#define | MSR_UCLE (1<<26) /* User-mode cache lock enable (e500) */ |
#define | MSR_VE (1<<25) /* Alti-Vec enable (7400+) */ |
#define | MSR_SPE (1<<25) /* SPE enable (e500) */ |
#define | MSR_AP (1<<25) /* Auxiliary processor available */ |
#define | MSR_APE (1<<19) /* APU exception enable */ |
#define | MSR_POW (1<<18) /* Enable Power Management */ |
#define | MSR_WE (1<<18) /* Wait state enable (e500, 4xx) */ |
#define | MSR_TGPR (1<<17) /* TLB Update registers in use */ |
#define | MSR_CE (1<<17) /* BookE critical interrupt */ |
#define | MSR_ILE (1<<16) /* Interrupt Little-Endian enable */ |
#define | MSR_EE (1<<15) /* External Interrupt enable */ |
#define | MSR_PR (1<<14) /* Supervisor/User privilege */ |
#define | MSR_FP (1<<13) /* Floating Point enable */ |
#define | MSR_ME (1<<12) /* Machine Check enable */ |
#define | MSR_FE0 (1<<11) /* Floating Exception mode 0 */ |
#define | MSR_SE (1<<10) /* Single Step */ |
#define | MSR_UBLE (1<<10) /* User-mode BTB lock enable (e500) */ |
#define | MSR_DWE (1<<10) /* Debug wait enable (4xx) */ |
#define | MSR_BE (1<<9) /* Branch Trace */ |
#define | MSR_DE (1<<9) /* BookE debug exception */ |
#define | MSR_FE1 (1<<8) /* Floating Exception mode 1 */ |
#define | MSR_E300_CE (1<<7) /* e300 critical interrupt */ |
#define | MSR_IP (1<<6) /* Exception prefix 0x000/0xFFF */ |
#define | MSR_IR (1<<5) /* Instruction MMU enable */ |
#define | MSR_DR (1<<4) /* Data MMU enable */ |
#define | MSR_IS (1<<5) /* Instruction address space */ |
#define | MSR_DS (1<<4) /* Data address space */ |
#define | MSR_PMM (1<<2) /* Performance monitor mark */ |
#define | MSR_RI (1<<1) /* Recoverable Exception */ |
#define | MSR_LE (1<<0) /* Little-Endian enable */ |
#define | HID0_EMCP (1<<31) /* Enable Machine Check pin */ |
#define | HID0_EBA (1<<29) /* Enable Bus Address Parity */ |
#define | HID0_EBD (1<<28) /* Enable Bus Data Parity */ |
#define | HID0_SBCLK (1<<27) |
#define | HID0_TBEN |
#define | HID0_EICE (1<<26) |
#define | HID0_ECLK (1<<25) |
#define | HID0_PAR (1<<24) |
#define | HID0_DOZE (1<<23) |
#define | HID0_7455_HIGH_BAT_EN (1<<23) |
#define | HID0_NAP (1<<22) |
#define | HID0_SLEEP (1<<21) |
#define | HID0_DPM (1<<20) |
#define | HID0_ICE (1<<15) /* Instruction Cache Enable */ |
#define | HID0_DCE (1<<14) /* Data Cache Enable */ |
#define | HID0_ILOCK (1<<13) /* Instruction Cache Lock */ |
#define | HID0_DLOCK (1<<12) /* Data Cache Lock */ |
#define | HID0_ICFI (1<<11) /* Instruction Cache Flash Invalidate */ |
#define | HID0_DCI (1<<10) /* Data Cache Invalidate */ |
#define | HID0_7455_XBSEN (1<<8) |
#define | HID0_SIED (1<<7) /* Serial Instruction Execution [Disable] */ |
#define | HID0_BTIC (1<<5) /* Branch Target Instruction Cache [Enable] */ |
#define | HID0_LRSTK (1<<4) /* Link register stack enable (7455) */ |
#define | HID0_FOLD (1<<3) /* Branch folding enable (7455) */ |
