RTEMS File Systems Bitmap RoutinesThese functions manage bit maps. More...
#include <stdlib.h>#include <rtems/rfs/rtems-rfs-bitmaps.h>
| #define | RTEMS_RFS_BITMAP_WARNINGS 0 |
| Set to 1 to enable warnings when developing. | |
| rtems_rfs_bitmap_element | rtems_rfs_bitmap_mask (unsigned int size) |
| Create a bit mask with the specified number of bits up to an element's size. More... | |
| rtems_rfs_bitmap_element | rtems_rfs_bitmap_mask_section (unsigned int start, unsigned int end) |
| Create a bit mask section. More... | |
| int | rtems_rfs_bitmap_map_set (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit bit) |
| Set a bit in a map and if all the bits are set, set the search map bit as well. More... | |
| int | rtems_rfs_bitmap_map_clear (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit bit) |
| Clear a bit in a map and make sure the search map bit is clear so a search will find this bit available. More... | |
| int | rtems_rfs_bitmap_map_test (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit bit, bool *state) |
| Test a bit in the map. More... | |
| int | rtems_rfs_bitmap_map_set_all (rtems_rfs_bitmap_control *control) |
| Set all bits in the bitmap and set the dirty bit. More... | |
| int | rtems_rfs_bitmap_map_clear_all (rtems_rfs_bitmap_control *control) |
| Clear all bits in the bitmap and set the dirty bit. More... | |
| int | rtems_rfs_bitmap_map_alloc (rtems_rfs_bitmap_control *control, rtems_rfs_bitmap_bit seed, bool *allocated, rtems_rfs_bitmap_bit *bit) |
| Find a free bit searching from the seed up and down until found. More... | |
| int | rtems_rfs_bitmap_create_search (rtems_rfs_bitmap_control *control) |
| Create a search bit map from the actual bit map. More... | |
| int | rtems_rfs_bitmap_open (rtems_rfs_bitmap_control *control, rtems_rfs_file_system *fs, rtems_rfs_buffer_handle *buffer, size_t size, rtems_rfs_buffer_block block) |
| Open a bitmap control with a map and search map. More... | |
| int | rtems_rfs_bitmap_close (rtems_rfs_bitmap_control *control) |
| Close a bitmap. More... | |
A bit map consists of the map of bit allocated in a block and a search map where a bit represents 32 actual bits. The search map allows for a faster search for an available bit as 32 search bits can checked in a test.
| int rtems_rfs_bitmap_close | ( | rtems_rfs_bitmap_control * | control | ) |
Close a bitmap.
| [in] | control | is the bit map control. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_bitmap_create_search | ( | rtems_rfs_bitmap_control * | control | ) |
| [in] | control | is the map control. |
| int rtems_rfs_bitmap_map_alloc | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_bitmap_bit | seed, | ||
| bool * | allocate, | ||
| rtems_rfs_bitmap_bit * | bit | ||
The search is performing by moving up from the seed for the window distance then to search down from the seed for the window distance. This is repeated out from the seed for each window until a free bit is found. The search is performed by checking the search map to see if the map has a free bit.
| [in] | seed | is the bit to search out from. |
| [out] | allocate | A bit was allocated. |
| [out] | bit | will contain the bit found free if true is returned. |
References RTEMS_RFS_BITMAP_SEARCH_WINDOW.
| int rtems_rfs_bitmap_map_clear | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_bitmap_bit | bit | ||
| [in] | control | is the control for the map. |
| [in] | bit | is the bit in the map to clear. |
| int rtems_rfs_bitmap_map_clear_all | ( | rtems_rfs_bitmap_control * | control | ) |
| [in] | control | is the bitmap control. |
| int rtems_rfs_bitmap_map_set | ( | rtems_rfs_bitmap_control * | control, |
| [in] | bit | is the bit in the map to set. |
| int rtems_rfs_bitmap_map_set_all | ( | rtems_rfs_bitmap_control * | control | ) |
| int rtems_rfs_bitmap_map_test | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_bitmap_bit | bit, | ||
| bool * | state | ||
| [in] | bit | is the bit to test. |
| [in] | state | is the state of the bit if no error is returned. |
| rtems_rfs_bitmap_element rtems_rfs_bitmap_mask | ( | unsigned int | size | ) |
The mask is aligned to bit 0 of the element.
| [in] | size | is the number of bits in the mask. |
| rtems_rfs_bitmap_element rtems_rfs_bitmap_mask_section | ( | unsigned int | start, |
| unsigned int | end | ||
A mask section is a mask that is not aligned to an end of the element.
| [in] | start | is the first bit of the mask numbered from 0. |
| [in] | end | is the end bit of the mask numbered from 0. |
| int rtems_rfs_bitmap_open | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_file_system * | fs, | ||
| rtems_rfs_buffer_handle * | buffer, | ||
| size_t | size, | ||
| rtems_rfs_buffer_block | block | ||
| [in] | fs | is the file system data. |
| [in] | buffer | is a pointer to the buffer handle the map is stored in. |
| [in] | size | is the number of bits in the map. |
