Watchdog Timer Handling. More...
| #define | wdt_reset() __asm__ __volatile__ ("wdr") |
| Watchdog Timer Reset. More... | |
| #define | _WD_PS3_MASK 0x00 |
| #define | _WD_CONTROL_REG WDTCR |
| #define | _WD_CHANGE_BIT WDCE |
| #define | wdt_enable(value) |
Enable the watchdog timer, configuring it for expiry after timeout (which is a combination of the WDP0 through WDP2 bits to write into the WDTCR register; For those devices that have a WDTCSR register, it uses the combination of the WDP0 through WDP3 bits). More... | |
| #define | wdt_disable() |
| Disable the watchdog timer, if possible. More... | |
| #define | WDTO_15MS 0 |
| Symbolic constants for the watchdog timeout. More... | |
| #define | WDTO_30MS 1 |
| #define | WDTO_60MS 2 |
| #define | WDTO_120MS 3 |
| #define | WDTO_250MS 4 |
| #define | WDTO_500MS 5 |
| #define | WDTO_1S 6 |
| #define | WDTO_2S 7 |