#define | HID0_BHTE (1<<2) /* Branch History Table Enable */ |
#define | HID0_BTCD (1<<1) /* Branch target cache disable */ |
#define | FPSCR_FX (1<<31) |
#define | FPSCR_FEX (1<<30) |
#define | _MACH_prep 1 |
#define | _MACH_Pmac 2 /* pmac or pmac clone (non-chrp) */ |
#define | _MACH_chrp 4 /* chrp machine */ |
#define | _MACH_mbx 8 /* Motorola MBX board */ |
#define | _MACH_apus 16 /* amiga with phase5 powerup */ |
#define | _MACH_fads 32 /* Motorola FADS board */ |
#define | _PREP_Motorola 0x01 /* motorola prep */ |
#define | _PREP_Firm 0x02 /* firmworks prep */ |
#define | _PREP_IBM 0x00 /* ibm prep */ |
#define | _PREP_Bull 0x03 /* bull prep */ |
#define | _CHRP_Motorola 0x04 /* motorola chrp, the cobra */ |
#define | _CHRP_IBM 0x05 /* IBM chrp, the longtrail and longtrail 2 */ |
#define | _GLOBAL(n) |
#define | TBRU 269 /* Time base Upper/Lower (Reading) */ |
#define | TBRL 268 |
#define | TBWU 285 /* Time base Upper/Lower (Writing) */ |
#define | TBWL 284 |
#define | PPC_XER 1 |
#define | PPC_LR 8 |
#define | PPC_CTR 9 |
#define | HID0 1008 /* Hardware Implementation 0 */ |
#define | HID1 1009 /* Hardware Implementation 1 */ |
#define | HID2 1011 /* Hardware Implementation 2 */ |
#define | DABR 1013 /* Data Access Breakpoint */ |
#define | PPC_PVR 287 /* Processor Version */ |
#define | IBAT0U 528 /* Instruction BAT #0 Upper/Lower */ |
#define | IBAT0L 529 |
#define | IBAT1U 530 /* Instruction BAT #1 Upper/Lower */ |
#define | IBAT1L 531 |
#define | IBAT2U 532 /* Instruction BAT #2 Upper/Lower */ |
#define | IBAT2L 533 |
#define | IBAT3U 534 /* Instruction BAT #3 Upper/Lower */ |
#define | IBAT3L 535 |
#define | IBAT4U 560 /* Instruction BAT #4 Upper/Lower */ |
#define | IBAT4L 561 |
#define | IBAT5U 562 /* Instruction BAT #5 Upper/Lower */ |
#define | IBAT5L 563 |
#define | IBAT6U 564 /* Instruction BAT #6 Upper/Lower */ |
#define | IBAT6L 565 |
#define | IBAT7U 566 /* Instruction BAT #7 Upper/Lower */ |
#define | IBAT7L 567 |
#define | DBAT0U 536 /* Data BAT #0 Upper/Lower */ |
#define | DBAT0L 537 |
#define | DBAT1U 538 /* Data BAT #1 Upper/Lower */ |
#define | DBAT1L 539 |
#define | DBAT2U 540 /* Data BAT #2 Upper/Lower */ |
#define | DBAT2L 541 |
#define | DBAT3U 542 /* Data BAT #3 Upper/Lower */ |
#define | DBAT3L 543 |
#define | DBAT4U 568 /* Instruction BAT #4 Upper/Lower */ |
#define | DBAT4L 569 |
#define | DBAT5U 570 /* Instruction BAT #5 Upper/Lower */ |
#define | DBAT5L 571 |
#define | DBAT6U 572 /* Instruction BAT #6 Upper/Lower */ |
#define | DBAT6L 573 |
#define | DBAT7U 574 /* Instruction BAT #7 Upper/Lower */ |
#define | DBAT7L 575 |
#define | DMISS 976 /* TLB Lookup/Refresh registers */ |
#define | DCMP 977 |
#define | HASH1 978 |
#define | HASH2 979 |
#define | IMISS 980 |
#define | ICMP 981 |
#define | PPC_RPA 982 |
#define | SDR1 25 /* MMU hash base register */ |
