rtems-4.11.3
score
include
score
priority.h
1
11
12
* COPYRIGHT (c) 1989-2011.
13
* On-Line Applications Research Corporation (OAR).
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
20
#ifndef _RTEMS_SCORE_PRIORITY_H
21
#define _RTEMS_SCORE_PRIORITY_H
22
41
42
* Processor specific information.
43
44
#include <rtems/score/cpu.h>
45
46
#ifdef __cplusplus
47
extern
"C"
48
#endif
49
56
typedef
uint32_t
Priority_Control
57
59
#define PRIORITY_MINIMUM 0
60
66
#define PRIORITY_PSEUDO_ISR PRIORITY_MINIMUM
67
69
#if defined (CPU_PRIORITY_MAXIMUM)
70
#define PRIORITY_DEFAULT_MAXIMUM CPU_PRIORITY_MAXIMUM
71
#else
72
#define PRIORITY_DEFAULT_MAXIMUM 255
73
#endif
74
76
#define PRIORITY_MAXIMUM rtems_maximum_priority
77
81
extern
uint8_t
82
83
#ifdef __cplusplus
84
85
#endif
86
89
#endif
90
/* end of include file */
uint8_t rtems_maximum_priority
This variable contains the configured number of priorities.
Priority_Control
uint32_t Priority_Control
The following type defines the control block used to manage thread priorities.
Definition:
priority.h:56
