This include file contains the static inline implementation of the private inlined routines for POSIX condition variables. More...
#include <rtems/posix/cond.h>#include <rtems/score/objectimpl.h>#include <rtems/score/threadqimpl.h>#include <rtems/score/watchdog.h>
| #define | POSIX_CONDITION_VARIABLES_NO_MUTEX 0 |
| Constant to indicate condition variable does not currently have a mutex assigned to it. | |
| void | _POSIX_Condition_variables_Manager_initialization (void) |
| POSIX Condition Variable Manager Initialization. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Condition_variables_Control * | _POSIX_Condition_variables_Allocate (void) |
| POSIX Condition Variable Allocate. More... | |
| RTEMS_INLINE_ROUTINE void | _POSIX_Condition_variables_Free (POSIX_Condition_variables_Control *the_condition_variable) |
| POSIX Condition Variable Free. More... | |
| POSIX_Condition_variables_Control * | _POSIX_Condition_variables_Get (pthread_cond_t *cond, Objects_Locations *location) |
| POSIX Condition Variable Get. More... | |
| int | _POSIX_Condition_variables_Signal_support (pthread_cond_t *cond, bool is_broadcast) |
| Implements wake up version of the "signal" operation. More... | |
| int | _POSIX_Condition_variables_Wait_support (pthread_cond_t *cond, pthread_mutex_t *mutex, Watchdog_Interval timeout, bool already_timedout) |
| POSIX condition variables wait support. More... | |
| POSIX_EXTERN Objects_Information | _POSIX_Condition_variables_Information |
| The following defines the information control block used to manage this class of objects. | |
| const pthread_condattr_t | _POSIX_Condition_variables_Default_attributes |
| The default condition variable attributes structure. | |
| RTEMS_INLINE_ROUTINE POSIX_Condition_variables_Control* _POSIX_Condition_variables_Allocate | ( | void | ) |
This function allocates a condition variable control block from the inactive chain of free condition variable control blocks.
References _Objects_Allocate().
Referenced by pthread_cond_init().
| RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Free | ( | POSIX_Condition_variables_Control * | the_condition_variable | ) |
This routine frees a condition variable control block to the inactive chain of free condition variable control blocks.
| POSIX_Condition_variables_Control* _POSIX_Condition_variables_Get | ( | pthread_cond_t * | cond, |
| Objects_Locations * | location | ||
This function maps condition variable IDs to condition variable control blocks. If ID corresponds to a local condition variable, then it returns the_condition variable control pointer which maps to ID and location is set to OBJECTS_LOCAL. if the condition variable ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_condition variable is undefined. Otherwise, location is set to OBJECTS_ERROR and the_condition variable is undefined.
Referenced by _POSIX_Condition_variables_Signal_support(), and pthread_cond_destroy().
| void _POSIX_Condition_variables_Manager_initialization | ( | void | ) |
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _POSIX_Condition_variables_Information.
| int _POSIX_Condition_variables_Signal_support | ( | pthread_cond_t * | cond, |
| bool | is_broadcast | ||
A support routine which implements guts of the broadcast and single task wake up version of the "signal" operation.
References _POSIX_Condition_variables_Get().
Referenced by pthread_cond_broadcast(), and pthread_cond_signal().
| int _POSIX_Condition_variables_Wait_support | ( | pthread_cond_t * | cond, |
| pthread_mutex_t * | mutex, | ||
| Watchdog_Interval | timeout, | ||
| bool | already_timedout | ||
A support routine which implements guts of the blocking, non-blocking, and timed wait version of condition variable wait routines.