#define | PPC_DAR 19 /* Data Address Register */ |
#define | DEAR_BOOKE 61 |
#define | DEAR_405 981 |
#define | SPR0 272 /* Supervisor Private Registers */ |
#define | SPRG0 272 |
#define | SPR1 273 |
#define | SPRG1 273 |
#define | SPR2 274 |
#define | SPRG2 274 |
#define | SPR3 275 |
#define | SPRG3 275 |
#define | SPRG4 276 |
#define | SPRG5 277 |
#define | SPRG6 278 |
#define | SPRG7 279 |
#define | USPRG0 256 |
#define | DSISR 18 |
#define | SRR0 26 /* Saved Registers (exception) */ |
#define | SRR1 27 |
#define | IABR 1010 /* Instruction Address Breakpoint */ |
#define | PPC_DEC 22 /* Decrementer */ |
#define | PPC_EAR 282 /* External Address Register */ |
#define | MSSCR0 1014 /* Memory Subsystem Control Register */ |
#define | L2CR 1017 /* PPC 750 and 74xx L2 control register */ |
#define | L2CR_L2E (1<<31) /* enable */ |
#define | L2CR_L2I (1<<21) /* global invalidate */ |
#define | L2CR_L2IO_745x 0x100000 /* (1<<20) L2 Instruction-Only */ |
#define | L2CR_L2DO_745x 0x10000 /* (1<<16) L2 Data-Only */ |
#define | L2CR_LOCK_745x (L2CR_L2IO_745x|L2CR_L2DO_745x) |
#define | L2CR_L3OH0 0x00080000 /* 12:L3 output hold 0 */ |
#define | L3CR 1018 /* PPC 7450/7455 L3 control register */ |
#define | L3CR_L3IO_745x 0x400000 /* (1<<22) L3 Instruction-Only */ |
#define | L3CR_L3DO_745x 0x40 /* (1<<6) L3 Data-Only */ |
#define | L3CR_LOCK_745x (L3CR_L3IO_745x|L3CR_L3DO_745x) |
#define | L3CR_RESERVED 0x0438003a /* Reserved bits in L3CR */ |
#define | L3CR_L3E 0x80000000 /* 0: L3 enable */ |
#define | L3CR_L3PE 0x40000000 /* 1: L3 data parity checking enable */ |
#define | L3CR_L3APE 0x20000000 /* 2: L3 address parity checking enable */ |
#define | L3CR_L3SIZ 0x10000000 /* 3: L3 size (0=1MB, 1=2MB) */ |
#define | L3SIZ_1M 0x00000000 |
#define | L3SIZ_2M 0x10000000 |
#define | L3CR_L3CLKEN 0x08000000 /* 4: Enables the L3_CLK[0:1] signals */ |
#define | L3CR_L3CLK 0x03800000 /* 6-8: L3 clock ratio */ |
#define | L3CLK_60 0x00000000 /* core clock / 6 */ |
#define | L3CLK_20 0x01000000 /* / 2 */ |
#define | L3CLK_25 0x01800000 /* / 2.5 */ |
#define | L3CLK_30 0x02000000 /* / 3 */ |
#define | L3CLK_35 0x02800000 /* / 3.5 */ |
#define | L3CLK_40 0x03000000 /* / 4 */ |
#define | L3CLK_50 0x03800000 /* / 5 */ |
#define | L3CR_L3IO 0x00400000 /* 9: L3 instruction-only mode */ |
#define | L3CR_L3SPO 0x00040000 /* 13: L3 sample point override */ |
#define | L3CR_L3CKSP 0x00030000 /* 14-15: L3 clock sample point */ |
#define | L3CKSP_2 0x00000000 /* 2 clocks */ |
#define | L3CKSP_3 0x00010000 /* 3 clocks */ |
#define | L3CKSP_4 0x00020000 /* 4 clocks */ |
#define | L3CKSP_5 0x00030000 /* 5 clocks */ |
#define | L3CR_L3PSP 0x0000e000 /* 16-18: L3 P-clock sample point */ |
#define | L3PSP_0 0x00000000 /* 0 clocks */ |
#define | L3PSP_1 0x00002000 /* 1 clocks */ |
#define | L3PSP_2 0x00004000 /* 2 clocks */ |
#define | L3PSP_3 0x00006000 /* 3 clocks */ |
