs_inode)) |
| The size of an inode. | |
| #define | rtems_rfs_inode_is_loaded(_h) ((_h)->node) |
| Is the inode loaded ? | |
| #define | rtems_rfs_inode_ino(_h) ((_h)->ino) |
| Get the inode ino for a handle. | |
Typedefs | |
| typedef uint32_t | rtems_rfs_ino |
| The inode number or ino. | |
| typedef uint32_t | rtems_rfs_time |
| The time in the file system. | |
| typedef uint32_t | rtems_rfs_inode_block |
| The size of a block value on disk. More... | |
| typedef struct _rtems_rfs_inode | rtems_rfs_inode |
| The inode. | |
| typedef struct _rtems_rfs_inode_handle | rtems_rfs_inode_handle |
| RFS Inode Handle. | |
| int | rtems_rfs_inode_alloc (rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, rtems_rfs_ino *ino) |
| Allocate an inode number and return it. More... | |
| int | rtems_rfs_inode_free (rtems_rfs_file_system *fs, rtems_rfs_ino ino) |
| Free an inode. More... | |
| int | rtems_rfs_inode_open (rtems_rfs_file_system *fs, rtems_rfs_ino ino, rtems_rfs_inode_handle *handle, bool load) |
| Open the inode handle. More... | |
| int | rtems_rfs_inode_close (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| The close inode handle. More... | |
| int | rtems_rfs_inode_load (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| Load the inode into memory. More... | |
| int | rtems_rfs_inode_unload (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle, bool update_ctime) |
| Unload the inode from memory. More... | |
| int | rtems_rfs_inode_create (rtems_rfs_file_system *fs, rtems_rfs_ino parent, const char *name, size_t length, uint16_t mode, uint16_t links, uid_t uid, gid_t gid, rtems_rfs_ino *ino) |
| Create an inode allocating, initialising and adding an entry to the parent directory. More... | |
| int | rtems_rfs_inode_delete (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| Delete the inode eraseing it and release the buffer to commit the write. More... | |
| int | rtems_rfs_inode_initialise (rtems_rfs_inode_handle *handle, uint16_t links, uint16_t mode, uid_t uid, gid_t gid) |
| Initialise a new inode. More... | |
| int | rtems_rfs_inode_time_stamp_now (rtems_rfs_inode_handle *handle, bool atime, bool mtime) |
| Time stamp the inode with the current time. More... | |
| rtems_rfs_pos | rtems_rfs_inode_get_size (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| Calculate the size of data attached to the inode. More... | |
The information nodes hold the data about all nodes in the file system.
| #define RTEMS_RFS_S_ISUID S_ISUID |
Currently map to the C library ones.Set user id on execution
| typedef uint32_t rtems_rfs_inode_block |
This include the inodes and indirect tables.
| int rtems_rfs_inode_alloc | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_bitmap_bit | goal, | ||
| rtems_rfs_ino * | ino | ||
| [in] | fs | is the file system data. |
| [out] | ino | will contain the ino. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_inode_close | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_inode_handle * | handle | ||
All opened inodes need to be closed.
| [in] | fs | is the file system. |
| [in] | handle | is the handle to close. |
| int rtems_rfs_inode_create | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | parent, | ||
| const char * | name, | ||
| size_t | length, | ||
| uint16_t | mode, | ||
| uint16_t | links, | ||
| uid_t | uid, | ||
| gid_t | gid, | ||
| [in] | parent | is the parent inode number to add the directory entry to. |
| [in] | name | is a pointer to the name of the directory entryinode to create. |
| int rtems_rfs_inode_delete | ( | rtems_rfs_file_system * | fs, |
You need to load the inode again if you wish to use it again.
| [in] | handle | is the inode handle to erase. |
| int rtems_rfs_inode_free | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | ino | ||
Free an inode.
| [in] | ino | is the ino too free. |
| rtems_rfs_pos rtems_rfs_inode_get_size | ( | rtems_rfs_file_system * | fs, |
| [in] | handle | is the inode handle. |
| size | The data size in bytes in the block map attched to the inode. |
| int rtems_rfs_inode_initialise | ( | rtems_rfs_inode_handle * | handle, |
| uid_t | uid, | ||
| gid_t | gid | ||
| [in] | handle | is the inode handle to initialise. |
| [in] | links | are the number of links to the inode. |
| [in] | mode | is the inode mode. |
| [in] | uid | is the user id. |
| [in] | gid | is the group id. |
| int rtems_rfs_inode_load | ( | rtems_rfs_file_system * | fs, |
| [in] | handle | is the inode handle to load. |
| int rtems_rfs_inode_open | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | ino, | ||
| rtems_rfs_inode_handle * | handle, | ||
| bool | load | ||
This reads the inode into the buffer and sets the data pointer. All data is in media byte order and needs to be accessed via the supporting calls.
| [in] | ino | is the inode number. |
| [in] | handle | is the handle to the inode we are opening. |
| [in] | load | If true load the inode into memory from the media. |
| int rtems_rfs_inode_time_stamp_now | ( | rtems_rfs_inode_handle * | handle, |
| bool | atime, | ||
| bool | mtime | ||
The ctime field is hanlded automatically.
| [in] | atime | Update the atime field. |
| [in] | mtime | UPdate the mtime field. |
| ENXIO | No inode is loaded. |
| int rtems_rfs_inode_unload | ( | rtems_rfs_file_system * | fs, |
| bool | update_ctime | ||
| [in] | handle | is the inode handle to unload. |
| [in] | update_ctime | Update the ctime field of the inode. |
