Initialization Manager. More...
#include <rtems/system.h>#include <rtems/config.h>#include <rtems/debug.h>#include <rtems/extensionimpl.h>#include <rtems/init.h>#include <rtems/score/sysstate.h>#include <rtems/score/apiext.h>#include <rtems/score/apimutex.h>#include <rtems/score/copyrt.h>#include <rtems/score/cpusetimpl.h>#include <rtems/score/heap.h>#include <rtems/score/interr.h>#include <rtems/score/isr.h>#include <rtems/score/priority.h>#include <rtems/score/schedulerimpl.h>#include <rtems/score/smpimpl.h>#include <rtems/score/timecounter.h>#include <rtems/score/threadimpl.h>#include <rtems/score/todimpl.h>#include <rtems/score/userextimpl.h>#include <rtems/score/watchdogimpl.h>#include <rtems/score/wkspace.h>#include <rtems/sptables.h>#include <rtems/rtems/rtemsapi.h>#include <rtems/posix/posixapi.h>
| void | rtems_initialize_data_structures (void) |
| RTEMS data structures initialization. More... | |
| void | rtems_initialize_before_drivers (void) |
| RTEMS initialization before the device drivers are initialized. More... | |
| void | rtems_initialize_device_drivers (void) |
| RTEMS initialization that initializes all device drivers. More... | |
| void | rtems_initialize_start_multitasking (void) |
| Starts the multitasking. More... | |
| Objects_Information * | _Internal_Objects [OBJECTS_INTERNAL_CLASSES_LAST+1] |
| void rtems_initialize_before_drivers | ( | void | ) |
This routine implements the portion of RTEMS initialization that is done immediately before device drivers are initialized.
References _DRV_Manager_initialization(), and _MPCI_Create_server().
| void rtems_initialize_data_structures | ( | void | ) |
This routine implements the portion of the RTEMS initializatin process that involves initializing data structures to a state that scheduling can occur in a consistent manner.
| void rtems_initialize_device_drivers | ( | void | ) |
This routine implements the portion of RTEMS initialization that initializes all device drivers.
References _DRV_Manager_init_level(), _IO_Initialize_all_drivers(), _MPCI_Initialization(), _MPCI_Internal_packets_Send_process_packet(), and bsp_driver_level_hook().
| void rtems_initialize_start_multitasking | ( | void | ) |
This directive initiates multitasking and performs a context switch to the first user application task and may enable interrupts as a side-effect of that context switch. The context switch saves the executing context. The application runs now. The directive rtems_shutdown_executive() will return to the saved context. The exit() function will use this directive.
After a return to the saved context a fatal system state is reached. The fatal source is RTEMS_FATAL_SOURCE_EXIT with a fatal code set to the value passed to rtems_shutdown_executive().
This directive does not return.