#define | L3PSP_4 0x00008000 /* 4 clocks */ |
#define | L3PSP_5 0x0000a000 /* 5 clocks */ |
#define | L3CR_L3REP 0x00001000 /* 19: L3 replacement algorithm (0=default, 1=alternate) */ |
#define | L3CR_L3HWF 0x00000800 /* 20: L3 hardware flush */ |
#define | L3CR_L3I |
#define | L3CR_L3RT 0x00000300 /* 22-23: L3 SRAM type */ |
#define | L3RT_MSUG2_DDR 0x00000000 /* MSUG2 DDR SRAM */ |
#define | L3RT_PIPELINE_LATE 0x00000100 /* Pipelined (register-register) synchronous late-write SRAM */ |
#define | L3RT_PB2_SRAM 0x00000300 /* PB2 SRAM */ |
#define | L3CR_L3NIRCA 0x00000080 /* 24: L3 non-integer ratios clock adjustment for the SRAM */ |
#define | L3CR_L3DO 0x00000040 /* 25: L3 data-only mode */ |
#define | L3CR_PMEN 0x00000004 /* 29: Private memory enable */ |
#define | L3CR_PMSIZ 0x00000004 /* 31: Private memory size (0=1MB, 1=2MB) */ |
#define | THRM1 1020 |
#define | THRM2 1021 |
#define | THRM3 1022 |
#define | THRM1_TIN (1<<(31-0)) |
#define | THRM1_TIV (1<<(31-1)) |
#define | THRM1_THRES (0x7f<<(31-8)) |
#define | THRM1_TID (1<<(31-29)) |
#define | THRM1_TIE (1<<(31-30)) |
#define | THRM1_V (1<<(31-31)) |
#define | THRM3_SITV (0x1fff << (31-30)) |
#define | THRM3_E (1<<(31-31)) |
#define | PPC_SR0 0 |
#define | PPC_SR1 1 |
#define | PPC_SR2 2 |
#define | PPC_SR3 3 |
#define | PPC_SR4 4 |
#define | PPC_SR5 5 |
#define | PPC_SR6 6 |
#define | PPC_SR7 7 |
#define | PPC_SR8 8 |
#define | PPC_SR9 9 |
#define | PPC_SR10 10 |
#define | PPC_SR11 11 |
#define | PPC_SR12 12 |
#define | PPC_SR13 13 |
#define | PPC_SR14 14 |
#define | PPC_SR15 15 |
#define | BOOKE_DECAR 54 |
#define | PPC405_MCSR 0x23C |
#define | PPC405_ESR 0x3D4 |
#define | PPC405_DEAR 0x3D5 |
#define | BOOKE_DEAR 61 |
#define | PPC405_TSR 0x3D8 |
#define | BOOKE_TSR 336 |
#define | BOOKE_TSR_ENW (1<<31) |
#define | BOOKE_TSR_WIS (1<<30) |
#define | BOOKE_TSR_DIS (1<<27) |
#define | BOOKE_TSR_FIS (1<<26) |
#define | PPC405_TCR 0x3DA |
#define | BOOKE_TCR 340 |
#define | BOOKE_TCR_WP(x) (((x)&3)<<30) |
#define | BOOKE_TCR_WP_MASK (3<<30) |
#define | BOOKE_TCR_WRC(x) (((x)&3)<<28) |
#define | BOOKE_TCR_WRC_MASK (3<<28) |
#define | BOOKE_TCR_WIE (1<<27) |
#define | BOOKE_TCR_DIE (1<<26) |
#define | BOOKE_TCR_FP(x) (((x)&3)<<24) |
#define | BOOKE_TCR_FIE (1<<23) |
#define | BOOKE_TCR_ARE (1<<22) |
#define | BOOKE_TCR_WPEXT(x) (((x)&0xf)<<17) |
#define | BOOKE_TCR_WPEXT_MASK (0xf<<17) |
#define | BOOKE_TCR_FPEXT(x) (((x)&0xf)<<13) |
#define | BOOKE_TCR_FPEXT_MASK (0xf<<13) |
#define | BOOKE_PID 48 /* Process ID */ |
#define | BOOKE_CSRR0 58 /* Critical Save/Restore Register 0 */ |
#define | BOOKE_CSRR1 59 /* Critical Save/Restore Register 1 */ |
#define | BOOKE_ESR 62 /* Exception Syndrome Register */ |
#define | BOOKE_IVPR 63 /* Interrupt Vector Prefix Register */ |
#define | BOOKE_SPRG4_W 260 /* Special Purpose Register General 4 (WO) */ |
