RTEMS File Systems Inode RoutinesThese functions manage inodes in the RFS file system. More...
#include <inttypes.h>#include <string.h>#include <rtems/rfs/rtems-rfs-block.h>#include <rtems/rfs/rtems-rfs-file-system.h>#include <rtems/rfs/rtems-rfs-inode.h>#include <rtems/rfs/rtems-rfs-dir.h>
| int | rtems_rfs_inode_alloc (rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, rtems_rfs_ino *ino) |
| Allocate an inode number and return it. More... | |
| int | rtems_rfs_inode_free (rtems_rfs_file_system *fs, rtems_rfs_ino ino) |
| Free an inode. More... | |
| int | rtems_rfs_inode_open (rtems_rfs_file_system *fs, rtems_rfs_ino ino, rtems_rfs_inode_handle *handle, bool load) |
| Open the inode handle. More... | |
| int | rtems_rfs_inode_close (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| The close inode handle. More... | |
| int | rtems_rfs_inode_load (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| Load the inode into memory. More... | |
| int | rtems_rfs_inode_unload (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle, bool update_ctime) |
| Unload the inode from memory. More... | |
| int | rtems_rfs_inode_create (rtems_rfs_file_system *fs, rtems_rfs_ino parent, const char *name, size_t length, uint16_t mode, uint16_t links, uid_t uid, gid_t gid, rtems_rfs_ino *ino) |
| Create an inode allocating, initialising and adding an entry to the parent directory. More... | |
| int | rtems_rfs_inode_delete (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| Delete the inode eraseing it and release the buffer to commit the write. More... | |
| int | rtems_rfs_inode_initialise (rtems_rfs_inode_handle *handle, uint16_t links, uint16_t mode, uid_t uid, gid_t gid) |
| Initialise a new inode. More... | |
| int | rtems_rfs_inode_time_stamp_now (rtems_rfs_inode_handle *handle, bool atime, bool mtime) |
| Time stamp the inode with the current time. More... | |
| rtems_rfs_pos | rtems_rfs_inode_get_size (rtems_rfs_file_system *fs, rtems_rfs_inode_handle *handle) |
| Calculate the size of data attached to the inode. More... | |
An inode is part of a block that reside after the bitmaps in the group.
| int rtems_rfs_inode_alloc | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_bitmap_bit | goal, | ||
| rtems_rfs_ino * | ino | ||
| [in] | fs | is the file system data. |
| [out] | ino | will contain the ino. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_inode_close | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_inode_handle * | handle | ||
All opened inodes need to be closed.
| [in] | fs | is the file system. |
| [in] | handle | is the handle to close. |
| int rtems_rfs_inode_create | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | parent, | ||
| const char * | name, | ||
| size_t | length, | ||
| uint16_t | mode, | ||
| uint16_t | links, | ||
| uid_t | uid, | ||
| gid_t | gid, | ||
| [in] | parent | is the parent inode number to add the directory entry to. |
| [in] | name | is a pointer to the name of the directory entryinode to create. |
| int rtems_rfs_inode_delete | ( | rtems_rfs_file_system * | fs, |
You need to load the inode again if you wish to use it again.
| [in] | handle | is the inode handle to erase. |
| int rtems_rfs_inode_free | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | ino | ||
Free an inode.
| [in] | ino | is the ino too free. |
| rtems_rfs_pos rtems_rfs_inode_get_size | ( | rtems_rfs_file_system * | fs, |
| [in] | handle | is the inode handle. |
| size | The data size in bytes in the block map attched to the inode. |
| int rtems_rfs_inode_initialise | ( | rtems_rfs_inode_handle * | handle, |
| uid_t | uid, | ||
| gid_t | gid | ||
| [in] | handle | is the inode handle to initialise. |
| [in] | links | are the number of links to the inode. |
| [in] | mode | is the inode mode. |
| [in] | uid | is the user id. |
| [in] | gid | is the group id. |
| int rtems_rfs_inode_load | ( | rtems_rfs_file_system * | fs, |
| [in] | handle | is the inode handle to load. |
| int rtems_rfs_inode_open | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_ino | ino, | ||
| rtems_rfs_inode_handle * | handle, | ||
| bool | load | ||
This reads the inode into the buffer and sets the data pointer. All data is in media byte order and needs to be accessed via the supporting calls.
| [in] | ino | is the inode number. |
| [in] | handle | is the handle to the inode we are opening. |
| [in] | load | If true load the inode into memory from the media. |
| int rtems_rfs_inode_time_stamp_now | ( | rtems_rfs_inode_handle * | handle, |
| bool | atime, | ||
| bool | mtime | ||
The ctime field is hanlded automatically.
| [in] | atime | Update the atime field. |
| [in] | mtime | UPdate the mtime field. |
| ENXIO | No inode is loaded. |
| int rtems_rfs_inode_unload | ( | rtems_rfs_file_system * | fs, |
| bool | update_ctime | ||
| [in] | handle | is the inode handle to unload. |
| [in] | update_ctime | Update the ctime field of the inode. |
