RTEMS thread and RTEMS_ASR modes. More...
Modules | |
| Classic Modes Implementation | |
Files | |
| file | modes.c |
| Body for RTEMS_INTERRUPT_LEVEL Macro. | |
| #define | RTEMS_ALL_MODE_MASKS 0x0000ffff |
| The following constants define the individual modes and masks which may be used to compose a mode set and to alter modes. | |
| #define | RTEMS_DEFAULT_MODES 0x00000000 |
| This mode constant is the default mode set. | |
| #define | RTEMS_CURRENT_MODE 0 |
| This mode constant is used when the user wishes to obtain their current execution mode. | |
| #define | RTEMS_TIMESLICE_MASK 0x00000200 |
| This mode constant corresponds to the timeslice enable/disable bit. More... | |
| #define | RTEMS_PREEMPT_MASK 0x00000100 |
| This mode constant corresponds to the preemption enable/disable bit. More... | |
| #define | RTEMS_ASR_MASK 0x00000400 |
| This mode constant corresponds to the signal enable/disable bit. More... | |
| #define | RTEMS_INTERRUPT_MASK CPU_MODES_INTERRUPT_MASK |
| This mode constant corresponds to the interrupt enable/disable bits. More... | |
| #define | RTEMS_PREEMPT 0x00000000 |
| This mode constant is used to indicate preemption is enabled. More... | |
| #define | RTEMS_NO_PREEMPT 0x00000100 |
| This mode constant is used to indicate preemption is disabled. More... | |
| #define | RTEMS_NO_TIMESLICE 0x00000000 |
| This mode constant is used to indicate timeslicing is disabled. More... | |
| #define | RTEMS_TIMESLICE 0x00000200 |
| This mode constant is used to indicate timeslicing is enabled. More... | |
| #define | RTEMS_ASR 0x00000000 |
| This mode constant is used to indicate signal processing is enabled. More... | |
| #define | RTEMS_NO_ASR 0x00000400 |
| This mode constant is used to indicate signal processing is disabled. More... | |
| #define | RTEMS_INTERRUPT_LEVEL(_mode_set) ( (_mode_set) & RTEMS_INTERRUPT_MASK ) |
| RTEMS_INTERRUPT_LEVEL. More... | |
Typedefs | |
| typedef uint32_t | Modes_Control |
| The following type defines the control block used to manage each a mode set. | |
| Modes_Control | rtems_interrupt_level_body (uint32_t level) |
| Body for RTEMS_INTERRUPT_LEVEL Macro. More... | |
| const uint32_t | rtems_interrupt_mask |
| Interrupt Mask Variable. More... | |
This encapsulates functionality related to the task modes supported by the Classic API Task Manager.
This include file contains all constants and structures associated with the RTEMS thread and RTEMS_ASR modes.
| #define RTEMS_ASR 0x00000000 |
| #define RTEMS_ASR_MASK 0x00000400 |
Referenced by _Modes_Is_asr_disabled().
| #define RTEMS_INTERRUPT_LEVEL | ( | _mode_set | ) | ( (_mode_set) & RTEMS_INTERRUPT_MASK ) |
This function returns the processor dependent interrupt level which corresponds to the requested interrupt level.
Referenced by rtems_interrupt_level_body().
| #define RTEMS_INTERRUPT_MASK CPU_MODES_INTERRUPT_MASK |
Referenced by _Modes_Get_interrupt_level().
| #define RTEMS_NO_ASR 0x00000400 |
| #define RTEMS_NO_PREEMPT 0x00000100 |
| #define RTEMS_NO_TIMESLICE 0x00000000 |
| #define RTEMS_PREEMPT 0x00000000 |
Referenced by _Modes_Is_preempt().
| #define RTEMS_PREEMPT_MASK 0x00000100 |
| #define RTEMS_TIMESLICE 0x00000200 |
Referenced by _Modes_Is_timeslice().
| #define RTEMS_TIMESLICE_MASK 0x00000200 |
| Modes_Control rtems_interrupt_level_body | ( | uint32_t | level | ) |
| [in] | level | is the desired interrupt level |
| This | methods returns a mode with the desired interrupt level in the proper bitfield location. |
References RTEMS_INTERRUPT_LEVEL.
| const uint32_t rtems_interrupt_mask |
This variable is used by bindings from languages other than C and C++.