#define | BOOKE_SPRG5_W 261 /* Special Purpose Register General 5 (WO) */ |
#define | BOOKE_SPRG6_W 262 /* Special Purpose Register General 6 (WO) */ |
#define | BOOKE_SPRG7_W 263 /* Special Purpose Register General 7 (WO) */ |
#define | BOOKE_PIR 286 /* Processor ID Register */ |
#define | BOOKE_DBSR 304 /* Debug Status Register */ |
#define | BOOKE_DBCR0 308 /* Debug Control Register 0 */ |
#define | BOOKE_DBCR1 309 /* Debug Control Register 1 */ |
#define | BOOKE_DBCR2 310 /* Debug Control Register 2 */ |
#define | BOOKE_IAC1 312 /* Instruction Address Compare 1 */ |
#define | BOOKE_IAC2 313 /* Instruction Address Compare 2 */ |
#define | BOOKE_IAC3 314 /* Instruction Address Compare 3 */ |
#define | BOOKE_IAC4 315 /* Instruction Address Compare 4 */ |
#define | BOOKE_DAC1 316 /* Data Address Compare 1 */ |
#define | BOOKE_DAC2 317 /* Data Address Compare 2 */ |
#define | BOOKE_DVC1 318 /* Data Value Compare 1 */ |
#define | BOOKE_DVC2 319 /* Data Value Compare 2 */ |
#define | BOOKE_IVOR0 400 /* Interrupt Vector Offset Register 0 */ |
#define | BOOKE_IVOR1 401 /* Interrupt Vector Offset Register 1 */ |
#define | BOOKE_IVOR2 402 /* Interrupt Vector Offset Register 2 */ |
#define | BOOKE_IVOR3 403 /* Interrupt Vector Offset Register 3 */ |
#define | BOOKE_IVOR4 404 /* Interrupt Vector Offset Register 4 */ |
#define | BOOKE_IVOR5 405 /* Interrupt Vector Offset Register 5 */ |
#define | BOOKE_IVOR6 406 /* Interrupt Vector Offset Register 6 */ |
#define | BOOKE_IVOR7 407 /* Interrupt Vector Offset Register 7 */ |
#define | BOOKE_IVOR8 408 /* Interrupt Vector Offset Register 8 */ |
#define | BOOKE_IVOR9 409 /* Interrupt Vector Offset Register 9 */ |
#define | BOOKE_IVOR10 410 /* Interrupt Vector Offset Register 10 */ |
#define | BOOKE_IVOR11 411 /* Interrupt Vector Offset Register 11 */ |
#define | BOOKE_IVOR12 412 /* Interrupt Vector Offset Register 12 */ |
#define | BOOKE_IVOR13 413 /* Interrupt Vector Offset Register 13 */ |
#define | BOOKE_IVOR14 414 /* Interrupt Vector Offset Register 14 */ |
#define | BOOKE_IVOR15 415 /* Interrupt Vector Offset Register 15 */ |
#define | BOOKE_MCSRR0 570 /* Machine Check Save/Restore Register 0 */ |
#define | BOOKE_MCSRR1 571 /* Machine Check Save/Restore Register 1 */ |
#define | BOOKE_MCSR 572 /* Machine Check Status Register */ |
#define | PPC440_INV0 880 /* Instruction Cache Normal Victim 0 */ |
#define | PPC440_INV1 881 /* Instruction Cache Normal Victim 1 */ |
#define | PPC440_INV2 882 /* Instruction Cache Normal Victim 2 */ |
#define | PPC440_INV3 883 /* Instruction Cache Normal Victim 3 */ |
#define | PPC440_ITV0 884 /* Instruction Cache Transient Victim 0 */ |
#define | PPC440_ITV1 885 /* Instruction Cache Transient Victim 1 */ |
#define | PPC440_ITV2 886 /* Instruction Cache Transient Victim 2 */ |
#define | PPC440_ITV3 887 /* Instruction Cache Transient Victim 3 */ |
#define | PPC440_CCR1 888 /* Core Configuration Register 1 */ |
#define | PPC440_DNV0 912 /* Data Cache Normal Victim 0 */ |
#define | PPC440_DNV1 913 /* Data Cache Normal Victim 1 */ |
#define | PPC440_DNV2 914 /* Data Cache Normal Victim 2 */ |
#define | PPC440_DNV3 915 /* Data Cache Normal Victim 3 */ |
#define | PPC440_DTV0 916 /* Data Cache Transient Victim 0 */ |
#define | PPC440_DTV1 917 /* Data Cache Transient Victim 1 */ |
#define | PPC440_DTV2 918 /* Data Cache Transient Victim 2 */ |
#define | PPC440_DTV3 919 /* Data Cache Transient Victim 3 */ |
#define | PPC440_DVLIM 920 /* Data Cache Victim Limit */ |
#define | PPC440_IVLIM 921 /* Instruction Cache Victim Limit */ |
#define | PPC440_RSTCFG 923 /* Reset Configuration */ |
#define | PPC440_DCDBTRL 924 /* Data Cache Debug Tag Register Low */ |
#define | PPC440_DCDBTRH 925 /* Data Cache Debug Tag Register High */ |
#define | PPC440_ICDBTRL 926 /* Instruction Cache Debug Tag Register Low */ |
#define | PPC440_ICDBTRH 927 /* Instruction Cache Debug Tag Register High */ |
#define | PPC440_MMUCR 946 /* Memory Management Unit Control Register */ |
#define | PPC440_CCR0 947 /* Core Configuration Register 0 */ |
#define | PPC440_ICDBDR 979 /* Instruction Cache Debug Data Register */ |
#define | PPC440_DBDR 1011 /* Debug Data Register */ |
#define | PPC440_TLB0_EPN(n) ( (((1<<22)-1)&(n)) << (31-21)) /* Etended Page Number */ |
#define | PPC440_TLB0_EPN_GET(n) ( ((n) >> (31-21)) & ((1<<22)-1)) |
#define | PPC440_TLB0_V ( 1 << (31-22)) /* Entry valid */ |
#define | PPC440_TLB0_TS ( 1 << (31-23)) /* Translation space */ |
#define | PPC440_TLB0_TSIZE(n) ( (0xf & (n)) << (31-27)) /* Page size */ |
#define | PPC440_TLB0_TSIZE_GET(n) ( ((n) >> (31-27)) & 0xf) |
#define | PPC440_TLB0_TPAR(n) ( (0xf & (n)) << (31-31)) /* Tag Parity */ |
#define | PPC440_TLB0_TPAR_GET(n) ( ((n) >> (31-31)) & 0xf) |
#define | PPC440_PID_TID(n) ( (0xff & (n)) << (31-31)) /* Translation ID */ |
#define | PPC440_PID_TID_GET(n) ( ((n) >> (31-31)) & 0xff) |
#define | PPC440_TLB1_RPN(n) ( (((1<<22)-1)&(n)) << (31-21)) /* Real Page Number */ |
#define | PPC440_TLB1_RPN_GET(n) ( ((n) >> (31-21)) & ((1<<22)-1)) |
#define | PPC440_TLB1_PAR1(n) ( (0x3 & (n)) << (31-23)) /* Parity for TLB word 1 */ |
#define | PPC440_TLB1_PAR1_GET(n) ( ((n) >> (31-23)) & 0x3) |
#define | PPC440_TLB1_ERPN(n) ( (0xf & (n)) << (31-31)) /* Extended Real Page No. */ |
#define | PPC440_TLB1_ERPN_GET(n) ( ((n) >> (31-31)) & 0xf) |
#define | PPC440_TLB2_PAR2(n) ( (0x3 & (n)) << (31- 1)) /* Parity for TLB word 2 */ |
#define | PPC440_TLB2_PAR2_GET(n) ( ((n) >> (31- 1)) & 0x3) |
#define | PPC440_TLB2_U0 ( 1 << (31-16)) /* User attr. 0 */ |
#define | PPC440_TLB2_U1 ( 1 << (31-17)) /* User attr. 1 */ |
#define | PPC440_TLB2_U2 ( 1 << (31-18)) /* User attr. 2 */ |
#define | PPC440_TLB2_U3 ( 1 << (31-19)) /* User attr. 3 */ |
#define | PPC440_TLB2_W ( 1 << (31-20)) /* Write-through */ |
#define | PPC440_TLB2_I ( 1 << (31-21)) /* Cache-inhibited */ |
#define | PPC440_TLB2_M ( 1 << (31-22)) /* Memory-coherence req. */ |
#define | PPC440_TLB2_G ( 1 << (31-23)) /* Guarded */ |
#define | PPC440_TLB2_E ( 1 << (31-24)) /* Little-endian */ |
#define | PPC440_TLB2_UX ( 1 << (31-26)) /* User exec. */ |
#define | PPC440_TLB2_UW ( 1 << (31-27)) /* User write */ |
#define | PPC440_TLB2_UR ( 1 << (31-28)) /* User read */ |
#define | PPC440_TLB2_SX ( 1 << (31-29)) /* Super exec. */ |
#define | PPC440_TLB2_SW ( 1 << (31-30)) /* Super write */ |
#define | PPC440_TLB2_SR ( 1 << (31-31)) /* Super read */ |
#define | PPC440_TLB2_ATTR(x) ( ((x) & 0x1ff) << 7 ) |
#define | PPC440_TLB2_ATTR_GET(x) ( ((x) >> 7) & 0x1ff ) |
#define | PPC440_TLB2_PERM(n) ( (n) & 0x3f ) |
#define | PPC440_TLB2_PERM_GET(n) ( (n) & 0x3f ) |
#define | FSL_EIS_BUCSR 1013 |
#define | FSL_EIS_BUCSR_STAC_EN (1 << (63 - 39)) |
#define | FSL_EIS_BUCSR_LS_EN (1 << (63 - 41)) |
#define | FSL_EIS_BUCSR_BBFI (1 << (63 - 54)) |
#define | FSL_EIS_BUCSR_BALLOC_ALL (0x0 << (63 - 59)) |
#define | FSL_EIS_BUCSR_BALLOC_FORWARD (0x1 << (63 - 59)) |
#define | FSL_EIS_BUCSR_BALLOC_BACKWARD (0x2 << (63 - 59)) |
#define | FSL_EIS_BUCSR_BALLOC_NONE (0x3 << (63 - 59)) |
#define | FSL_EIS_BUCSR_BPRED_TAKEN (0x0 << (63 - 61)) |
#define | FSL_EIS_BUCSR_BPRED_TAKEN_ONLY_FORWARD (0x1 << (63 - 62)) |
#define | FSL_EIS_BUCSR_BPRED_TAKEN_ONLY_BACKWARD (0x2 << (63 - 62)) |
#define | FSL_EIS_BUCSR_BPRED_NOT_TAKEN (0x3 << (63 - 62)) |
#define | FSL_EIS_BUCSR_BPEN (1 << (63 - 63)) |
#define | FSL_EIS_SVR 1023 |
#define | FSL_EIS_MAS0 624 |
#define | FSL_EIS_MAS0_TLBSEL (1 << (63 - 35)) |
#define | FSL_EIS_MAS0_ESEL(n) ((0xf & (n)) << (63 - 47)) |
#define | FSL_EIS_MAS0_ESEL_GET(m) (((m) >> (63 - 47)) & 0xf) |
#define | FSL_EIS_MAS0_NV (1 << (63 - 63)) |
#define | FSL_EIS_MAS1 625 |
#define | FSL_EIS_MAS1_V (1 << (63 - 32)) |
#define | FSL_EIS_MAS1_IPROT (1 << (63 - 33)) |
#define | FSL_EIS_MAS1_TID(n) ((0xff & (n)) << (63 - 47)) |
#define | FSL_EIS_MAS1_TID_GET(n) (((n) >> (63 - 47)) & 0xfff) |
#define | FSL_EIS_MAS1_TS (1 << (63 - 51)) |
#define | FSL_EIS_MAS1_TSIZE(n) ((0xf & (n)) << (63 - 55)) |
#define | FSL_EIS_MAS1_TSIZE_GET(n) (((n)>>(63 - 55)) & 0xf) |
#define | FSL_EIS_MAS2 626 |
#define | FSL_EIS_MAS2_EPN(n) ((((1 << 21) - 1)&(n)) << (63-51)) |
#define | FSL_EIS_MAS2_EPN_GET(n) (((n) >> (63 - 51)) & 0xfffff) |
#define | FSL_EIS_MAS2_EA(n) FSL_EIS_MAS2_EPN((n) >> 12) |
#define | FSL_EIS_MAS2_EA_GET(n) (FSL_EIS_MAS2_EPN_GET(n) << 12) |
#define | FSL_EIS_MAS2_X0 (1 << (63 - 57)) |
#define | FSL_EIS_MAS2_X1 (1 << (63 - 58)) |
#define | FSL_EIS_MAS2_W (1 << (63 - 59)) |
#define | FSL_EIS_MAS2_I (1 << (63 - 60)) |
#define | FSL_EIS_MAS2_M (1 << (63 - 61)) |
#define | FSL_EIS_MAS2_G (1 << (63 - 62)) |
#define | FSL_EIS_MAS2_E (1 << (63 - 63)) |
#define | FSL_EIS_MAS2_ATTR(x) ((x) & 0x7f) |
#define | FSL_EIS_MAS2_ATTR_GET(x) ((x) & 0x7f) |
#define | FSL_EIS_MAS3 627 |
#define | FSL_EIS_MAS3_RPN(n) ((((1 << 21) - 1) & (n)) << (63-51)) |
#define | FSL_EIS_MAS3_RPN_GET(n) (((n)>>(63 - 51)) & 0xfffff) |
#define | FSL_EIS_MAS3_RA(n) FSL_EIS_MAS3_RPN((n) >> 12) |
#define | FSL_EIS_MAS3_RA_GET(n) (FSL_EIS_MAS3_RPN_GET(n) << 12) |
#define | FSL_EIS_MAS3_U0 (1 << (63 - 54)) |
#define | FSL_EIS_MAS3_U1 (1 << (63 - 55)) |
#define | FSL_EIS_MAS3_U2 (1 << (63 - 56)) |
#define | FSL_EIS_MAS3_U3 (1 << (63 - 57)) |
#define | FSL_EIS_MAS3_UX (1 << (63 - 58)) |
#define | FSL_EIS_MAS3_SX (1 << (63 - 59)) |
#define | FSL_EIS_MAS3_UW (1 << (63 - 60)) |
#define | FSL_EIS_MAS3_SW (1 << (63 - 61)) |
#define | FSL_EIS_MAS3_UR (1 << (63 - 62)) |
#define | FSL_EIS_MAS3_SR (1 << (63 - 63)) |
#define | FSL_EIS_MAS3_PERM(n) ((n) & 0x3ff) |
#define | FSL_EIS_MAS3_PERM_GET(n) ((n) & 0x3ff) |
#define | FSL_EIS_MAS4 628 |
#define | FSL_EIS_MAS4_TLBSELD (1 << (63 - 35)) |
#define | FSL_EIS_MAS4_TIDSELD(n) ((0x3 & (n)) << (63 - 47)) |
#define | FSL_EIS_MAS4_TSIZED(n) ((0xf & (n)) << (63 - 55)) |
#define | FSL_EIS_MAS4_X0D FSL_EIS_MAS2_X0 |
#define | FSL_EIS_MAS4_X1D FSL_EIS_MAS2_X1 |
#define | FSL_EIS_MAS4_WD FSL_EIS_MAS2_W |
#define | FSL_EIS_MAS4_ID FSL_EIS_MAS2_I |
#define | FSL_EIS_MAS4_MD FSL_EIS_MAS2_M |
#define | FSL_EIS_MAS4_GD FSL_EIS_MAS2_G |
#define | FSL_EIS_MAS4_ED FSL_EIS_MAS2_E |
#define | FSL_EIS_MAS5 629 |
#define | FSL_EIS_MAS6 630 |
#define | FSL_EIS_MAS6_SPID0(n) ((0xff & (n)) << (63 - 55)) |
#define | FSL_EIS_MAS6_SAS (1 << (63 - 63)) |
#define | FSL_EIS_MAS7 944 |
#define | FSL_EIS_MMUCFG 1015 |
#define | FSL_EIS_MMUCSR0 1012 |
#define | FSL_EIS_PID0 48 |
#define | FSL_EIS_PID1 633 |
#define | FSL_EIS_PID2 634 |
#define | FSL_EIS_TLB0CFG 688 |
#define | FSL_EIS_TLB1CFG 689 |
#define | FSL_EIS_L1CFG0 515 |
#define | FSL_EIS_L1CFG1 516 |
#define | FSL_EIS_L1CSR0 1010 |
#define | FSL_EIS_L1CSR1 1011 |
#define | FSL_EIS_ATBL 526 |
#define | FSL_EIS_ATBU 527 |
#define | FSL_EIS_MCAR 573 |
#define | FSL_EIS_DSRR0 574 |
#define | FSL_EIS_DSRR1 575 |
#define | FSL_EIS_SPEFSCR 512 |
#define | FSL_EIS_SPRG8 604 |
#define | FSL_EIS_SPRG9 605 |
#define | FSL_EIS_DBCR3 561 |
#define | FSL_EIS_DBCR4 563 |
#define | FSL_EIS_DBCR5 564 |
#define | FSL_EIS_DBCR6 603 |
#define | FSL_EIS_DBCNT 562 |
#define | PPC_INTERRUPT_DISABLE_MASK_DEFAULT MSR_EE |
| Default value for the interrupt disable mask. More...
#define | _CPU_MSR_GET(_msr_value) |
#define | _CPU_MSR_SET(_msr_value) { __asm__ volatile ("mtmsr %0" : "=&r" ((_msr_value)) : "0" ((_msr_value))); } |
#define | _CPU_ISR_Disable(_isr_cookie) |
#define | _CPU_ISR_Enable(_isr_cookie) ppc_interrupt_enable(_isr_cookie) |
#define | _CPU_ISR_Flash(_isr_cookie) ppc_interrupt_flash(_isr_cookie) |
